Extended Advertising on NRF52832
Hi
Using SD Version 6.1.1 and NRF Version 15.3.0.
Using the following advertising params I can set non-extended advertising
ble_gap_adv_params_t advertisingParameters;
advertisingParameters.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED; // GAP Advertising type
using
sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &advertisingParams);
As soon I change to
advertisingParameters.properties.type = BLE_GAP_ADV_TYPE_EXTENDED_CONNECTABLE_NONSCANNABLE_UNDIRECTED
I get an error NRF_ERROR_INVALID_PARAM from the Softdevice is there a step I am missing here to use Bluetooth 5
  • Hi, can you please post the rest of the advertising init function?
  • Hi
    Here is the rest of the setup
    memset(&advertisingParameters,0x00,sizeof(advertisingParameters));
    advertisingParameters.properties.type = BLE_GAP_ADV_TYPE_EXTENDED_CONNECTABLE_NONSCANNABLE_UNDIRECTED;
    advertisingParameters.p_peer_addr = NULL;
    advertisingParameters.duration = BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED;
    advertisingParameters.interval = 0x40;
    advertisingParameters.primary_phy = BLE_GAP_PHY_AUTO;
    advertisingParameters.secondary_phy = BLE_GAP_PHY_AUTO;
    advertisingParameters.set_id = 4;
    advertisingParameters.filter_policy = BLE_GAP_ADV_FP_ANY;
    From a working instance where a remote central sees the advertising the only line I have changed
    Many thanks
  • There's more to the initialization function. More specifically you are probably calling sd_ble_gap_adv_set_configure() in the end to configure the advertising paramters.
    Anyways, here's an example I tested with here, and is working with extended advertising:
    static void extended_adv_init(void)
        memset(&m_adv_params, 0, sizeof(m_adv_params));
        //m_adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
        m_adv_params.properties.type = BLE_GAP_ADV_TYPE_EXTENDED_CONNECTABLE_NONSCANNABLE_UNDIRECTED;
        m_adv_params.p_peer_addr     = NULL;
        m_adv_params.duration        = BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED;
        m_adv_params.interval      = 0x40;
        m_adv_params.primary_phy   = BLE_GAP_PHY_AUTO;
        m_adv_params.secondary_phy   = BLE_GAP_PHY_AUTO;
        m_adv_params.set_id         = 4;
        m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
        ret_code_t               err_code;
        ble_advdata_t            advdata;
        ble_advdata_manuf_data_t manuf_data;
        memset(&advdata, 0, sizeof(advdata));
        manuf_data.company_identifier = COMPANY_IDENTIFIER;
        manuf_data.data.size          = ADV_ADDL_MANUF_DATA_LEN;
        manuf_data.data.p_data        = m_addl_adv_manuf_data;
        advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        advdata.p_manuf_specific_data = &manuf_data;
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
