Debug messages from the custom board to be displayed on serial terminal
Dear Sir,
I am using nrf52832
SDK 15 and softdevice s132.
I have made a custom board using BMD300 module (nrf52832 based module).
I have takem the following pins outside VCC,GND , SWDIO and SWCLK.
I could flash the program to the board using nRFGo Studio and BMD300 DK( from Rigado) by using the following connection pattern
    Rigado BMD300 DK			External/Custom BMD300		    Voltage Source
	EXT_VTG<-----------------------> VCC <-------------------------->3.3V
	EXT_GND_DETECT <----------------> GND <------------------------->GND
	EXT_SWDIO<----------------------> SWDIO
	EXT_SWCLK<----------------------->SWCLK
	GND<------------------------------>GND
I have used NRF_LOG_INFO() function to display the debug messages on serial terminal and it works well  in the BMD300 DK.
I have flashed the same code to custom board.
But the I could NOT get the debug messages displayed on the serial terminal when I run the code on custom board.
Can I use the existing connection (using VCC<GND,SWDIO and SWCLK) to see the messages while running the code on custom board.?
Whether we need to make some changes in sdk_config.h file?
I was trying for this a long time ago.I have checked almost all the related posts , but I could not get a valid working procedure to make it work.
thanking you in advance.
with regards,
Geetha
