chnage adv name on push btn event
hi, i am doing a project where i have to change adv name of ble device.
i am using nrf sdk 15.3.0 ble_app_blinky example for pca 10040e because it has all the things i need ble adv name and push btn driver.
i have modified the code that app_button_enable();  will be always active.
so now on push btn event i have to change adv name of the device.
here is the code snippet which will be called by the push btn event handler and i also changed to GPIOTE_CONFIG_IN_SENSE_LOTOHI interrupt type.
void name_change(void)
    ret_code_t err_code;
    (void)sd_ble_gap_adv_stop(m_adv_handle);
                                            (const uint8_t *)DEVICE_NAME1,
                                             strlen(DEVICE_NAME1));
    advertising_init();
    advertising_start();
but problem which i am facing is that i am not able to change adv name which has more string length then the adv name which is previously advertised
for eg,
initial adv name is "blinky_test"
new adv name is "new_blinky_test"
then in this case the name is advertise as "new_blinky_"
but when i used shorter name then original adv name it worked fine but new problem is that when i go back to original adv name from here it is taking last adv name's length.
for eg.
new adv name is "new_blink"
if we go back to "blinky_test" then the new name which is adv is "blinky_te"
please help me to figure out what i am doing wrong.
