I like to convert private key to code.
  I generate a private key by using nrfutil.
  I like to convert raw data format to use in the code from private key.
  Additionally, I already used a nrf_crypto_ecc_key_pair_generate() function to generate private key.
  But, I don't  know how to convert a format to use it on PC.
  Any way( private key(*.pem) to code or Key generated from board to PC)  is Okay.
   Please, help me out to resolve this conversion issue.
     Chongchun Moon
PS C:\work\E-ciga\dfu> nrfutil keys display --key sk --format hex .\test.pem
WARNING: Security risk! Do not share the private key.
Private (signing) key sk:
6a72e923fa15c81782c90a02f6c7e9755d4509c5d9be16e5f9f2830fae7754dc
     I just use example(examples\crypto\nrf_crypto\ecdsa) in the SDK
     And, I just replaced private key and public key on that example as my previous comment.
     So, I believe I am using same hash and generation procedure for signature is no problem.
     Anyway,  code is attached as below.
    /** @brief Alice signs the message.
    static void alice_sign()
        static nrf_crypto_ecc_private_key_t alice_private_key;
        ret_code_t                          err_code = NRF_SUCCESS;
        NRF_LOG_INFO("Alice's signature generation");
        // Alice converts her raw private key to internal representation
        err_code = nrf_crypto_ecc_private_key_from_raw(&g_nrf_crypto_ecc_secp256r1_curve_info,
                                                       &alice_private_key,
                                                       m_alice_raw_private_key,
                                                       sizeof(m_alice_raw_private_key));
        DEMO_ERROR_CHECK(err_code);
        // Alice generates signature using ECDSA and SHA-256
        m_signature_size = sizeof(m_signature);
        err_code = nrf_crypto_ecdsa_sign(NULL,
                                         &alice_private_key,
                                         m_hash,
                                         sizeof(m_hash),
                                         m_signature,
                                         &m_signature_size);
        // Alice can now send the message and its signature to Bob
        print_hex("Alice's message hash: ", m_hash, sizeof(m_hash));
        print_hex("Alice's signature: ", m_signature, m_signature_size);
        // Key deallocation
        err_code = nrf_crypto_ecc_private_key_free(&alice_private_key);
    You can check if the signature you generate using the private key in your code match with the signature generated by nrfutil.
    How can I check the signature? Please help me out to do it.
    Could you tell me private key conversion as below is correct?
      Private key generation :
     b954ae7fea6910692bd6879072074ea1519676922f11984290f2f24ddb104904
     Private key conversion :
    static uint8_t m_alice_raw_private_key[] =
        0xb9, 0x54, 0xae, 0x7f, 0xea, 0x69, 0x10, 0x69,
        0x2b, 0xd6, 0x87, 0x90, 0x72, 0x07, 0x4e, 0xa1,
        0x51, 0x96, 0x76, 0x92, 0x2f, 0x11, 0x98, 0x42,
        0x90, 0xf2, 0xf2, 0x4d, 0xdb, 0x10, 0x49, 0x04,
      Chongchun Moon
  • Hi Moon,
    Ok so you just want to try encrypt a message using the same private key and public key generated by nrfutil.
    I will try to test here and let you now if it works.
      Is there any update for this?
      Chongchun Moon
  • Hi Moon,
    I'm really sorry for the late response. I was out of office in the last 2 weeks. I tried to test what you wanted to do and had the same issue. I have contacted our team to find the reason why it didn't work but haven't got the solution yet.
    I will try to push this. Will update you if I have any response from the team.
