Basic SPI reads and writes
I have a SPI peripheral connected to the nRF960 DK. In order to access this correctly, I need to be able to write a byte to a specific address first and then read back from specific addresses.
I can run the basic SPI example
https://github.com/Rallare/fw-nrfconnect-nrf/tree/nrf9160_samples/samples/nrf9160/spi
which carries out a basic loop back. This all works fine but I can't see how to write a specific byte to a specific address or read a specific address.
So, ideally I would like to write 0xD2 to address 0x80, wait 1 second and then read data from address 0x00.
Can you point me to a simple example please?
Ta,
Rod
  • Hello Rod,
    The SPI example you are using is the only one we have at the moment. The example is using the built-in SPI functions of the Zephyr project, perhaps you are able to find what you are looking for in the Zephyr samples? Also, have a look at the Zephyr SPI API and the SPI header file.
    Ref. similar answer given by my colleague Jan Tore here.
    Øyvind
  • Hi Øyvind,
    I went back to the reply from Jan Tore on the ticket here. I realised that the BME280 has both an I2C and an SPI interface. So, I thought if I can get this sensor working over SPI and I can then try and migrate it to my own SPI sensor.
    I have successfully connected and ran the BME280 sensor over I2C. I am now trying to access this over SPI.
    Im using the sample given here,
    https://github.com/zephyrproject-rtos/zephyr/blob/master/samples/sensor/bme280/src/main.c
    I have set up SPI in my overlay file as suggested by Jan in the other ticket.
     * Copyright (c) 2018 Linaro Limited
    &i2c2 {
            status = "ok";
            sda-pin = <1>;
            scl-pin = <0>;
            clock-frequency = <I2C_BITRATE_FAST>;
    &spi3 {
            status = "ok";
    	sck-pin = <10>;
    	mosi-pin = <11>;
    	miso-pin = <12>;
    	ss-pin = <13>;
    	spi-max-frequency = <8000000>;
    	bme280@0 {
    		compatible = "bosch,bme280";
    		reg = <0>;
    		label = "BME280";
    and also I have enabled SPI in my conf file
    CONFIG_CONSOLE_SUBSYS=y
    CONFIG_CONSOLE_GETCHAR=y
    CONFIG_GPIO=y
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_SERIAL=y
    CONFIG_TEST_RANDOM_GENERATOR=y
    CONFIG_I2C=y
    CONFIG_SENSOR=y
    CONFIG_NET_BUF_USER_DATA_SIZE=1
    CONFIG_LOG=n
    CONFIG_LOG_DEFAULT_LEVEL=4
    CONFIG_HEAP_MEM_POOL_SIZE=1024
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_NEWLIB_LIBC=y
    # SPI
    CONFIG_SPI=y
    CONFIG_SPI_3=y
    CONFIG_SPI_3_NRF_SPIM=y
    CONFIG_BME280=y
    CONFIG_SPI_NRFX=y
    However, I get an error
    Secure Boot: MSP_NS 200216b0
    Secure Boot: prepare to jump to Non-Secure image
    ***** Booting Zephyr OS v1.13.99-ncs1-5561-gde69d2df908f *****
    Exception occurred in Secure State
    ***** HARD FAULT *****
      Fault escalation (see below)
    ***** BUS FAULT *****
      Precise data bus error
      BFAR Address: 0x50008120
    ***** Hardware exception *****
    Current thread ID = 0x20020154
    Faulting instruction address = 0x41f98
    Fatal fault in ISR! Spinning...
    Any thoughts?
  • Hello Rod,
    My apologies for the late reply, your question went under my radar for some reason.
    Can you tell me what version of the nRF Connect SDK you are running?
    In your prj.conf file, if not there, can you please add:
    Øyvind
  • Hi Øyvind,
    No problem.
    I have version 2.6.2 installed but am not using it directly. I use cmake and ninja for building code and programming.
    I have this entry in my pro.conf file, here is the full file
    CONFIG_GPIO=y
    CONFIG_SERIAL=y
    CONFIG_I2C=y
    CONFIG_SENSOR=y
    CONFIG_LOG=n
    # SPI
    CONFIG_SPI=y
    CONFIG_SPI_3=y
    CONFIG_BME280=y
    CONFIG_SPI_NRFX=y
    Rod
  • Hi Rod,
    Sorry, our naming convention can be a little confusing. nRF Connect (for desktop) 2.6.2 is not what I mean here, but it can be used to install NCS. nRF Connect SDK (NCS) is either (git tag) v0.3.0 or (git) master branch (0.3.99). Where the former is installed as described in the Getting Started guide and the latter is usually installed using west (but does not work in SES).
    Can you please try to remove either the i2c or spi config from the overlay with corresponding CONFIG from prj.conf? This to see if there is anything wrong with the configuration
