SWO signal inversion bug
OK - so I just started with these chips, and have been asked to find out why SWO debug signal is getting corrupted.
At fairly random intervals the signal passive state inverts from 0 to 1, which corrupts the next few lines of debug output until the passive state inverts back again.
I suspect a silicon bug, or a conflict between something like GPIO and the ITM, but wanted to start by double-checking the hardware configuration settings.
The SWO is configured as follows, but there are quite a few magic numbers in there.
//  brief Initialize the SWO trace port for debug message printing
//      param portBits Port bit mask to be configured
void SWO_Init(uint32_t portBits)
    uint32_t SWOSpeed = 57600; // baud rate
    uint32_t SWOPrescaler = (CPU_CORE_FREQUENCY_HZ / SWOSpeed) + 1; // SWOSpeed in Hz, note that CPU_CORE_FREQUENCY_HZ is expected to be match the CPU core clock
    CoreDebug->DEMCR = CoreDebug_DEMCR_TRCENA_Msk; // enable trace in core debug */
  *((volatile unsigned *)(ITM_BASE + 0x400F0)) = 0x00000002; // "Selected PIN Protocol Register": Select which protocol to use for trace output (2: SWO NRZ, 1: SWO Manchester encoding)
  *((volatile unsigned *)(ITM_BASE + 0x40010)) = SWOPrescaler; // "Async Clock Prescaler Register". Scale the baud rate of the asynchronous output
  *((volatile unsigned *)(ITM_BASE + 0x00FB0)) = 0xC5ACCE55; // ITM Lock Access Register, C5ACCE55 enables more write access to Control Register 0xE00 :: 0xFFC
  ITM->TCR = ITM_TCR_TraceBusID_Msk | ITM_TCR_SWOENA_Msk | ITM_TCR_SYNCENA_Msk | ITM_TCR_ITMENA_Msk; // ITM Trace Control Register
  ITM->TPR = ITM_TPR_PRIVMASK_Msk; // ITM Trace Privilege Register
  ITM->TER = portBits; // ITM Trace Enable Register. Enabled tracing on stimulus ports. One bit per stimulus port.
  *((volatile unsigned *)(ITM_BASE + 0x01000)) = 0x400003FE; // DWT_CTRL
  *((volatile unsigned *)(ITM_BASE + 0x40304)) = 0x00000100; // Formatter and Flush Control Register
So first question - anybody know where I can find the register definitions?
I followed this thread about SWO but it took me to the Infocenter, which has been deprecated and I cannot find a reference manual for the 52832
Thanks in advance
  • After much headscratching - another support site gave me this answer
    "When (Cortex M-series) target enters true low power mode (in the absence of debug connection) due to a sleep event and there is data in the ITM/TPIU that has not been flushed, then the data stream gets mangled with garbage due to what appears to be clock gating/changes when core transitions to sleep."
    After I disabled the sd_app_evt_wait() call in our project the SWO is 100% reliable as a uart output.
    With the debugger connected, the core does not transition to sleep so SWO functions correctly even with the call to sd_app_event_wait()
    As far as I can tell, there are no flags to say when the last character has been flushed from the FIFO, so we cannot hold off the call to sleep until all the characters have been sent.
    Moving on...
