I like to convert private key to code.
  I generate a private key by using nrfutil.
  I like to convert raw data format to use in the code from private key.
  Additionally, I already used a nrf_crypto_ecc_key_pair_generate() function to generate private key.
  But, I don't  know how to convert a format to use it on PC.
  Any way( private key(*.pem) to code or Key generated from board to PC)  is Okay.
   Please, help me out to resolve this conversion issue.
     Chongchun Moon
PS C:\work\E-ciga\dfu> nrfutil keys display --key sk --format hex .\test.pem
WARNING: Security risk! Do not share the private key.
Private (signing) key sk:
6a72e923fa15c81782c90a02f6c7e9755d4509c5d9be16e5f9f2830fae7754dc
  • Hi Hung Bui,
       Okay. Thanks for response.
       Chongchun Moon
  • Hi Moon,
    I'm really sorry for the dragging of the case. We found the issue. When generating by nrfutil, the endianess needed to be swapped. But the private key SK is only one entity when the public key are 2 entities.
    So the private key need to be swapped once when the public key need to be double swapped:
    For SK:  nrf_crypto_internal_swap_endian(sk_copy, sk, sizeof(sk) );
    For PK:     nrf_crypto_internal_double_swap_endian(pk_copy, pk, sizeof(pk) / 2);
    I attached here the ecdsa example that I used the keys generated by nrfutil to test:
     * Copyright (c) 2018 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
     * @defgroup nrf_crypto_ecdsa_example
     * @ingroup nrf_crypto_ecdsa
     * @brief ECDSA Example Application main file.
     * This file contains the source code for a sample application that demonstrates using the
     * nrf_crypto library to do ECDSA signature generation and verification. Different backends can be
     * used by adjusting @ref sdk_config.h accordingly.
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #include "sdk_common.h"
    #include "nrf_assert.h"
    #include "app_error.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_crypto.h"
    #include "nrf_crypto_ecc.h"
    #include "nrf_crypto_error.h"
    #include "nrf_crypto_ecdsa.h"
    #include "mem_manager.h"
    #include "nrf_crypto_shared.h"
    /** @brief SHA-256 hash digest of the message "Hello bob!
     * @note If you need to calculate a hash digest from message, please use
     *       @ref nrf_crypto_hash.
    static uint8_t m_hash[] =
        // SHA256("Hello Bob!")
        0x42, 0xba, 0x83, 0x54, 0xdb, 0x26, 0x3a, 0x6a,
        0x5a, 0x9f, 0x74, 0xd6, 0xb7, 0xce, 0xb4, 0xc9,
        0x62, 0xa3, 0xd8, 0xfd, 0x58, 0xa4, 0x19, 0x69,
        0xe5, 0x21, 0xeb, 0x02, 0x22, 0x45, 0x54, 0x15,
    /** @brief Signature that Alice will generate and Bob will later verify.
    static nrf_crypto_ecdsa_secp256r1_signature_t m_signature;
    /** @brief Size of the signature generated by Alice.
    static size_t m_signature_size;
    //======================================== Print functions ========================================
    // Utility functions used to print results generated in this examples.
    static void print_array(uint8_t const * p_string, size_t size)
        #if NRF_LOG_ENABLED
        size_t i;
        NRF_LOG_RAW_INFO("    ");
        for(i = 0; i < size; i++)
            NRF_LOG_RAW_INFO("%02x", p_string[i]);
        #endif // NRF_LOG_ENABLED
    static void print_hex(char const * p_msg, uint8_t const * p_data, size_t size)
        NRF_LOG_INFO(p_msg);
        print_array(p_data, size);
        NRF_LOG_RAW_INFO("\r\n");
    #define DEMO_ERROR_CHECK(error)     \
    do                                  \
        if (error != NRF_SUCCESS)       \
            NRF_LOG_ERROR("Error 0x%04X: %s", error, nrf_crypto_error_string_get(error));\
            APP_ERROR_CHECK(error);     \
    } while(0)
    //========================================= Alice's site =========================================
    // This part of an example contains implementation of Alice's site. Alice have predefined private
    // key which she needs to keep secret. She uses this private key to sign "Hello Bob!" message.
    /** @brief Predefined example private key.
     *  This private key contains some dummy data just to show the functionality. Is should never be
     *  placed in any practical usage. Is is not secure, because it is filled with ones (in HEX).
    static const uint8_t m_alice_raw_private_key[] =
        0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11, 0x11,  // This is an example. DO NOT USE THIS KEY!
    __ALIGN(4) const uint8_t sk[32] =
        0xcb, 0x4e, 0x8d, 0x48, 0xd8, 0x33, 0x97,
        0x5f, 0x34, 0x8a, 0xe6, 0x4d, 0x08, 0xdb, 0xa6,
        0x68, 0xa1, 0xc5, 0x42, 0x2b, 0x67, 0x2c, 0x4e,
        0x90, 0x9b, 0x8e, 0x87, 0xbb, 0x55, 0x03, 0x12, 0xfb
    /** @brief Alice signs the message.
    static void alice_sign()
    {     uint8_t    sk_copy[sizeof(sk)];
        static nrf_crypto_ecc_private_key_t alice_private_key;
        ret_code_t                          err_code = NRF_SUCCESS;
        NRF_LOG_INFO("Alice's signature generation");
        // Alice converts her raw private key to internal representation
        err_code = nrf_crypto_ecc_private_key_from_raw(&g_nrf_crypto_ecc_secp256r1_curve_info,
                                                       &alice_private_key,
                                                       sk_copy,
                                                       sizeof(sk));
        DEMO_ERROR_CHECK(err_code);
        // Alice generates signature using ECDSA and SHA-256
        m_signature_size = sizeof(m_signature);
        err_code = nrf_crypto_ecdsa_sign(NULL,
                                         &alice_private_key,
                                         m_hash,
                                         sizeof(m_hash),
                                         m_signature,
                                         &m_signature_size);
        // Alice can now send the message and its signature to Bob
        print_hex("Alice's message hash: ", m_hash, sizeof(m_hash));
        print_hex("Alice's signature: ", m_signature, m_signature_size);
        // Key deallocation
        err_code = nrf_crypto_ecc_private_key_free(&alice_private_key);
    //========================================== Bob's site ==========================================
    // This part of the example contains implementation of Bobs's site. Bob has a public generated from
    // Alice's private key. The public key is not secret and it could have been shared beforehand, by a
    // key-exchange scheme, or by using another authenticated message exchange.
    // He will use the public key it to verify authenticity of the message, i.e. check if the
    // message is actually from Alice.
    /** @brief Predefined example public key that is associated with example private key
     *  @ref m_alice_raw_private_key.
    static const uint8_t m_alice_raw_public_key[] =
        0x02, 0x17, 0xE6, 0x17, 0xF0, 0xB6, 0x44, 0x39,
        0x28, 0x27, 0x8F, 0x96, 0x99, 0x9E, 0x69, 0xA2,
        0x3A, 0x4F, 0x2C, 0x15, 0x2B, 0xDF, 0x6D, 0x6C,
        0xDF, 0x66, 0xE5, 0xB8, 0x02, 0x82, 0xD4, 0xED,
        0x19, 0x4A, 0x7D, 0xEB, 0xCB, 0x97, 0x71, 0x2D,
        0x2D, 0xDA, 0x3C, 0xA8, 0x5A, 0xA8, 0x76, 0x5A,
        0x56, 0xF4, 0x5F, 0xC7, 0x58, 0x59, 0x96, 0x52,
        0xF2, 0x89, 0x7C, 0x65, 0x30, 0x6E, 0x57, 0x94,
    __ALIGN(4) const uint8_t pk[64] =
        0x7a, 0x9f, 0xa8, 0xe8, 0xdc, 0xa2, 0x9f, 0xc8, 0xd5, 0x3f, 0x46, 0x96, 0xc9, 0xf6, 0x6f, 0xe2, 0x5a, 0x6e, 0xc0, 0x33, 0xe4, 0xc4, 0xc7, 0x86, 0xe6, 0xae, 0x5b, 0x11, 0x52, 0x25, 0x72, 0x4c,
        0x88, 0x10, 0xf1, 0x67, 0x72, 0x8e, 0x66, 0x90, 0xdc, 0x32, 0xbc, 0x41, 0x7d, 0x76, 0x4c, 0xdd, 0x0e, 0x00, 0x61, 0x70, 0x7b, 0x23, 0xf9, 0x96, 0x83, 0x68, 0xef, 0xf0, 0xcf, 0x87, 0x06, 0x97
    /** @brief Bob verifies the signature.
    void bob_verify()
        static nrf_crypto_ecc_public_key_t alice_public_key;
        uint8_t    pk_copy[sizeof(pk)];
        NRF_LOG_INFO("Bob's message verification");
        // Bob converts Alice's raw public key to internal representation
        err_code = nrf_crypto_ecc_public_key_from_raw(&g_nrf_crypto_ecc_secp256r1_curve_info,
                                                      &alice_public_key,
                                                      pk_copy,
                                                      sizeof(pk));
        // Bob verifies the message using ECDSA and SHA-256
        err_code = nrf_crypto_ecdsa_verify(NULL,
                                           &alice_public_key,
                                           m_hash,
                                           sizeof(m_hash),
                                           m_signature,
                                           m_signature_size);
        if (err_code == NRF_SUCCESS)
            NRF_LOG_INFO("Signature is valid. Message is authentic.");
        else if (err_code == NRF_ERROR_CRYPTO_ECDSA_INVALID_SIGNATURE)
            NRF_LOG_WARNING("Signature is invalid. Message is not authentic.");
        // Key deallocation
        err_code = nrf_crypto_ecc_public_key_free(&alice_public_key);
    //========================================= Example entry =========================================
    /** @brief Function for initializing the nrf log module.
    static void log_init(void)
    /** @brief Function for application main entry.
        log_init();
        NRF_LOG_INFO("ECDSA example started.\r\n");
        err_code = nrf_mem_init();
        err_code = nrf_crypto_init();
        alice_sign();  // Alice signs the message
        bob_verify();  // Bob verifies the signature
        NRF_LOG_INFO("ECDSA example executed successfully.");
        for (;;)
    Here is the hex keys from nrfutil:
  • It works!
    Thank  you very much.
      Chongchun Moon
