PWM moves the specified number of steps in nRF52832
I am try to create a PWM output which can move the specified number of steps.
Please find following source code
uint32_t		TotalMove = 0;
void pwm0_Manual_handler(nrf_drv_pwm_evt_type_t event_type)
	#define	StepCntInitial		2
	static	uint32_t		StepCnt = 0/*MotorInitializeStep*/;
	static	uint8_t			DebugPrint = 0;
	TotalMove++;
	if ( StepCnt-- == 0 )
		StepCnt = StepCntInitial;
		nrf_drv_pwm_stop(&m_pwm0, true);
	return;
void PwmInit_ManualRun(void)
	{	// Control PWM-0
		nrf_drv_pwm_config_t const config =
		    .output_pins =
		        PwmOutputPin | NRF_DRV_PWM_PIN_INVERTED,
		        2 | NRF_DRV_PWM_PIN_NOT_USED,
		        30 | NRF_DRV_PWM_PIN_NOT_USED,
		        28 | NRF_DRV_PWM_PIN_NOT_USED
		    .irq_priority = APP_IRQ_PRIORITY_LOWEST,
		    .base_clock   = NRF_PWM_CLK_16MHz,
		    .count_mode   = NRF_PWM_MODE_UP,
		    .top_value    = m_BaseFrequency,
		    .load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
		    .step_mode    = NRF_PWM_STEP_AUTO
		APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config, pwm0_Manual_handler));
		m_pwm0_set_value.channel_0 = m_BaseFrequency/2;
		m_pwm0_set_value.channel_1 = m_BaseFrequency/2;
		m_pwm0_set_value.channel_2 = m_BaseFrequency/2;
		m_pwm0_set_value.channel_3 = m_BaseFrequency/2;
		(void)nrf_drv_pwm_simple_playback(&m_pwm0, &m_pwm0_seq, 1, NRF_DRV_PWM_FLAG_LOOP);
		NRF_LOG_INFO("Use call-back: pwm0_Manual_handler");
After I execute above problem, I can get following wave form output.
First image is correct, and the second image is incorrect.
The second image include to many wave, but I only want send 2 waves output.
Would you please tell me how to fix this problem?
Thank you
