Issues with DSM and Access persistent storage
I have a node running with the SDK for Mesh  v3.1.0. It crashes during boot up in restore_addresses_for_model() due to dsm_address_subscription_add_handle() returning NRF_ERROR_NOT_FOUND.
This is because nothing has been restored from flash for DSM.
In mesh_stack_init() the return value from dsm_flash_config_load() is ignored and access_flash_config_load() is called regardless.
    (void) dsm_flash_config_load();
    (void) access_flash_config_load();
Wouldn't it make more sense to erase the access flash area in case the DSM failed to load as access depends on DSM?
dsm_flash_config_load() fails because it can't read the dsm metadata entry. I have no clue into how it could have been lost.
A hexdump of the DSM flash area. It doesn't contain the expected DSM_FLASH_HANDLE_METAINFO. It is however sealed.
:10400000080410100100FFFF02000200010004007C
:1040100006000030000000D68706571C8FA8CCFE93
:104020005B1938489A8CAE00060000500100000071
:1040300090B51101530FB8BA733987CE72F58F411D
:104040000600004000000000E477A7878EC8A8BFE4
:1040500050CD2D0A119EB2FF0200001001C00210C7
:104060000200011002C00A10020002100400011038
:10407000FFFFFF7FFFFFFFFFFFFFFFFFFFFFFFFFD0
The recovery page contains the following, which indicate that a defrag was performed and completed successfully.
:1060000000000000080410100100FFFF0200020061
:10601000FFFF01100200010000800110FFFFFFFFE1
:10602000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80
bool dsm_flash_config_load(void)
    if (!m_flash_is_available)
        return false;
    dsm_flash_entry_metainfo_t metainfo;
    uint32_t metainfo_size = sizeof(metainfo);
    if (flash_manager_entry_read(&m_flash_manager,
                                 DSM_FLASH_HANDLE_METAINFO,
                                 &metainfo,
                                 &metainfo_size) != NRF_SUCCESS)
        return false;
Wouldn't it make sense to call reset_flash_area() if it can't find the metainfo? As the dsm_init() must have created it in case the area was empty?
Thanks.
  • Hi
    I got the same issue and the application will stop running. I am using the light server example with mesh sdk v3.1.0.
    Please see when will the bug can be fixed.
    Furthermore, is there any shortern solution i can reset the memory and may be configure the netwrok again rather than hang.
    Regards
    Nicky
  • Hi ,
    Has there been any progress on this internally?
    Thanks.
  • I've debugged this issue for some time now. My theory of why this happens is because the device is reset after the flash manager metadata is written but before the DSM metadata is written.
    The code simply assumes that the presence of the first indicates the presence of the latter which isn't always true.
    The dsm_flash_config_load() tries to readout the DSM metadata, if that fails it simply returns false, which wrongly is ignored by the caller.
    In the beginning there is no access configuration to read back from flash and thus it doesn't fail. Regular operations continues and both DSM and Access data are saved to flash.
    On the next bootup the dsm_flash_config_load() call again fails to find its metadata and never load the real data from flash and thus the access layer load asserts because it tries to reference DSM entries that wasn't loaded.
    I'm currently using the following patch as a workaround until there is an official solution to this problem.
    diff --git a/mesh/access/api/access_config.h b/mesh/access/api/access_config.h
    index 8e3fd31..4b52c67 100644
    --- a/mesh/access/api/access_config.h
    +++ b/mesh/access/api/access_config.h
    @@ -54,6 +54,11 @@
    + * Clear access layer configuration from flash.
    +void access_flash_config_clear(void);
      * Recover access layer configuration from flash.
    diff --git a/mesh/access/src/access.c b/mesh/access/src/access.c
    index a8bdb29..b1149d0 100644
    --- a/mesh/access/src/access.c
    +++ b/mesh/access/src/access.c
    @@ -946,7 +946,7 @@ static inline uint32_t element_store(uint16_t element_index)
     /* ********** Public API ********** */
    -static void access_flash_config_clear(void)
         static fm_mem_listener_t flash_clear_mem_available_struct =
    @@ -1066,7 +1066,7 @@ void access_flash_config_store(void)
         bearer_event_critical_section_end();
     #else
         m_access_model_config_frozen = false;
    diff --git a/mesh/access/src/device_state_manager.c b/mesh/access/src/device_state_manager.c
    index b073ae6..97b708f 100644
    --- a/mesh/access/src/device_state_manager.c
    +++ b/mesh/access/src/device_state_manager.c
    @@ -1785,7 +1785,14 @@ bool dsm_flash_config_load(void)
                                      &metainfo,
    -        return false;
    +        if (m_flash_manager.internal.state != FM_STATE_BUILDING) {
    +            // The flash isn't building thus the METAINFO should always be
    +            // available. Something is clearly wrong.
    +            reset_flash_area();
    +            return false;
    +        return true;
         if (metainfo.max_addrs_nonvirtual != DSM_NONVIRTUAL_ADDR_MAX ||
    diff --git a/mesh/stack/src/mesh_stack.c b/mesh/stack/src/mesh_stack.c
    index f98adb8..e35164f 100644
    --- a/mesh/stack/src/mesh_stack.c
    +++ b/mesh/stack/src/mesh_stack.c
    @@ -109,11 +109,14 @@ uint32_t mesh_stack_init(const mesh_stack_init_params_t * p_init_params,
             p_init_params->models.models_init_cb();
    -    (void) dsm_flash_config_load();
    -    if (access_flash_config_load())
    +    if (dsm_flash_config_load())
    -        access_flash_config_store();
    +        if (access_flash_config_load())
    +            access_flash_config_store();
    +    } else {
    +        access_flash_config_clear();
         bool is_provisioned = mesh_stack_is_device_provisioned();
    Thanks.
  • Hi.
    Thanks for sharing your workaround.
    Our developers is working on this, but I haven't gotten an official solution to this yet.
    I know this will be fixed in future releases, but I'll ask for a fix that can be used with previous versions of the nRF5 SDK for Mesh as well.
    Best regards.
