DFU not working
SDK 15.2 API 6.10 SES custom board
I am trying to get DFU to work and it is not seeming to work right.
I am trying to engage DFU mode by holding in button on board for 10-20 seconds. after releasing during allotted time i call enter_dfu_mode()
static void dfu_flash_cb(void *p_buf)
    uint32_t result = *((uint32_t*)p_buf);
    if(result == NRF_SUCCESS)
        NRF_LOG_DEBUG("resetting into DFU...\n");
        //blink the led 4x
        tb_led_blink(TLBX_LED_LOGO, 4, 500);
        NVIC_SystemReset();
        NRF_LOG_DEBUG("error 0x%x writing DFU settings\n");
static void enter_dfu_mode(void)
    NRF_LOG_DEBUG("writing dfu settings\n");
//    uint32_t err_code = sd_power_gpregret_clr(GPREGRET, BOOTLOADER_DFU_START);
//    APP_ERROR_CHECK(err_code);
    //write the bootloader settings and reset
    s_dfu_settings.enter_buttonless_dfu = true;
    (void)nrf_dfu_settings_write(dfu_flash_cb);
I am using the dfu secure_bootloader no changes to it
I added the buttonless dfu service, not sure if necessary considering my way of wanting to enter DFU mode, from the buttonless_dfu example.
When i call the function it does nothing. When i try and write to the settings nrf_dfu_settings_write returns the following
<error> nrf_fstorage: p_fs->p_api check failed in nrf_fstorage_erase() with value 0x8.
<warning> nrf_dfu_flash: nrf_fstorage_erase() failed with error 0x8.
<error> nrf_dfu_settings: Could not erase the settings page!
Is there something i am missing with how i want to do this or is there a method to enter DFU mode with a button press i have not seen in examples yet.
Also. Once in DFU mode. How do you reset the device either after OTA is complete or after 20sec of no transfer?
  • I got it to enter DFU mode. I modify the function to this
        uint32_t err_code;
        // Dsiconnect all BLE connections
        disconnect_all();                       //static function
        // Set DFU mode bit
        //NRF_POWER->GPREGRET = 0xB1;             // Non softdevice way
        err_code = sd_power_gpregret_set(GPREGRET_ID1, 0xB1);
        //Disable SoftDevice. It is required to be able to write to GPREGRET2 register (SoftDevice API blocks it).
        //GPREGRET2 register holds the information about skipping CRC check on next boot.
        err_code = nrf_sdh_disable_request();
        NVIC_SystemReset();
    Even though i enter DFU mode and connect. When i try and upload the compiled DFU .zip file created following this help site, https://devzone.nordicsemi.com/b/blog/posts/getting-started-with-nordics-secure-dfu-bootloader, It disconnects immediately. What would cause it to disconnect immediately? Here is my batch file which makes the DFU .zip file
    set APP_FILE=app
    set APP_FILE_LOC=Output\Release\Exe
    set SOFTDEVICE_LOC=sdk_nRF1520\components\softdevice\s132\hex
    set SOFTDEVICE=s132_nrf52_6.1.0_softdevice.hex
    set BOOTLOADER_LOC=secure_bootloader\pca10040_ble\ses\Output\Release\Exe
    set BOOTLOADER=secure_bootloader_ble_s132_pca10040.hex
    set OUTPUT_FILE_LOC=Output\Release
    @echo Preparing: nordic dfu settings file...
    nrfutil settings generate --family NRF52 --application %APP_FILE_LOC%\%APP_FILE%.hex --application-version 1 --bootloader-version 2 --bl-settings-version 1 %APP_FILE_LOC%\%APP_FILE%_bl_settings.hex
    mergehex --merge %APP_FILE_LOC%\%APP_FILE%.hex %APP_FILE_LOC%\%APP_FILE%_bl_settings.hex --output  %APP_FILE_LOC%\%APP_FILE%_app+bl_settings.hex
    @echo Preparing: nordic DFU zip
    nrfutil pkg generate --hw-version 52 --sd-req 0xAE --application-version 1 --application %APP_FILE_LOC%\%APP_FILE%.hex --key-file %APP_FILE_LOC%\..\..\..\keys\app_private_key.pem %OUTPUT_FILE_LOC%\%APP_FILE%_app_dfu_pkg.zip
    @echo merging softdevice, secure bootloader, bootloader settings and application...
    mergehex --merge %SOFTDEVICE_LOC%\%SOFTDEVICE% %BOOTLOADER_LOC%\%BOOTLOADER% %APP_FILE_LOC%\%APP_FILE%_app+bl_settings.hex --output  %OUTPUT_FILE_LOC%\%APP_FILE%_sd_app_bl.hex
  • :You are using the incorrect  --sd-req, you are setting it to 0xAE(S140 v6.1.0), but you should use 0xAF(s132_nrf52_6.1.0)
  • Ok, then please flash the debug bootloader ( nRF5_SDK_15.2.0_9412b96\examples\dfu\secure_bootloader\pca10040_ble_debug) and then post the debug log from when you perform a DFU.
  • I cannot figure ou thow to view the NRF_LOG_DEBUG output. I can view the NRF_LOG_INFO outputs, but how can i view the debug output. I am using SEGGER RTT Viewer to see th einfo an dtried starting debug logger but nothing is being recorded apart from NRF_LOG_INFO
