Issues with DSM and Access persistent storage
I have a node running with the SDK for Mesh  v3.1.0. It crashes during boot up in restore_addresses_for_model() due to dsm_address_subscription_add_handle() returning NRF_ERROR_NOT_FOUND.
This is because nothing has been restored from flash for DSM.
In mesh_stack_init() the return value from dsm_flash_config_load() is ignored and access_flash_config_load() is called regardless.
    (void) dsm_flash_config_load();
    (void) access_flash_config_load();
Wouldn't it make more sense to erase the access flash area in case the DSM failed to load as access depends on DSM?
dsm_flash_config_load() fails because it can't read the dsm metadata entry. I have no clue into how it could have been lost.
A hexdump of the DSM flash area. It doesn't contain the expected DSM_FLASH_HANDLE_METAINFO. It is however sealed.
:10400000080410100100FFFF02000200010004007C
:1040100006000030000000D68706571C8FA8CCFE93
:104020005B1938489A8CAE00060000500100000071
:1040300090B51101530FB8BA733987CE72F58F411D
:104040000600004000000000E477A7878EC8A8BFE4
:1040500050CD2D0A119EB2FF0200001001C00210C7
:104060000200011002C00A10020002100400011038
:10407000FFFFFF7FFFFFFFFFFFFFFFFFFFFFFFFFD0
The recovery page contains the following, which indicate that a defrag was performed and completed successfully.
:1060000000000000080410100100FFFF0200020061
:10601000FFFF01100200010000800110FFFFFFFFE1
:10602000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80
bool dsm_flash_config_load(void)
    if (!m_flash_is_available)
        return false;
    dsm_flash_entry_metainfo_t metainfo;
    uint32_t metainfo_size = sizeof(metainfo);
    if (flash_manager_entry_read(&m_flash_manager,
                                 DSM_FLASH_HANDLE_METAINFO,
                                 &metainfo,
                                 &metainfo_size) != NRF_SUCCESS)
        return false;
Wouldn't it make sense to call reset_flash_area() if it can't find the metainfo? As the dsm_init() must have created it in case the area was empty?
Thanks.
  • I realized that the patch posted earlier wasn't complete after the upgrade to v3.2.0.
    The following is in addition to the previous patch. It ensure that failure to flash loading of DSM causes the access layer to clear it's flash as well.
    It changes the behavior of the return value from dsm_flash_config_load() to return false if it wasn't possible to read anything useful from it. Previously it would return false if the flash was properly initialized but no address was stored.
    One might consider moving the access_flash_config_clear() into the dsm_flash_config_load() after each call to reset_flash_area() which would be more similar to the access_flash_config_load() code.
    diff --git a/mesh/access/src/access.c b/mesh/access/src/access.c
    index 4fc61c7..e584a6e 100644
    --- a/mesh/access/src/access.c
    +++ b/mesh/access/src/access.c
    @@ -977,6 +977,18 @@ bool access_flash_config_load(void)
             NRF_MESH_ASSERT(ACCESS_INTERNAL_STATE_IS_ALLOCATED(m_subscription_list_pool[i].internal_state));
    +    if (m_flash_not_ready)
    +        // Flash is currently being erased, consider this as a success and
    +        // freeze further changes.
    +        // NOTE: This part of the code assumes that the flash_manager_remove()
    +        // call in access_flash_config_clear() was successful. Otherwise it
    +        // would try again async causing the m_access_model_config_froze variable
    +        // to be wrongfully set to false.
    +        m_access_model_config_frozen = true;
    +        return true;
         if (flash_manager_entry_read(&m_flash_manager, FLASH_HANDLE_METADATA, &metadata, &metadata_size) != NRF_SUCCESS)
             /* Entry could not be read, means the application is trying to load access data for the
    @@ -1007,6 +1019,11 @@ bool access_flash_config_load(void)
         /* Freeze composition data. */
         return config_restored;
    diff --git a/mesh/access/src/device_state_manager.c b/mesh/access/src/device_state_manager.c
    index 97b708f..fae2bd0 100644
    --- a/mesh/access/src/device_state_manager.c
    +++ b/mesh/access/src/device_state_manager.c
    @@ -1807,8 +1807,8 @@ bool dsm_flash_config_load(void)
         /* Run through the rest of the entries and load them based on type */
         (void) flash_manager_entries_read(&m_flash_manager, NULL, flash_read_callback, NULL);
    -    /* The storage was valid if there was a local unicast address present */
    -    return bitfield_get(m_addr_unicast_allocated, 0);
    +    return true;
     bool dsm_has_unflashed_data(void)
    diff --git a/mesh/stack/src/mesh_stack.c b/mesh/stack/src/mesh_stack.c
    index e35164f..6cd38fc 100644
    --- a/mesh/stack/src/mesh_stack.c
    +++ b/mesh/stack/src/mesh_stack.c
    @@ -109,16 +109,21 @@ uint32_t mesh_stack_init(const mesh_stack_init_params_t * p_init_params,
             p_init_params->models.models_init_cb();
    -    if (dsm_flash_config_load())
    +    if (!dsm_flash_config_load())
    -        if (access_flash_config_load())
    -            access_flash_config_store();
    -    } else {
    +        // As any stored access data depends on the DSM it doesn't make sense
    +        // to keep that old data around.
             access_flash_config_clear();
    +    // Regardless of the clear above, try to load it to mark the composition
    +    // as frozen.
    +    if (access_flash_config_load())
    +        // This should only store the metadata.
    +        access_flash_config_store();
         bool is_provisioned = mesh_stack_is_device_provisioned();
     #if MESH_FEATURE_GATT_PROXY_ENABLED
    Thanks.
