how is it possible to stop the uart modul after it was running?
Which perepherie is running after init the uart modul?
best regards Nils
best regards Nils
Hello Niis.
I think you means stop the uart receive/trasnmit operation by some cause, right?
If you set the register like below, you will be stop the uart.
NRF_UART0->STOP = 1
Thanks.
-yjpark
i have to stop all my modul which i doesn#t use in this moment for reducing the current in __WFI () mode.
So if i use NRF_UART0->STOP = 1, do i stop the uart modul an reduce the current?
Thank you :)
To turn off the UART peripheral, you have to set its ENABLE register to the Disabled value.
No.. this stops the uart but not the peripheral. The peripheral stays on and uses power. You need to disable it.
NRF_UART0->ENABLE = UART_ENABLE_ENABLE_Disabled;
