Basic SPI reads and writes
I have a SPI peripheral connected to the nRF960 DK. In order to access this correctly, I need to be able to write a byte to a specific address first and then read back from specific addresses.
I can run the basic SPI example
https://github.com/Rallare/fw-nrfconnect-nrf/tree/nrf9160_samples/samples/nrf9160/spi
which carries out a basic loop back. This all works fine but I can't see how to write a specific byte to a specific address or read a specific address.
So, ideally I would like to write 0xD2 to address 0x80, wait 1 second and then read data from address 0x00.
Can you point me to a simple example please?
Ta,
Rod
    I tried the update as detailed above, all seemed to work fine but my code does not compile.
    Watts-MacBook-Pro:build Watt$ cmake -GNinja -DBOARD=nrf9160_pca10090  ..
    -- Using application from '/Users/Watt/Documents/Switch_That/Nordic_Semi_Code/SPI_Test'
    Zephyr version: 1.14.99
    CMake Warning at /Users/Watt/zephyrproject/ncs/zephyr/cmake/app/boilerplate.cmake:196 (message):
      The build directory must be cleaned pristinely when changing boards
      CMakeLists.txt:3 (include)
    -- Selected BOARD nrf9160_pca10090ns
    -- Found west: /usr/local/bin/west (found suitable version "0.5.8", minimum required is "0.5.6")
    -- Cache files will be written to: /Users/Watt/Library/Caches/zephyr
    -- Loading /Users/Watt/zephyrproject/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
    -- Overlaying /Users/Watt/zephyrproject/ncs/zephyr/dts/common/common.dts
    -- Overlaying /Users/Watt/Documents/Switch_That/Nordic_Semi_Code/SPI_Test/nrf9160_pca10090ns.overlay
    nrf9160_pca10090ns.dts.pre.tmp:258.19-264.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
    Parsing Kconfig tree in /Users/Watt/zephyrproject/ncs/zephyr/Kconfig
    Loading /Users/Watt/Documents/Switch_That/Nordic_Semi_Code/SPI_Test/build/zephyr/.config as base
    Configuration written to '/Users/Watt/Documents/Switch_That/Nordic_Semi_Code/SPI_Test/build/zephyr/.config'
    Including module: nrf in path: /Users/Watt/zephyrproject/ncs/nrf
    -- Using application from '/Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/spm'
    Changed board to secure nrf9160_pca10090 (NOT NS)
    -- Loading /Users/Watt/zephyrproject/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090.dts as base
    -- Overlaying /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/spm/nrf9160_pca10090.overlay
    nrf9160_pca10090.dts.pre.tmp:120.18-126.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/uart@a000: duplicate unit-address (also used in node /soc/peripheral@50000000/i2c@a000)
      also defined at nrf9160_pca10090.dts.pre.tmp:512.8-514.3
    nrf9160_pca10090.dts.pre.tmp:260.19-266.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@50000000/power@5000)
    Loading /Users/Watt/Documents/Switch_That/Nordic_Semi_Code/SPI_Test/build/spm/zephyr/.config as base
    Configuration written to '/Users/Watt/Documents/Switch_That/Nordic_Semi_Code/SPI_Test/build/spm/zephyr/.config'
    Including module: mcuboot in path: /Users/Watt/zephyrproject/ncs/mcuboot/zephyr
    Including module: tinycbor in path: /Users/Watt/zephyrproject/ncs/modules/lib/tinycbor
    Including module: nrfxlib in path: /Users/Watt/zephyrproject/ncs/nrfxlib
    -- Configuring done
    CMake Error at /Users/Watt/zephyrproject/ncs/zephyr/cmake/extensions.cmake:423 (add_library):
      Cannot find source file:
        src/main.c
      Tried extensions .c .C .c++ .cc .cpp .cxx .cu .m .M .mm .h .hh .h++ .hm
      .hpp .hxx .in .txx
      /Users/Watt/zephyrproject/ncs/zephyr/cmake/app/boilerplate.cmake:554 (zephyr_library_named)
      /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/spm/CMakeLists.txt:3 (include)
      No SOURCES given to target: spm_app
    -- Build files have been written to: /Users/Watt/Documents/Switch_That/Nordic_Semi_Code/SPI_Test/build
    So then I tried a clean install....
    Watts-MacBook-Pro:ncs Watt$ west init -m https://github.com/NordicPlayground/fw-nrfconnect-nrf --mr v0.4.0
    West already initialized. Aborting.
  • Hi Rod,
    This is not making any sense. There is clearly an issue with your NCS install, but I am not fully able to reproduce the issue. There seems to be an issue with your path, from what I was able to reproduce.
    Please follow the next steps. They will be divided into 3 sections, each tackling in a different way.
    The first thing to try, if you were able to update the nrf repo and run west update:
    In your application: /Users/Watt/Documents/Switch_That/Nordic_Semi_Code/SPI_Test do you have a CmakeCache.txt? (Not the one in the build folder)
    If so, please delete this and the build folder. Then to ensure the correct path, please run:
    Run NCS/Zephyr/zephyr-env.sh
    Then try to make a new build folder and run:
    cmake -GNinja -DBOARD=nrf9160_pca10090ns ..
    The second thing to try, as you are getting "West already initialized. Aborting.":
    The clean install needs to be in a completely new folder. Please make a new folder with a completely new name e.g. NCS2, etc.
    mkdir NCS2 && cd NCS2
    west update
    To ensure the correct path, run:
    NCS2/Zephyr/zephyr-env.sh
    Then try to program NCS2\nrf\samples\nrf9160\at_client, without changing the code to ensure everything works that way.
    The third thing is that you send me your project so that I can test it here.
    If anything is unclear, let me know.
    Øyvind
  • Hi Øyvind,
    Ok, I have gone though your steps as above.
    1. I deleted CmakeCache.txt and ran zephyr-env.sh. When I tried to build, I get the same error as above.
    2. I tried a complete new install. But as you will see from below, I still get the "West already initialised" error
    Watts-MacBook-Pro:zephyrproject Watt$ mkdir NCS2
    Watts-MacBook-Pro:zephyrproject Watt$ cd NCS2
    Watts-MacBook-Pro:NCS2 Watt$ west init -m https://github.com/NordicPlayground/fw-nrfconnect-nrf --mr v0.4.0
    3. I don't think its my code, to prove this I tried to build at_client. I get the same error
    Watts-MacBook-Pro:nrf9160 Watt$ cd at_client/
    Watts-MacBook-Pro:at_client Watt$ ls
    CMakeLists.txt	prj.conf	sample.yaml	src
    Watts-MacBook-Pro:at_client Watt$ mkdir build
    Watts-MacBook-Pro:at_client Watt$ cd build/
    Watts-MacBook-Pro:build Watt$ cmake -GNinja -DBOARD=nrf9160_pca10090ns ..
    -- Using application from '/Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/at_client'
    -- Found PythonInterp: /usr/local/bin/python3 (found suitable version "3.7.3", minimum required is "3.4")
    Loading /Users/Watt/zephyrproject/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns_defconfig as base
    Merging /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/at_client/prj.conf
    Configuration written to '/Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/at_client/build/zephyr/.config'
    -- The C compiler identification is GNU 7.3.1
    -- The CXX compiler identification is GNU 7.3.1
    -- Found assembler: /Users/Watt/gnuarmemb/bin/arm-none-eabi-gcc
    -- Performing Test toolchain_is_ok
    -- Performing Test toolchain_is_ok - Success
    Loading /Users/Watt/zephyrproject/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090_defconfig as base
    Merging /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/spm/prj.conf
    Configuration written to '/Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/at_client/build/spm/zephyr/.config'
    CMake Warning at /Users/Watt/zephyrproject/ncs/zephyr/CMakeLists.txt:1523 (message):
            --- WARNING:  __ASSERT() statements are globally ENABLED ---
            --- The kernel will run more slowly and use more memory  ---
    -- Configuring done
        src/main.c
      .hpp .hxx .in .txx
      ../spm/CMakeLists.txt:3 (include)
    -- Build files have been written to: /Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/at_client/build
    So, I think i need to carry out a complete reinstall but it won't seem to let me do this simply my creating a new NCS2 directory.
    How can I do a clean install?
    Rod
  • Hi Rod,
    Really sorry for this being so difficult to fix, I have not seen similar issues.
     You need to find a folder named .west on your computer. This folder is generated when initializing west. Try to find this folder and delete it to see if this has any impact.
    I am discussing the issue in my team and will get back to you asap.
    Øyvind
  • Hi Øyvind,
    I got this working but not 100% sure what actually did the trick. Based on this thread "
    nRF9160 at_client sample project"
    i deleted my path and env variables.
    I then ran this again..
    pip3 install -r zephyr/scripts/requirements.txt
    pip3 install -r nrf/scripts/requirements.txt
    pip3 install -r mcuboot/scripts/requirements.txt
    as well as the update as above. Something did the trick and it burst into life.
    So,  I can no generate a merged.hex file and my code complies and runs. Unfortunately, my basic SPI reads and writes still dont work but at least I am now running on SPM
    Rod
