Unable to receive UART response when combined the NUS example with custom service central example
I am using a central example to scan the peripheral and connects to it. I get data through notifications in bulk. That works fine. Then in order to add support to FONA808 module, I need to have UART communication which I have established using NUS peripheral example (because that uses UART). Both of the examples work fine when I use them separately.
Now when I have combined NUS code (without use of peripheral) inside the central example, I first got into problem of NO_MEMORY(err_code=0x04) issue because I was adding 2 services (Custom & NUS). I just can live without custom service on central so I just commented that out and now I don't have that issue. I am just having NUS(1) service in my code (although I also don't need it).
However, the problem in this combined code is that:
NUS service is added successfully, UART is initiated successfully, pins assignment is same as in working NUS example, data bits are transmitted serially through the following code:
for(int i=0;i<strlen(AT_cmd);i++)
    while(app_uart_put(AT_cmd[i]) != NRF_SUCCESS);
Since this code does not halt inside the while loop, so (I am assuming that)  the data bits are being transferred successfully (please correct me if I am wrong, do I need to see that on oscilloscope?).
But after this, I am expecting response from FONA808 which I never receive and I am stuck in loop waiting for the response forever.
Just to mention again that FONA808 works fine with NUS-standalone code (when not mixed with central code), so I am sure FONA808 module is working fine and the Tx/Rx pins are the same in the combined code.
Can anyone think of possible reasons for this problem? I will be obliged if someone can give me a hint to debug why the serial communication not working well in my situation.
Thanks
  • I just want to add that I get the following on my log:
    0> RAM START ADDR 0x200025E0 should be adjusted to 0x20002418
    0> RAM SIZE should be adjusted to 0xDBE8
    0> sd_ble_enable: RAM START at 0x200025E0
    Currently the RAM start address is set at 0x200025E0.
    If I set the RAM Start address to be 0x20002418 (Meaning I am keeping less RAM for SD), then I get
    0> sd_ble_enable: RAM START at 0x20002418
    0> sd_ble_enable: app_ram_base should be adjusted to 0x200025E0
    0> ram size should be adjusted to 0xDA20
    0> softdevice_enable ERROR code = 0x4
    Error code 0x04 means, I don't have sufficient MEMORY for SD. So, I think setting the RAM starting point to 0x200025E0 keeps sufficient RAM for SD, but in that scenario I don't understand why I get the 1st message of reducing the RAM start address to 0x20002418???
    Can there be some conflicting memory usage going inside the app?
    I am using CENTRAL_LINK_COUNT==1 & PERIPHERAL_LINK_COUNT==1. While I am using one service only, as mentioned above.
  • I don't think the above mentioned RAM usage messages have anything to do with UART problem. Because I have just checked that my other program (which is working fine and does not use central code) also gives the same messages on top of the log:
    But still works fine. Meaning UART operation has nothing to do with these messages. The problem is somewhere else.
  • UPDATE: I have just checked on the oscilloscope that both Tx and Rx pins of nRF52 are getting data on them.
    Meaning UART is working fine while transmitting the data at least (UART of nRF sends data and gets the response back from FONA808).
    However, due to some reason the UART in nRF is not detecting the received response, because of which the application keeps on waiting for the response.
    Here is my code for the UART event handler which is supposed to handle the received packets from FONA808 module.
        static uint8_t data_array[FONA_CMD_RET_MAX_DATA_LEN];
        static uint8_t index = 0;
        uint32_t       err_code;
    		static char* http_read;
        switch (p_event->evt_type)
    				//Test
    				SEGGER_RTT_printf(0, "\nReceived some response from UART\n");
            case APP_UART_DATA_READY:			//Gets the event at each byte receive
                index++;
                if (data_array[index - 1] == '\n') 															//AK removed the the upper limit on BLE_NUS_MAX_DATA_LEN==20
    																																						//FONA reply consists of at least 3 "\n" if SUCCESS
    																																						// 1: Command repeats
    																																						// 2: Command response
    																																						// 3: OK etc.
    								/*			AK47			*/
    								// Data is ready to be displayed
    								fona_cmd_t.ret_cr_cnt++;		//New CR '\n' found in the command
    								uint8_t i=0;
    								do{
    								//	SEGGER_RTT_printf(0, "Rx[%d] = %c\n",i,data_array[i]);
    									 cmd_ret[fona_cmd_t.ret_cr_cnt][i]=data_array[i];
    									//SEGGER_RTT_printf(0, "cmd_ret [%d] = %x\n",i,cmd_ret[fona_cmd_t.ret_cr_cnt][i]);
    									i++;
    								}while(data_array[i] != '\n');
    								fona_cmd_t.ret_len=i-1;
    								if(fona_cmd_t.ret_len == 0)
    									fona_cmd_t.ret_type		=	 CMD_NULL;
    									fona_cmd_t.cmd_status =  CMD_PROCESS;
    										//If command length is Non-Zero :: Characterizing the command return types (wnhich type of return code is it)
    										char* ret_type = strstr(cmd_ret[fona_cmd_t.ret_cr_cnt],fona_cmd_t.cmd);		//Finding same command
    										if(ret_type!=NULL)																	//Meaning "SAME" command found in return type
    											fona_cmd_t.ret_type		=	 CMD_REPEAT;
    										else		//Same command was not returned
    											char* ret_type = strstr(cmd_ret[fona_cmd_t.ret_cr_cnt],"OK");						//Finding OK in response
    											if(ret_type!=NULL)																//Found OK
    												fona_cmd_t.ret_type=CMD_OK;
    												if(strstr(fona_cmd_t.cmd,"AT+HTTPACTION=1")!=NULL)		//If command is AT+HTTPACTION=1 ; in that case "OK" does not indicated the end of response
    													SEGGER_RTT_printf(0, "OK response of AT+HTTPACTION=1 does not mean EOC\n");
    													fona_cmd_t.cmd_status =  CMD_END;								//Nothing to expect after "OK"
    													fona_cmd_t.ret_cr_cnt=0;													//Cleared
    											else		// Response was not OK
    												char* ret_type = strstr(cmd_ret[fona_cmd_t.ret_cr_cnt],"ERROR");						//Finding ERROR in response
    												if(ret_type!=NULL)																//Found ERROR
    													fona_cmd_t.ret_type=CMD_ERROR;
    													fona_cmd_t.cmd_status =  CMD_END;								//Nothing to expect after "ERROR"
    												else	//ERROR was not found in response
    													char* ret_type = strstr(cmd_ret[fona_cmd_t.ret_cr_cnt],"0.0.0.0");						//Finding GPRS network release
    														fona_cmd_t.ret_type=CMD_GPRS_INVALID_IP;
    														fona_cmd_t.cmd_status =  CMD_END;								//Nothing to expect after "CMD_GPRS_DEACT"
    													else		//NULL ip was not found in response
    														char* ret_type = strstr(cmd_ret[fona_cmd_t.ret_cr_cnt],"DOWNLOAD");						//Finding ERROR in response
    															fona_cmd_t.ret_type   =  CMD_DOWNLOAD;
    															fona_cmd_t.cmd_status =  CMD_PROCESS;								//User needs to process (input data) further
    															char* ret_type = strstr(cmd_ret[fona_cmd_t.ret_cr_cnt],"+HTTPACTION"); // Denotes that HTTP POST executed OK :: CMD_HTTP_POST_OK
    															if(ret_type!=NULL)																//Found respose from server on +HTTPACTION:1
    																SEGGER_RTT_printf(0, "Response from server = %s \n",cmd_ret[fona_cmd_t.ret_cr_cnt]);
    																char* ret_type = strstr(cmd_ret[fona_cmd_t.ret_cr_cnt],"200");	//200 status code=SUCCESS
    																if(ret_type!=NULL)																							//Found 200 in the response from server
    																	SEGGER_RTT_printf(0, "\n*** Data successfully uploaded to server ***\n");
    																	fona_cmd_t.cmd_repeat = 0;			//Don't repeat cmd
    																	fona_cmd_t.ret_type   =  CMD_HTTP_POST_OK;
    																	fona_cmd_t.cmd_status =  CMD_END;								//Nothing to expect after this
    																	SEGGER_RTT_printf(0, "\n*** Some error in uploading data to server. Retry ***\n");
    																	fona_cmd_t.cmd_repeat = 1;			//cmd_repeat flag raised
    																	fona_cmd_t.ret_type   =  CMD_HTTP_POST_REPEAT;
    																	fona_cmd_t.cmd_status =  CMD_END;								//Ending the command with repeat type[CMD_HTTP_POST_REPEAT]: That will force to re-execute the command
    																//http_read = cmd_ret[fona_cmd_t.ret_cr_cnt];
    																char* ret_type = strstr(cmd_ret[fona_cmd_t.ret_cr_cnt],"+HTTPREAD");	//Message from the server
    																	SEGGER_RTT_printf(0, "Message from server = %s \n",cmd_ret[fona_cmd_t.ret_cr_cnt]);
    																	fona_cmd_t.ret_type   =  CMD_HTTP_POST_READ;
    																	fona_cmd_t.ret_type		=  CMD_RESPONSE;
    																	fona_cmd_t.cmd_status =  CMD_PROCESS;						//Command return string : more to expect
    								/*			AK47			*/
                    index = 0;
            case APP_UART_FIFO_ERROR:
    BTW, the same piece of code (UART event handler) is working fine (with the same hardware of FONA808) when I don't combine it with central example. Any hints why nRF UART event handler is not being executed?
  • UPDATE:
    I got the issue resolved. The exact reason, I am still unsure.
    The issue was that I was using app_uart.c in the project which was not working fine.
    While I was using app_uart_fifo.c in the project which was working fine.
    Since both of these files, I guess, uses same nomenclature of the APIs, so I could not point it out.
    Once I started using app_uart_fifo.c and app_fifo.c in the combined project, the issue was resolved. NRF now can hear back on UART and the program is working as expected.
    Still, I have one question in mind, why???
