Cannot Pair with Vendor UUID using Central device
 I am using SDK 15.2 with softdevice 140 on nrf52840 board. I have been trying to get the development board to pair with a peripheral sensor with UUID "E7D4AA0F-5ACB-55C0-B177-A07D4525E1FA". I've been looking at the ble_app_uart_c example to see how to best do this. I have tried replacing the line with the original nus_base_uuid with this:
//#define NUS_BASE_UUID                   {{0x9E, 0xCA, 0xDC, 0x24, 0x0E, 0xE5, 0xA9, 0xE0, 0x93, 0xF3, 0xA3, 0xB5, 0x00, 0x00, 0x40, 0x6E}} /**< Used vendor specific UUID. */
#define NUS_BASE_UUID                   {{0xFA, 0xE1, 0x25, 0x45, 0x7D, 0xA0, 0x77, 0xB1, 0xC0, 0x55, 0xCB, 0x5A, 0x0F, 0xAA, 0xD4, 0xE7}} /**< Used vendor specific UUID. */
 From what I've read about the pairing process, this should pair with my peripheral using this example, is that not correct? I can successfully pair with my peripheral using a phone that has the nrf_connect app or the lightblue app and see all the characteristics as well as being able to write/read from/to them.
I have paired with other devices in the past through the multilink example using their names however that has not worked with this one. I have also used some of the search functions such as ble_advdata_name_find(p_gap_evt->params.adv_report.data.p_data, p_gap_evt->params.adv_report.data.len , "VitalgramBLE #35015"  ) however i cannot find the name or the uuid in the advertisement packets.
The device is clearly advertising however I cannot seem to find it.
Any ideas?
Gian
    If the UUID filter is correctly configured, it should connect. But, the ble_app_uart and ble_app_uart_c examples does not use the peer manager, so pairing/bonding is by default not supported for these examples.
    Try setting the BLE_UUID_NUS_SERVICE in ble_nus_c.h to 0xAA0F
    #define BLE_UUID_NUS_SERVICE            0xAA0F                      /**< The UUID of the Nordic UART Service. */
  • Sigurd,
     I have changed the line as you suggested in the ble_nus_c.h file however nothing seems to be happening. The Scanning LED continues blink and scanning continues as normal.  It seems as if the central application is not even finding the device. I think this is true because I keep receiving  NRF_BLE_SCAN_EVT_NOT_FOUND within the scan event callback in the application.
    How should i proceed?
  • In addition, inside the BLE_GAP_EVT_ADV_REPORT event I added :
            if(ble_advdata_uuid_find(p_ble_evt->evt.gap_evt.params.adv_report.data.p_data, p_ble_evt->evt.gap_evt.params.adv_report.data.len, &m_nus_uuid))
              NRF_LOG_INFO("\n FOUND UUID OF VITALGRAM APP\n");
    However the code never finds the UUID. I'm thinking that something within the scan settings might not be correct.
  • Could it be that you have reversed the byte order of the UUID ?
    If a non-whitelisted 128bit UUID is found in the event NRF_BLE_SCAN_EVT_NOT_FOUND, you can print it like this:
    typedef struct
        uint8_t * p_data;   /**< Pointer to data. */
        uint16_t  data_len; /**< Length of data. */
    } data_t;
    #define N_AD_TYPES 2
    #define UUID128_SIZE    16  /**< Size of 128 bit UUID. */
    #include "ble_advdata.h"
    /**@brief Function for handling Scanning Module events.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        ret_code_t err_code;
        data_t   adv_data;
        // Initialize advertisement report for parsing
        adv_data.p_data   = (uint8_t *) p_scan_evt->params.p_not_found->data.p_data;
        adv_data.data_len = p_scan_evt->params.p_not_found->data.len;
        uint16_t        data_offset = 0;
        uint8_t         ad_types[N_AD_TYPES];
        uint8_t       * p_parsed_uuid;
        uint16_t        parsed_uuid_len = adv_data.data_len;
        uint8_t   uuid_buffer[UUID128_SIZE];
        switch(p_scan_evt->scan_evt_id)
             case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                  err_code = p_scan_evt->params.connecting_err.err_code;
             } break;
             case NRF_BLE_SCAN_EVT_CONNECTED:
                  ble_gap_evt_connected_t const * p_connected =
                                   p_scan_evt->params.connected.p_connected;
                 // Scan is automatically stopped by the connection.
                 NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                          p_connected->peer_addr.addr[0],
                          p_connected->peer_addr.addr[1],
                          p_connected->peer_addr.addr[2],
                          p_connected->peer_addr.addr[3],
                          p_connected->peer_addr.addr[4],
                          p_connected->peer_addr.addr[5]
             } break;
             case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
                 NRF_LOG_INFO("Scan timed out.");
                 scan_start();
             } break;
             case NRF_BLE_SCAN_EVT_NOT_FOUND:
                ad_types[0] = BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_COMPLETE;
                ad_types[1] = BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_MORE_AVAILABLE;
                for (uint8_t i = 0; (i < N_AD_TYPES) && (data_offset == 0); i++)
                    parsed_uuid_len = ble_advdata_search(adv_data.p_data, adv_data.data_len, &data_offset, ad_types[i]);
                if (data_offset == 0 )
                    // Could not find any relevant UUIDs in the encoded data.
                    return;
                p_parsed_uuid = &adv_data.p_data[data_offset]; //The UUID we found
                //Copy the UUID to our list of devices
                memset(uuid_buffer,0,UUID128_SIZE);
                memcpy(uuid_buffer, p_parsed_uuid, parsed_uuid_len);
                 NRF_LOG_INFO("Device-addr %02x:%02x:%02x:%02x:%02x:%02x",
                 p_scan_evt->params.p_not_found->peer_addr.addr[5],
                 p_scan_evt->params.p_not_found->peer_addr.addr[4],
                 p_scan_evt->params.p_not_found->peer_addr.addr[3],
                 p_scan_evt->params.p_not_found->peer_addr.addr[2],
                 p_scan_evt->params.p_not_found->peer_addr.addr[1],
                 p_scan_evt->params.p_not_found->peer_addr.addr[0]
                NRF_LOG_INFO("Hexdump:");
                NRF_LOG_HEXDUMP_INFO(p_parsed_uuid,parsed_uuid_len);
  • Sigurd,
     This has been very helpful. I think we are getting closer. Using the code you provided I can see the UUID of the device i want to pair with being printed to the terminal. I am guessing this means that the device is not being white-listed correctly with the filter. So this has to do with a filtering issue? What can i do to have this 128 bit UUID successfully white-listed and found by the scanner and then paired with?
