spi_mngr not working under SDK 15.2
going on with the migration from SDK 14.2 to SDK 15.3 it keeps on making trouble. Now the spi_mngr is not working anymore. After changing all calls to perform with extra NULL I am getting the error
error: 'NRFX_SPIMSPI_DS_INSTANCE_INST_IDX' undeclared here (not in a function)
Since I've already had a similar issue with the TWI manager I had to change the sdk_config and delete all parts of old SPI stuff. But if I run the exact same application I now get the error:
<error> app: ERROR 4 [NRF_ERROR_NO_MEM] nrf_spi_mngr_schedule
Although the queue size is exactly the same. Sorry but did some one of you already tested it?
Only if I run it with HIGH priority I can get it running while the performance (again exact same code) is only half as good as for the SDK 14.2.
I doubt that the spi_mngr uses the SPIM transfer. Am I correct? Is there a spi_mngr version with SPIM transfer? What do I need to change.
  • Further if change to SPI3 which should be available for the new SDK it directly hangs in the init routine. So I can initialize the manager but cannot send something.
    May you please share a code where I could reproduce an issue? I just tried our spi_mngr example and it worked fine.
  • #include <nrf_drv_gpiote.h>
    #include "peripheral_pin_map.h"
    #include "st7789v_register_pinmap.h"
    #include "st7789v.h"
    #include <stdbool.h>
    #include <nrf_spi_mngr.h>
    #include <nrf_delay.h>
    #include <nrf_lcd.h>
    #define NRF_LOG_MODULE_NAME ST7789V
    #include "nrf_log.h"
    NRF_LOG_MODULE_REGISTER();
    NRF_SPI_MNGR_DEF(m_nrf_st_spi_mngr, SPI_DS_QUEUE_SIZE, 2);
    //nrf_drv_spi_config_t const display_spi_config =
    //    .sck_pin        = DISPLAY_SCK,
    //    .mosi_pin       = DISPLAY_MOSI,
    //    .miso_pin       = NRF_DRV_SPI_PIN_NOT_USED,
    //    .ss_pin         = DISPLAY_CS,
    //    .irq_priority   = APP_IRQ_PRIORITY_MID,
    //    .orc            = 0xFF,
    //    .frequency      = NRF_DRV_SPI_FREQ_8M,
    //    .mode           = NRF_DRV_SPI_MODE_2,
    //    .bit_order      = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST
    nrfx_spim_config_t const display_spi_config =
    	.ss_active_high = false,
        .orc            = 0xFF,
        .frequency      = NRF_SPIM_FREQ_8M,
    // Function called before SPI command is send to LCD display. I is used to drive A0 pin low.
    static void ST7789V_set_command_cb(void * p_user_data)
        nrf_gpio_pin_clear(DISPLAY_DATA_SEL);
    // Function called before SPI data is send to LCD display. It is used to drive A0 pin high.
    static void ST7789V_set_data_cb(void * p_user_data)
        nrf_gpio_pin_set(DISPLAY_DATA_SEL);
    static void set_addr_window(uint16_t x_0, uint16_t y_0, uint16_t x_1, uint16_t y_1)
        ASSERT(x_0 <= x_1);
        ASSERT(y_0 <= y_1);
        // copy coordinates
        static uint8_t x_coord[4];
        static uint8_t y_coord[4];
        x_coord[0] = x_0 >> 8;
        x_coord[1] = (uint8_t) x_0;
        x_coord[2] = x_1 >> 8;
        x_coord[3] = (uint8_t) x_1;
        y_coord[0] = y_0 >> 8;
        y_coord[1] = (uint8_t) y_0;
        y_coord[2] = y_1 >> 8;
        y_coord[3] = (uint8_t) y_1;
        static nrf_spi_mngr_transfer_t NRF_SPI_MNGR_BUFFER_LOC_IND transfer[] =
            NRF_SPI_MNGR_TRANSFER(&(ST7789V_CASET), 1, NULL, 0),
            NRF_SPI_MNGR_TRANSFER(&(x_coord), 4, NULL, 0),
            NRF_SPI_MNGR_TRANSFER(&(ST7789V_RASET), 1, NULL, 0),
            NRF_SPI_MNGR_TRANSFER(&(y_coord), 4, NULL, 0),
            NRF_SPI_MNGR_TRANSFER(&(ST7789V_RAMWR), 1, NULL, 0),
        static const int NUM_OF_ADDRESS_TRANS = 5;
        static nrf_spi_mngr_transaction_t const transaction_address_data[] =
    			.begin_callback      = ST7789V_set_command_cb,
    			.end_callback        = NULL,
    			.p_user_data         = NULL,
    			.p_transfers         = &transfer[0],   // page 0
    			.number_of_transfers = 1,
    			.p_required_spi_cfg  = &display_spi_config
    			.begin_callback      = ST7789V_set_data_cb,
    			.p_transfers         = &transfer[1],   // page 0
    			.p_required_spi_cfg  = NULL
    			.p_transfers         = &transfer[2],   // page 0
    			.p_transfers         = &transfer[3],   // page 0
    			.p_transfers         = &transfer[4],   // page 0
        for (int i = 0; i < NUM_OF_ADDRESS_TRANS; i++){
            nrf_spi_mngr_schedule(&m_nrf_st_spi_mngr, &transaction_address_data[i]);
    static void init_command()
    	static uint8_t init_data[] = {0x08, 0x55, 0x0F};
    	static uint8_t gamma_voltage_plus[] = {0xD0, 0x00, 0x05, 0x0E, 0x15, 0x0D, 0x37, 0x43, 0x47, 0x09, 0x15, 0x12, 0x16, 0x09};
    	static uint8_t gamma_voltage_minus[] = {0xD0, 0x00, 0x05, 0x0D, 0x0C, 0x06, 0x2D, 0x44, 0x40, 0x0E, 0x1C, 0x18, 0x16, 0x19};
    	static nrf_spi_mngr_transfer_t NRF_SPI_MNGR_BUFFER_LOC_IND reset_transfers[] =
        	// send as command
            NRF_SPI_MNGR_TRANSFER(&(ST7789V_SWRESET), 1, NULL, 0), // 120 ms delay afterwards
            NRF_SPI_MNGR_TRANSFER(&(ST7789V_SLPOUT), 1, NULL, 0), // 150 ms delay afterwards
    	ST7789V_set_command_cb(NULL);
    	nrf_spi_mngr_perform(&m_nrf_st_spi_mngr, NULL, &(reset_transfers[0]), 0, 0);
    	nrf_delay_ms(120);
    	nrf_spi_mngr_perform(&m_nrf_st_spi_mngr, NULL, &(reset_transfers[1]), 0, 0);
    	nrf_delay_ms(150);
        	// send as command
            NRF_SPI_MNGR_TRANSFER(&(ST7789V_MADCTL), 1, NULL, 0), //
            // send as data up right down mode
    		NRF_SPI_MNGR_TRANSFER(&(init_data[0]), 1, NULL, 0),
    		// send as command
    		NRF_SPI_MNGR_TRANSFER(&(ST7789V_COLMOD), 1, NULL, 0),
    		// send as data 18 bit color mode
    		NRF_SPI_MNGR_TRANSFER(&(init_data[1]), 1, NULL, 0),
    		// send as command
    		NRF_SPI_MNGR_TRANSFER(&(ST7789V_FRMCTR2), 1, NULL, 0),
    		// send as data 60 Hz frame rate
    		NRF_SPI_MNGR_TRANSFER(&(init_data[2]), 1, NULL, 0),
    		// send as command
    		NRF_SPI_MNGR_TRANSFER(&(ST7789V_PVGAMCTRL), 1, NULL, 0),
    		// send as data gamma voltage +
    		NRF_SPI_MNGR_TRANSFER(&(gamma_voltage_plus[0]), 14, NULL, 0),
    		// send as command
    		NRF_SPI_MNGR_TRANSFER(&(ST7789V_NVGAMCTRL), 1, NULL, 0),
    		NRF_SPI_MNGR_TRANSFER(&(gamma_voltage_minus[0]), 14, NULL, 0),
    		// send as command
    		NRF_SPI_MNGR_TRANSFER(&(ST7789V_INVON), 1, NULL, 0),
    		// send as command
    		NRF_SPI_MNGR_TRANSFER(&(ST7789V_DISPON), 1, NULL, 0),
    	static const int NUM_OF_INIT_TRANS = 12;
        static nrf_spi_mngr_transaction_t transaction_init_data[] =
    			.p_transfers         = &transfer[5],   // page 0
    			.p_transfers         = &transfer[6],   // page 0
    			.p_transfers         = &transfer[7],   // page 0
    			.p_transfers         = &transfer[8],   // page 0
    			.p_transfers         = &transfer[9],   // page 0
    			.p_transfers         = &transfer[10],   // page 0
    			.p_transfers         = &transfer[11],   // page 0
        for (int i = 0; i < NUM_OF_INIT_TRANS; i++){
        	APP_ERROR_CHECK(nrf_spi_mngr_schedule(&m_nrf_st_spi_mngr, &transaction_init_data[i]));
    static void st7789v_pixel_draw(uint16_t x, uint16_t y, uint32_t color)
        set_addr_window(x, y, x, y);
        static uint8_t pixel_data[2];
        uint16_t u_color = (uint16_t) color;
        memcpy(pixel_data, (uint8_t*)&u_color, 2);
        static nrf_spi_mngr_transfer_t NRF_SPI_MNGR_BUFFER_LOC_IND pixel_transfer[] =
    		NRF_SPI_MNGR_TRANSFER(&pixel_data[0], 2, NULL, 0)
        static nrf_spi_mngr_transaction_t const transaction_pixel_data[] =
    			.p_transfers         = &pixel_transfer[0],   // page 0
        APP_ERROR_CHECK(nrf_spi_mngr_schedule(&m_nrf_st_spi_mngr, &transaction_pixel_data[0]));
    static void st7789v_pixel_draw_buffered(uint16_t x, uint16_t y, uint16_t* color, uint32_t length)
    //    set_addr_window(x, y, x, y);
    //    static uint8_t* img_buf = (uint8_t*)&(color[0]);
    //    static nrf_spi_mngr_transfer_t NRF_SPI_MNGR_BUFFER_LOC_IND pixel_transfer[] =
    //		NRF_SPI_MNGR_TRANSFER(img_buf, length<<1, NULL, 0)
    //    static nrf_spi_mngr_transaction_t const transaction_pixel_data[] =
    //			.begin_callback      = ST7789V_set_data_cb,
    //			.end_callback        = NULL,
    //			.p_user_data         = NULL,
    //			.p_transfers         = &pixel_transfer[0],   // page 0
    //			.number_of_transfers = 1,
    //			.p_required_spi_cfg  = NULL
    //    APP_ERROR_CHECK(nrf_spi_mngr_schedule(&m_nrf_st_spi_mngr, &transaction_pixel_data[0]));
    static void st7789v_rect_draw(uint16_t x, uint16_t y, uint16_t width, uint16_t height, uint32_t color)
        set_addr_window(x, y, x + width - 1, y + height - 1);
        static  uint8_t data[2];
        memcpy(data, (uint8_t*)&color, 2);
        // Duff's device algorithm for optimizing loop.
        uint32_t i = (height * width + 7) / 8;
        static nrf_spi_mngr_transfer_t NRF_SPI_MNGR_BUFFER_LOC_IND rect_transfer[] =
    		NRF_SPI_MNGR_TRANSFER(&data[0], 2, NULL, 0)
        ST7789V_set_data_cb(NULL);
        switch ((height * width) % 8) {
            case 0:
                do {
                	APP_ERROR_CHECK(nrf_spi_mngr_perform(&m_nrf_st_spi_mngr, NULL, rect_transfer, 1, NULL));
            case 7:
            case 6:
            case 5:
            case 4:
            case 3:
            case 2:
            case 1:
                } while (--i > 0);
    static void st7789v_dummy_display(uint8_t * data, uint16_t len, uint8_t x0, uint8_t y0, uint8_t x1, uint8_t y1)
        if(len == 0xFFFF){
        	set_addr_window(x0, y0, x1, y1);
        else{
            nrf_spi_mngr_transfer_t NRF_SPI_MNGR_BUFFER_LOC_IND dummy_transfer[] =
        		NRF_SPI_MNGR_TRANSFER(&data[0], len, NULL, 0)
            nrf_spi_mngr_transaction_t const transaction_dummy_data[] =
        			.p_transfers         = &dummy_transfer[0],   // page 0
            APP_ERROR_CHECK(nrf_spi_mngr_schedule(&m_nrf_st_spi_mngr, &transaction_dummy_data[0]));
    static void st7789v_rotation_set(nrf_lcd_rotation_t rotation)
    	static uint8_t data = 0;
        switch (rotation % 4) {
            case NRF_LCD_ROTATE_0:
            	data = ST7789V_MADCTL_MX | ST7789V_MADCTL_MY | ST7789V_MADCTL_RGB;
                //Column address (MX): Right to left
                //Page address (MY): Bottom to top
                //Page/ Column order (MV): normal
                //RGB/BGR order: RGB
            case NRF_LCD_ROTATE_90:
            	data = ST7789V_MADCTL_MV | ST7789V_MADCTL_RGB;
                //Column address (MX): Left to right
                //Page address (MY): Top to bottom
                //Page/ Column order (MV): reverse
            case NRF_LCD_ROTATE_180:
            	data = ST7789V_MADCTL_RGB;
            case NRF_LCD_ROTATE_270:
            	data = ST7789V_MADCTL_MX | ST7789V_MADCTL_MV | ST7789V_MADCTL_RGB;
    	static nrf_spi_mngr_transfer_t NRF_SPI_MNGR_BUFFER_LOC_IND rotation_transfers[] =
        	// send as command
    		NRF_SPI_MNGR_TRANSFER(&data, 1, NULL, 0),
        static nrf_spi_mngr_transaction_t transaction_rotation_data[] =
    			.p_transfers         = &rotation_transfers[0],   // page 0
    			.p_transfers         = &rotation_transfers[1],   // page 0
    	for (int i = 0; i < 2; i++){
    		APP_ERROR_CHECK(nrf_spi_mngr_schedule(&m_nrf_st_spi_mngr, &transaction_rotation_data[i]));
    static void st7789v_display_invert(bool invert)
    	uint8_t cmd = invert ? ST7789V_INVON : ST7789V_INVOFF;
        nrf_spi_mngr_transfer_t NRF_SPI_MNGR_BUFFER_LOC_IND inv_transfer[] =
    		NRF_SPI_MNGR_TRANSFER(&cmd, 1, NULL, 0),
    	APP_ERROR_CHECK(nrf_spi_mngr_perform(&m_nrf_st_spi_mngr, NULL, inv_transfer, 1, NULL));
    static lcd_cb_t st7789v_cb = {
        .height = 320,
        .width = 240
    static ret_code_t st7789v_init(){
    	ret_code_t err_code;
    	if (!nrf_drv_gpiote_is_init()){
    		NRF_LOG_INFO("GPIO initialized");
    	// configure GPIO pins
    	nrf_gpio_cfg_output(DISPLAY_DATA_SEL);
    	nrf_delay_us(20);
    	nrf_gpio_cfg_output(DISPLAY_RESET);
    	// set standard values
    	nrf_gpio_pin_set(DISPLAY_RESET);
    	nrf_gpio_pin_clear(DISPLAY_RESET);
    	nrf_delay_us(20);
    	// init display driver
    	err_code = nrf_spi_mngr_init(&m_nrf_st_spi_mngr, &display_spi_config);
    	init_command();
    	NRF_LOG_INFO("Initialized!");
    	return err_code;
    static void st7789v_uninit(void)
    	nrf_delay_us(20);
    	nrf_spi_mngr_uninit(&m_nrf_st_spi_mngr);
    const nrf_lcd_t nrf_lcd_st7789v = {
        .lcd_init = st7789v_init,
        .lcd_uninit = st7789v_uninit,
        .lcd_pixel_draw = st7789v_pixel_draw,
        .lcd_rect_draw = st7789v_rect_draw,
        .lcd_display = st7789v_dummy_display,
        .lcd_rotation_set = st7789v_rotation_set,
        .lcd_display_invert = st7789v_display_invert,
        .p_lcd_cb = &st7789v_cb
    If I switch of NRFX_SPIM_EXTENDED_ENABLED it is working but only half the speed then SDK 14.2. And only if I increase the priority to MID if I dry to write a text with 10 Hz. Otherwise the queue get stuck (OUT OF MEM).
    st7789v.h
    Furthermore the SPIM3 with increased frequency is not usable with the spi_mngr, because the code is all old legacy stuff with the dirty wrapper and glue in between.
  • Okay I've switched the spi_mngr to nrfx_spim.Therefor, I had to change the nrf_spi_mngr.c and h files.
    This is now working for SPIM2 but not for SPIM3. If I try SPIM3 I get now the following error:
    <error> app: SOFTDEVICE: INVALID MEMORY ACCESS
    And the program is freezing. I tried with NRFX_SPIM_EXTENDED_ENABLED 0 and 1 but neither worked. Same for NRFX_SPIM3_NRF52840_ANOMALY_198_WORKAROUND_ENABLED. Did not change something.
