HIGH CONSUMPTION UARTE1
I'm using NRF52840 module to make a customer device. This device send message by UART. My device is powered with a battery, for this reason I would like reduce the current consumption due to serial comunication.
I'm configuring serial port this way:
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte1_drv_config,
                      RX_PIN_NUMBER, TX_PIN_NUMBER,
                      RTS_PIN_NUMBER, CTS_PIN_NUMBER,
                      NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED,
                      NRF_UART_BAUDRATE_115200,
                      UART_DEFAULT_CONFIG_IRQ_PRIORITY);
#define SERIAL_FIFO_TX_SIZE 1024
#define SERIAL_FIFO_RX_SIZE 1024
NRF_SERIAL_QUEUES_DEF(serial1_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
#define SERIAL_BUFF_TX_SIZE 1
#define SERIAL_BUFF_RX_SIZE 1
NRF_SERIAL_BUFFERS_DEF(serial1_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
NRF_SERIAL_CONFIG_DEF(serial1_config, NRF_SERIAL_MODE_IRQ,
                      &serial1_queues, &serial1_buffs, rec_uart_handler, sleep_handler);
NRF_SERIAL_UART_DEF(serial1_uarte, 1);
What I use is '"nrf_serial_init', and, after reading, then '"nrf_serial_uninit' to close the serial port. I am working in IRQ mode. Before and after the FIRST 'init', the current is lower than 100uA. But after the first 'read' the current is about 1.5mA. And it never goes back to 100uA even if I 'uninit' the serial port.
I had tried also:
          NRF_UARTE1->TASKS_STOPRX = 1:
          NRF_UARTE1->TASKS_STOPTX = 1;
          NRF_UARTE1->ENABLE = 0;
But with no success.
Is there any function or macro, to get back to low power (<100uA) after the reading process?
Any help is wellcome. Thank you in advance.
Thank you!!!
  • Hi Edward
    What SDK are you using? There was an issue with UARTE not disabling properly in SDK v15.0.0 where the workaround posted here had to be implemented. This workaround should power cycle the peripheral after calling app_uart_close() and lower the current consumption. The workaround is thoroughly explained here if you have any initial questions.
    If this doesn't solve your problem, don't hesitate to tell me!
    Simon
  • Hi Simon!!
    I'm using nRF5 SDK for Thread v0.11.0.
    I saw that solution, and I tried it, this is the part of my code:
                          nrf_serial_uninit(&serial1_uarte);
                            *(volatile uint32_t *)0x40028FFC = 0;   // Power down UARTE1
                            *(volatile uint32_t *)0x40028FFC;       //
                            *(volatile uint32_t *)0x40028FFC = 1;   // Power on UARTE1 so it is ready
    I tried too this:
                          NRF_UARTE1->TASKS_STOPRX=1;
                          NRF_UARTE1->TASKS_STOPTX=1;
                          NRF_UARTE1->ENABLE=0;
    But it's not success, The consumption is the same.
    In this moment I don't know what can I try...
    Thank you in advance!
  • Hi Edward
    The SDK you are using is very old (older than the workaround I proposed), so first of all, I suggest you update to the newest Thread SDK v3.0.0, as I suspect just updating your SDK might be enough to solve the problem for you.
    Simon
  • Hi Simonr,
    At the end I updated the SDK and now I'm using nRF5 SDK for Thread and Zigbee v3.0.0 but I have the same problem more or less...
    I did three tests using UARTE1 (mode DMA):
    1º  When I write by UARTE1 but never read, the current is 0.3mA
    My code:
               ret = nrf_serial_init(&serial1_uarte, &m_uarte1_drv_config, &serial1_config);
         APP_ERROR_CHECK(ret);
         ret = nrf_serial_write(&serial1_uarte,&tx[2],tx[1],NULL,NRF_SERIAL_MAX_TIMEOUT);
        (void)nrf_serial_flush(&serial1_uarte, 0);
     //   memset(buffer_uartRx,0,sizeof(buffer_uartRx));
     //  while(nrf_serial_read(&serial1_uarte, &buffer_uartRx[tam_buffer_uartRx], 1, NULL, 10)==NRF_SUCCESS)
     //     tam_buffer_uartRx++;
    2º When I write and read without power down UARTE1, the current is 2.4mA
    My code:
       THE CURRENT IS 2.4mA
    3º When I write and read with power down UARTE1, the current is 1.7mA
    My code:
       while(nrf_serial_read(&serial1_uarte, &buffer_uartRx[tam_buffer_uartRx], 1, NULL, aux_tmp)==NRF_SUCCESS)
      THE CURRENT IS 1.7mA
      Also I tried to read only once at the beginning of my program and never read again but the current did'nt go down.   (1.7mA)
    So, when initiating the UARTE, writing to it, BUT not reading from it, the current is really low.
    But, just reading a single byte, the current increases more than 1mA. And never goes down again.
    How can we fix this, in our opinion, erroneous behaviour?
    Best regards
    Thank you!!!
  • Hi Edward
    Do you have the same problems when using the serial_uartes example provided in the SDK? What are you using to measure the current? Also, can you confirm that the values you are reading and writing are read and written correctly? And last, do you get an error code if you try going to sleep?
    Simon
