UART debug logging
I know that this question has been asked a few times, but I am a little desperate after trying to get debug logging over the Virtual COM Port to work. Here are the steps that I did:
  • I got myself a nRF51 USB Dongle (pca10031 board with nRF51422_xxAC chipset)
  • I configured a new Project in Keil with all the necessarey libraries and a 120 Soft Device
  • I wrote a main.c that toggles the onboard LED in an infinite loop and calls printf after each loop.
  • I called app_trace_init() at the beginning to set up the debug UART connection
From looking at the app_trace_init function I gathered, that the Baud rate is 115200, as opposed to the Baud rate stated in the documentation (38400). I think that flow control is hardware? (UART_FLOW_CONTROL_ENABLED).
I configured Putty to use 8 data bits, 1 stop bit, and varied all other parameters but to no avail. I can only get garbage characters, but at least the length seems to be similar to the string that I am trying to trace.
Could you please point me in the right direction?
Thanks, Marius Heil
  • hi,stian:
    when i test uart simple example, all is OK.. but when i test using app_trace_init() and app_trace_log(), i has the same question.. I can only get garbage characters...
    int main(void) {
    app_trace_init();
    while (1) {
    app_trace_log("a==B++\r\n"); }
    but the log messages are: +B=aaB==a+==a
    configuration: pca10028, APP_UART_FLOW_CONTROL_DISABLE, 38400, image description
    and I change to use app_uart_fifo.c for app_uart. and test again, the following is the result:
    Ba+=+= image description
  • hi, all: the code of SDK9.0, simple uart example and app_trace_init/ app_trace_log are the same after i check the code. why i get error message log, please add some time delay in the loop. ererything is OK. ..
