App timer triggering instantly
Development Software: SDK v15.3, IDE IAR v7.8, SoftDevice 6.1.1
Computer Platform: Windows
HW revisions: EYSHJNZWZ (nRF52832)
My application requires SPI and BLE working together. For BLE I've defined two application timers which gets instantiated at different points in time and works fine.
For scheduling SPI transaction I thought of creating a new app timer. But, as soon as I create another app timer, it gets triggered instantly I don't understand why. When there are only 2 timers, everything work fine, but adding one more timer is causing timer to elapse instantly.
As a workaround I've used RTC2 to generate repeated interrupt to schedule my SPI transactions, but why would APP timer behave this way?
Can you please help me with this?
 * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_app_template_main main.c
 * @ingroup ble_sdk_app_template
 * @brief Template project main file.
 * This file contains a template for creating a new application. It has the code necessary to wakeup
 * from button, advertise, get a connection restart advertising on disconnect and if no new
 * connection created go back to system-off mode.
 * It can easily be used as a starting point for creating a new application, the comments identified
 * with 'YOUR_JOB' indicates where and how you can customize.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_dis.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "fds.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "sensorsim.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "ble_cus.h"
#define START_RF                        1
#define SPI_MODULE                      1
#ifdef SPI_MODULE
#include "nrf_drv_spi.h"
#define DEVICE_NAME                     "Custom Service"                        /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "Siemens"                               /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                640                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION                18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
// Section to negotiate connection parameters-----------------------------------
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY                   0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
  An application timer that calls ble_cus_custom_value_update() at a regular
  interval and then start it when we get the BLE_CUS_EVT_NOTIFICATION_ENABLED
  event
//timeout interval of our application timer
#define NOTIFICATION_INTERVAL           APP_TIMER_TICKS(1000)
#define TIMER_INTERVAL                  APP_TIMER_TICKS(10000)
APP_TIMER_DEF(m_notification_timer_id);
APP_TIMER_DEF(m_update_connection_params);
#ifdef SPI_MODULE
    APP_TIMER_DEF(m_spi_transaction);
    #define SPI_INSTANCE            0
    static nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
    static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
    #define TEST_STRING "Nordic"
    static uint8_t       m_tx_buf[] = TEST_STRING;           /**< TX buffer. */
    static uint8_t       m_rx_buf[sizeof(TEST_STRING) + 1];    /**< RX buffer. */
    static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
    #define SPI_INTERVAL            20000
    #define SPI_SS_PIN              31
    #define SPI_MISO_PIN            30
    #define SPI_MOSI_PIN            29
    #define SPI_SCK_PIN             26
/* This code belongs in main.c*/
static uint8_t m_custom_value = 0;
NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                             /**< Advertising module instance. */
BLE_CUS_DEF(m_cus);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
/* YOUR_JOB: Declare all services structure your application is using
 *  BLE_XYZ_DEF(m_xyz);
// YOUR_JOB: Use UUIDs for service(s) used in your application.
static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
    {CUSTOM_SERVICE_UUID,                       BLE_UUID_TYPE_VENDOR_BEGIN},
    {BLE_UUID_DEVICE_INFORMATION_SERVICE,       BLE_UUID_TYPE_BLE},
    //{CUSTOM_SERVICE_UUID_TWO,                   BLE_UUID_TYPE_VENDOR_BEGIN+1}
static void advertising_start(bool erase_bonds);
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            advertising_start(false);
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
 *                       app_start_timer() call to the timeout handler.
static void notification_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    ret_code_t err_code;
    // Increment the value of m_custom_value before nortifing it.
    m_custom_value++;
    err_code = ble_cus_custom_value_update(&m_cus, m_custom_value);
static void notification_timeout_handler_2(void * p_context)
    ble_gap_conn_params_t  updated_conn_param;
    // Update in Connection parameters preferred by the application.
    updated_conn_param.min_conn_interval = MSEC_TO_UNITS(200, UNIT_1_25_MS);
    updated_conn_param.max_conn_interval = MSEC_TO_UNITS(400, UNIT_1_25_MS);
    updated_conn_param.slave_latency     = 1;
    updated_conn_param.conn_sup_timeout  = MSEC_TO_UNITS(6000, UNIT_10_MS);
    // Initialize and set-up connection parameter negotiation module.
    err_code = ble_conn_params_change_conn_params(m_conn_handle, &updated_conn_param);
    if(err_code == NRF_SUCCESS)
        // Procedure request succeeded. Connection parameters will be negotiated as requested.
        // BLE_CONN_PARAMS_EVT_SUCCEEDED will be notified if parameter negotiation is successful.
        // Procedure request failed.
#ifdef SPI_MODULE
static void notification_timeout_handler_3(void * p_context)
    uint32_t counter;
    counter = app_timer_cnt_get();
    memset(m_rx_buf, 0, m_length);
    spi_xfer_done = false;
    err_code = nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    // Create timers.
    err_code = app_timer_create(&m_notification_timer_id, APP_TIMER_MODE_REPEATED, notification_timeout_handler);
    err_code = app_timer_create(&m_update_connection_params, APP_TIMER_MODE_SINGLE_SHOT, notification_timeout_handler_2);
#ifdef SPI_MODULE
    err_code = app_timer_create(&m_spi_transaction, APP_TIMER_MODE_SINGLE_SHOT, notification_timeout_handler_3);
    // Create timers.
    /* YOUR_JOB: Create any timers to be used by the application.
                 Below is an example of how to create a timer.
                 For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
                 one.
       err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
       APP_ERROR_CHECK(err_code); */
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    ble_gap_conn_params_t       gap_conn_params;
    ble_gap_conn_sec_mode_t     sec_mode;
    ble_gap_privacy_params_t    prvt_conf;
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    /* YOUR_JOB: Use an appearance value matching the application's use case.
       err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_REMOTE_CONTROL);
    gap_conn_params.min_conn_interval   = MIN_CONN_INTERVAL;
    gap_conn_params.max_conn_interval   = MAX_CONN_INTERVAL;
    gap_conn_params.slave_latency       = SLAVE_LATENCY;
    gap_conn_params.conn_sup_timeout    = CONN_SUP_TIMEOUT;
    memset(&prvt_conf, 0, sizeof(prvt_conf));
    prvt_conf.privacy_mode              = BLE_GAP_PRIVACY_MODE_DEVICE_PRIVACY;
    prvt_conf.private_addr_type         = BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE;
    prvt_conf.private_addr_cycle_s      = 0;
    err_code = sd_ble_gap_privacy_set(&prvt_conf);
/**@brief GATT module event handler.
static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
                     p_evt->conn_handle,
                     p_evt->params.att_mtu_effective);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the YYY Service events.
 * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
 * @details This function will be called for all YY Service events which are passed to
 *          the application.
 * @param[in]   p_yy_service   YY Service structure.
 * @param[in]   p_evt          Event received from the YY Service.
static void on_yys_evt(ble_yy_service_t     * p_yy_service,
                       ble_yy_service_evt_t * p_evt)
    switch (p_evt->evt_type)
        case BLE_YY_NAME_EVT_WRITE:
            APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
            // No implementation needed.
/**@brief Function for handling the Custom Service Service events.
 * @details This function will be called for all Custom Service events which are passed to
 *          the application.
 * @param[in]   p_cus_service  Custom Service structure.
 * @param[in]   p_evt          Event received from the Custom Service.
static void on_cus_evt(ble_cus_t     * p_cus_service,
                       ble_cus_evt_t * p_evt)
    switch(p_evt->evt_type)
        case BLE_CUS_EVT_NOTIFICATION_ENABLED:
            err_code = app_timer_start(m_notification_timer_id, NOTIFICATION_INTERVAL, NULL);
        case BLE_CUS_EVT_NOTIFICATION_DISABLED:
            err_code = app_timer_stop(m_notification_timer_id);
        case BLE_CUS_EVT_CONNECTED:
        case BLE_CUS_EVT_DISCONNECTED:
    nrf_ble_qwr_init_t          qwr_init = {0};
    ble_cus_init_t              cus_init;
    ble_dis_init_t              dis_init;
    // Initialize CUS service init structure to zero
    memset(&cus_init, 0, sizeof(cus_init));
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.write_perm);
      In order to propagate events from our service we need to assign the
      on_cus_evt function as the event handler function of our service
      when we initialize the Custom Service
    cus_init.evt_handler        = on_cus_evt;
    err_code    = ble_cus_init(&m_cus, &cus_init);
    // Initialize Device Information Service.
    memset(&dis_init, 0, sizeof(dis_init));
    ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
    dis_init.dis_char_rd_sec    = SEC_OPEN;
    err_code                    = ble_dis_init(&dis_init);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
/**@brief Function for starting timers.
static void application_timers_start(void)
    /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
       err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
#ifdef SPI_MODULE
    err_code = app_timer_start(m_spi_transaction, SPI_INTERVAL, NULL);
    err_code = app_timer_start(m_update_connection_params, TIMER_INTERVAL, NULL);
    // Prepare wakeup buttons.
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    ret_code_t err_code = NRF_SUCCESS;
            NRF_LOG_INFO("Disconnected.");
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
 * @param[in]   event   Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
            break; // BSP_EVENT_SLEEP
        case BSP_EVENT_DISCONNECT:
            break; // BSP_EVENT_DISCONNECT
        case BSP_EVENT_WHITELIST_OFF:
            break; // BSP_EVENT_KEY_0
int8_t powerLevel               = 0;
    ble_advertising_init_t init;
    init.advdata.name_type                      = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance             = true;
    init.advdata.flags                          = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.p_tx_power_level               = &powerLevel;
    init.srdata.uuids_complete.uuid_cnt         = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.srdata.uuids_complete.p_uuids          = m_adv_uuids;
    init.config.ble_adv_fast_enabled            = true;
    init.config.ble_adv_fast_interval           = APP_ADV_INTERVAL;
    init.config.ble_adv_fast_timeout            = APP_ADV_DURATION;
    init.evt_handler                            = on_adv_evt;
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for changing the tx power.
static void tx_power_set(void)
    ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, powerLevel);
#ifdef SPI_MODULE
 * @brief SPI user event handler.
 * @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    spi_xfer_done = true;
    NRF_LOG_INFO("Transfer completed.");
    if (m_rx_buf[0] != 0)
        NRF_LOG_INFO(" Received:");
        NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
    NRF_LOG_FLUSH();
/**@brief Function for application main entry.
    bool erase_bonds;
    // Initialize.
    log_init();
    timers_init();
    nrf_gpio_cfg_output(MY_PIN);
    power_management_init();
    ble_stack_init();
    sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
#ifdef SPI_MODULE
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    spi_config.ss_pin   = SPI_SS_PIN;
    spi_config.miso_pin = SPI_MISO_PIN;
    spi_config.mosi_pin = SPI_MOSI_PIN;
    spi_config.sck_pin  = SPI_SCK_PIN;
    APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
    NRF_LOG_INFO("SPI example started.");
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("Template example started.");
    application_timers_start();
#ifdef START_RF
    advertising_start(erase_bonds);
    tx_power_set();
#else
    // Enter main loop.
    for (;;)
        while (!spi_xfer_done)
            idle_state_handle();
