Unhandled signal 17. Status: 0
Hello.
I'm working for a Zigbee networking project.I chose nRF52840 as the coordinator.The coordinator acts as a gateway to communicate with Zigbee 3.0 devices on the market that support HA 1.2.
I test the networking function through the nRF5SDKforThreadandZigbee20029775ac/examples/zigbee/experimental/cli/cli_agent_router.When nRF52840 accepted Micro Door Sensor 3323-C joined the network, the following problems arose:
<info> app: Unhandled signal 16. Status: 0
<info> app: Unhandled signal 2. Status: 0
<info> app: Unhandled signal 17. Status: 0
It looks like the device has joined the network, but it will exit in a few seconds.
The state will continue to cycle like this.
I used the advice on the forum:
zb_bdb_set_legacy_device_support(1); // To support legacy Zigbee device
comm_status = bdb_start_top_level_commissioning(ZB_BDB_NETWORK_STEERING);
ZB_COMM_STATUS_CHECK(comm_status);
or
zb_bdb_set_legacy_device_support(0); // To support legacy Zigbee device
But I find that nothing seems to have changed.
I would like to ask the Nordic developer team what I should do to solve this problem?
    Can you try to add the ZB_ZDO_SIGNAL_DEVICE_ANNCE event to your zboss_signal_handler() in main.c and see if it hits? Just addNRF_LOG_INFO("ZB_ZDO_SIGNAL_DEVICE_ANNCE"); to the event, and you should see whether it happens or not.
    Edvin
  • Yes, I've tried it. After adding ZB_ZDO_SIGNAL_DEVICE_ANNCE to Main.c,NRF_LOG_INFO ( "ZB_ZDO_SIGNAL_DEVICE_ANNCE") did happen.Because we see the "<info> app:unhandled signal 2."
    Status:0 "is actually ZB_ZDO_SIGNAL_DEVICE_ANNCE.
    I guess since we've seen ZB_ZDO_SIGNAL_DEVICE_ANNCE happen, is it possible to say that the Zigbee protocol version of the two devices is the same or compatible? The most important thing is that after a few seconds, we can see ZB_ZDO_SIGNAL_LEAVE_INDICATION, which is <info>app:unhandled SIGNAL 17. Status:0, this problem has prevented me from doing the next step.
    I don't know if you saw, but we recently released SDK for Thread And Zigbee v 3.0.0.
    Can you (in your current implementation) please check the zb_zdo_signal_leave_indication_params_t.rejoin? Is it 0 or 1?
    What sort of device is your door sensor? Is it something that you have made? Does it require something specific that the CLI maybe haven't set up?
    BR,
    Edvin
