Hello team,
I'm working on system development using Mesh SDK and I have some questions so please let me know.
Development environment
IDE : Segger Embedded Stuido
SoC : nRF52840
SDK : Mesh v2.2.0
normal SDK v15.0.0
Base project : light switch example (modifying for our system)
1. If a node belonging to a group receives a message for that group address, which of the following will be performed first?
・Processing for messages, such as replies
・Transfer message to another node
・Anything else.
2. There is possiblity to rewrite the same variable in the receive callback of Mesh message and the timer interrupt handler, in main.c.
As such, I do not want to generate other interrupts during this process, includes receiving mesh messages.
How can I realize this?
Are the following functions and macros useful?
・CRITICAL_REGION_ENTER () / CRITICAL_REGION_EXIT ()
・nrf_mesh_disable () / nrf_mesh_enable ()
3. About interrupt
As far as the document is referred to, when the Mesh message is received during execution of the application interrupt process,
the application interrupt is interrupted and the Mesh reception interrupt is processed.
I think that system will return to the interrupted application interrupt after the processing of the reception interrupt is finished.
Is this recognition correct?
I will assume that it is correct and ask a question.
Is there a way to see this series of processes?
I put a loop processing with an end condition to make the waiting time in the timer interrupt handler.
I tried sending Mesh messages during looping, but the timer interrupt handler was not interrupted by the receipt of Mesh messages.
On the contrary, mesh message reception interrupt did not occur even after loop termination.
Does that mean that the system has not received a message?
Or did the system receive it but did not put the interrupt on hold?
The code in the timer interrupt handler is described below for reference.
void timer_handler(void * p_context) { __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "%s called.\n", __func__); for (uint8_t i = 100; i > 0; i--) { printf("loop %d\n", i); } }
Thanks in advance.
Wataru
