SWO signal inversion bug
OK - so I just started with these chips, and have been asked to find out why SWO debug signal is getting corrupted.
At fairly random intervals the signal passive state inverts from 0 to 1, which corrupts the next few lines of debug output until the passive state inverts back again.
I suspect a silicon bug, or a conflict between something like GPIO and the ITM, but wanted to start by double-checking the hardware configuration settings.
The SWO is configured as follows, but there are quite a few magic numbers in there.
//  brief Initialize the SWO trace port for debug message printing
//      param portBits Port bit mask to be configured
void SWO_Init(uint32_t portBits)
    uint32_t SWOSpeed = 57600; // baud rate
    uint32_t SWOPrescaler = (CPU_CORE_FREQUENCY_HZ / SWOSpeed) + 1; // SWOSpeed in Hz, note that CPU_CORE_FREQUENCY_HZ is expected to be match the CPU core clock
    CoreDebug->DEMCR = CoreDebug_DEMCR_TRCENA_Msk; // enable trace in core debug */
  *((volatile unsigned *)(ITM_BASE + 0x400F0)) = 0x00000002; // "Selected PIN Protocol Register": Select which protocol to use for trace output (2: SWO NRZ, 1: SWO Manchester encoding)
  *((volatile unsigned *)(ITM_BASE + 0x40010)) = SWOPrescaler; // "Async Clock Prescaler Register". Scale the baud rate of the asynchronous output
  *((volatile unsigned *)(ITM_BASE + 0x00FB0)) = 0xC5ACCE55; // ITM Lock Access Register, C5ACCE55 enables more write access to Control Register 0xE00 :: 0xFFC
  ITM->TCR = ITM_TCR_TraceBusID_Msk | ITM_TCR_SWOENA_Msk | ITM_TCR_SYNCENA_Msk | ITM_TCR_ITMENA_Msk; // ITM Trace Control Register
  ITM->TPR = ITM_TPR_PRIVMASK_Msk; // ITM Trace Privilege Register
  ITM->TER = portBits; // ITM Trace Enable Register. Enabled tracing on stimulus ports. One bit per stimulus port.
  *((volatile unsigned *)(ITM_BASE + 0x01000)) = 0x400003FE; // DWT_CTRL
  *((volatile unsigned *)(ITM_BASE + 0x40304)) = 0x00000100; // Formatter and Flush Control Register
So first question - anybody know where I can find the register definitions?
I followed this thread about SWO but it took me to the Infocenter, which has been deprecated and I cannot find a reference manual for the 52832
Thanks in advance
  • NickT said:
    it is used for runtime logging
     In the finished application, or for debugging? Have you considered using the RTT backend for the logger?
    Did you try Rick Chung's implementation (step 1-4) in the post that you linked to? Does that behave the same way as your implementation? (flipping the signal?)
  • Edvin,
    The previous engineer added the SWO_init code to the product to get a "uart" data stream available for application monitoring, even when there is no debugger connected.
    I don't believe RTT is available without Segger...but I may be wrong
    Rick's code seems to assume that SWO can be run at 4MHz, not 57600, but that might be a simple matter of setting the pre-scalar.
     That is correct. It doesn't look like it supports 57600Hz, if you look in the nrf52_bitfields.h on line 1228-1233.
     This should still be possible. You can use the UART to output data even if you only have 1 pin. You can use this as TX and not initialize the RX pin.
    If you look at the ble_app_uart example from the SDK, in the uart_init() function, try to comment out the pins that aren't used:
    static void uart_init(void)
            //.rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            //.rts_pin_no   = RTS_PIN_NUMBER,
            //.cts_pin_no   = CTS_PIN_NUMBER,
            .use_parity   = false,
    #if defined (UART_PRESENT)
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    I tested this and it throws a framing error in the UART event handler. Remember to comment out this:
                //APP_ERROR_HANDLER(p_event->data.error_communication);
    It is just tellling you that you have a framing error on the RX, which is not initialized, so that shouldn't be a concern.
    Using the UART, you can also set the baudrate you desire:
    .baud_rate    = NRF_UART_BAUDRATE_57600
    Edvin
  • Edvin,
    Thanks for the information about how to use the UART.
    Unfortunately that is not what we are trying to fix...on our hardware, the SWO pin is available on a connector, the UART pin is not.
    To recap,
    We have an implementation that uses the SWO in NRZ node (0xE00400F0 = 2)
    with a pre-scalar (0xE0040010 = 556) which generates a baud rate of 57600 (0.01% error) from the 32MHz TPIU sysclock.
    This works, we can connect a terminal to the SWO pin and "see" the internal log messages.  But it is unreliable - every so often the data is corrupted because the SWO inverts its passive state.
    What I am trying to discover is why the SWO does not behave reliably in this configuration.
    I hope that is clear now?
    I am sorry for the late reply. We have had public holiday in Nordic from Thursday until yesterday.
    I believe I understand. But you do not have a programming chip on the device, right? Do you use a debugger to monitor this SWO pin? You can set the UART pin to whatever pin you like, so I don't really see this limitation.
    Do you have a project file that I can run on a DK that can replicate this issue?
    BR,
    Edvin
