Hei, får error på terminalen min etter jeg har lastet opp mqtt_simple. er det noe jeg gjør feil?
The MQTT simple sample started
LTE Link Connecting ...
LTE Link Connected!
IPv4 Address found 0x7135ab36
ERROR: mqtt_connect -60
mvh
Henning
LTE Link Connected!
mvh
Henning
Error 60 sounds like ETIMEDOUT from errno.h, which means that you time out when trying to connect. (I think that would be a connection to the mqtt broker.) Can you check that the IP address 0x7135ab36 (113.53.171.54) is correct?
Please note that we are entering Easter holidays in Norway. We will be back in office on Tuesday.
Terje
Okay, figured out that, that is an connect timedout. so if I understand correctly from u now, the IP address here is the address we try to connect too?
I thougth that this IP address was the address I get assign when connecting.
best
Henning
It seems the MQTT broker used in the example is no longer available for public usage. You should find another mqtt broker, and use that one in CONFIG_MQTT_BROKER_HOSTNAME.
Terje
