In the 15.3 SDK I see different IDE projects setting under peripheral "mbr" directory and the "blank" directory.
What is the difference?
The MBR - Master Boot Record is used to allow safe update of bootloader on the chip. The MBR is included on the nRF52840 Dongle, as this device contains a bootloader to allow programming applications through the USB port. Please see this tutorial for more details. Blank directory is used for devices that does not require a MBR/bootloader, for instance the nRF52 DK and nRF52840 DK. BLE examples require a softdevice, and the directories will be named s1xx/s2xx/s3xx, depending on which chip is used and which protocols are supported in the example.
Jørgen
could you please explain what is the use case of having the blinky example with MBR? (since MBR is used to update the bootloader/softdevice).
Thank you.
It is just an example showing how to have the MBR present without using the Softdevice. Examples of this use-case is for instance DFU/bootloader over other wireless protocols, like Thread or Zigbee.
