sd_ant_burst_handler_request() limit
according to the documenation, the function sd_ant_burst_handler_request() can return with the error code NRF_ANT_ERROR_MESSAGE_SIZE_EXCEEDS_LIMIT. When will the function return with this code, how should a caller cope with this response and is there a way to avoid this return code at all (for example limiting each chunk to a static compile time limit)?
kind regards,
Torsten
  • I haven't tested this myself, but could this question be helpful?
    I know you get NRF_ANT_ERROR_MESSAGE_SIZE_EXCEEDS_LIMIT from sd_ant_broadcast_message_tx() if you try to use a message size larger than 8, but with sd_ant_burst_handler_request() I get NRF_ANT_ERROR_INVALID_PARAMETER_PROVIDED. I have contacted ANT and will update when I hear from them.
    Edit 01.12.2014: NRF_ANT_ERROR_MESSAGE_SIZE_EXCEEDS_LIMIT should never be returned by sd_ant_burst_handler_request().
    The size provided must be a multiple of 8, or you will get NRF_ANT_ERROR_INVALID_PARAMETER_PROVIDED. You can actually provide the complete 1024 bytes array to sd_ant_burst_handler_request() and ANT will split the data and send it. With normal burst this will be in packets with a payload of 8 bytes. The payload can be increased by using the advanced burst, where the packets can have a payload up to 24 bytes. Please see the question linked to above.
  • No, not really. I'm going to implement a chunk size of 1024 and hope for the error code to never occure.
  • @Petter With wich sizes do you get NRF_ANT_ERROR_INVALID_PARAMETER_PROVIDED? I mean I want to burst data that's usually much greater in size than 8 bytes. Thank you!
