SEGGER emStudio build project failure
After trying to work out why one of our nrf9160 DK:s cannot execute any AT commands using the at_client sample I tried redoing the getting started guide to make sure it is purely a problem with the board. After doing that SEGGER emStudio stopped working and when I try to build a project I get the following error:
This is the same for all samples and I can't figure out why, how can I fix this?
Kind regards
Samuel
  • Hi Samuel,
    I am getting the same error as you were getting. I dint install it twice. so i dont think it has anything to do with the folder names.
    C:\Users\jnai\OneDrive\Documents\MyScripts\Nordic_NBIot\ncs\nrf\samples\nrf9160\spm\build>cmake -DBOARD=nrf9160_pca10090 -GNinja ..
    -- Using application from 'C:/Users/jnai/OneDrive/Documents/MyScripts/Nordic_NBIot/ncs/nrf/samples/nrf9160/spm'
    Zephyr version: 1.14.0
    -- Found PythonInterp: C:/Python37/python.exe (found suitable version "3.7.3", minimum required is "3.4")
    -- Selected BOARD nrf9160_pca10090
    -- Found west: C:/Python37/Scripts/west.exe (found suitable version "0.5.8", minimum required is "0.5.6")
    -- Cache files will be written to: C:\Users\jnai\AppData\Local/.cache/zephyr
    -- Loading C:/Users/jnai/OneDrive/Documents/MyScripts/Nordic_NBIot/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090.dts as base
    -- Overlaying C:/Users/jnai/OneDrive/Documents/MyScripts/Nordic_NBIot/ncs/zephyr//dts/common/common.dts
    -- Overlaying -
    -- Overlaying /Documents/MyScripts/Nordic_NBIot/ncs/nrf/samples/nrf9160/spm/nrf9160_pca10090.overlay
    arm-none-eabi-gcc.exe: error: CreateProcess: No such file or directory
    CMake Error at C:/Users/jnai/OneDrive/Documents/MyScripts/Nordic_NBIot/ncs/zephyr/cmake/dts.cmake:94 (message):
    command failed with return code: 1
    C:/Users/jnai/OneDrive/Documents/MyScripts)/Nordic_NBIot/ncs/zephyr/cmake/app/boilerplate.cmake:486 (include)
    CMakeLists.txt:3 (include)
    I was not able to do   git checkout c1939d963fe2c18013ffb8de0bd8f6fc1d91724d
    error: The following untracked working tree files would be overwritten by checkout:
    The process was getting aborted.
    Can you please suggest how to fix this? Thanks in advance!
  • Hi JNair
    I am not sure about how to fix you problem since I am pretty new here. But you could try doing as Gurkan suggested a few messages above by running "zephyr-env.cmd" in the zephyr folder to set you variables and try again. Since it seems to be some sort of variable problem from what I can tell.
    /Samuel
  • /Documents/MyScripts/Nordic_NBIot/ncs/nrf/samples/nrf9160/spm/nrf9160_pca10090.overlay
    Looks like it could not find gnu tool chain.
    I'd suggest to simply your folder location, just do a clear installation from scratch and use;
    for gnu toolchain -> c:\gnuarmemb
    For nordic sdk -> c:\nordic\ncs.
  • Thanks Gurkan for the help. I will try doing that.
  • Thanks Samuel. Will try installing it from scratch and try again.
