Dear ,
I want to use LTE_M of nRF9160 DK to POST to my webserver
Do you have any suggestions?
Regards
hng
Dear ,
Regards
hng
I believe a bug in the BSD library causes this. I get the "no memory" error when call socket send in a loop without any delay in-between. I have reported this internally. A workaround, for now, is to add a delay between each post request.
Dear Vidar Berg
I had 2s delay between
How long should I add ?
Thanks for fast responds,
hng
A 2-second delay should be sufficient. Can you try to increase the stack sizes in your project *.conf file?
e.g.,
CONFIG_MAIN_STACK_SIZE= 8192
CONFIG_HEAP_MEM_POOL_SIZE=8192
Dear Vidar Berg
I tried, the same thing happened
int nRF_LTE_check(void)
int err;
const char *ATREG="AT+CEREG?";
int at_socket_fd = socket(AF_LTE, 0, NPROTO_AT);
printk("Checking LTE_M signal.............\n\r");
if (at_socket_fd < 0) {
err = 1;
else {
int bytes_written = send(at_socket_fd, ATREG, strlen(ATREG), 0);
if (bytes_written > 0) {
int r_bytes = blocking_recv(at_socket_fd, recv_buf,sizeof(recv_buf), MSG_DONTWAIT);
if (r_bytes > 0) {
printk("%s", recv_buf);
if (recv_buf== LTEfound)
err = 0;
printk("Found LTE_M signal \n");
else {
printk("Couldnt find the LTE_M signal \n");
err =1;
printk("Closing socket\n\r");
(void)close(at_socket_fd);
return err;
my loop:
#include <zephyr.h>
#include <net/socket.h>
#include <misc/printk.h>
#include <zephyr/types.h>
#include <math.h>
#include <uart.h>
#include <soc.h>
#include <gpio.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h> /* atof */
#include <autoconf.h>
void main (void)
printk("Test is starting \n");
while(1){
int lte_err= nRF_LTE_check();
if(lte_err==0){ printk(" find LTE_M signal........... \n"); }
else{ printk(" Couldnt find LTE_M signal........... \n");}
k_sleep(2000);
and my prj.conf
CONFIG_SERIAL=y CONFIG_TRUSTED_EXECUTION_NONSECURE=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_UART_1_NRF_UARTE=y CONFIG_UART_2_NRF_UARTE=y CONFIG_GPIO=y CONFIG_NETWORKING=y CONFIG_NET_BUF_USER_DATA_SIZE=1 CONFIG_NET_SOCKETS_OFFLOAD=y CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_POSIX_NAMES=y CONFIG_NET_RAW_MODE=y CONFIG_BSD_LIBRARY=y CONFIG_STDOUT_CONSOLE=y CONFIG_TEST_RANDOM_GENERATOR=y CONFIG_LOG=n CONFIG_LOG_DEFAULT_LEVEL=4 #CONFIG_HEAP_MEM_POOL_SIZE=1024 CONFIG_MAIN_STACK_SIZE= 8192 CONFIG_HEAP_MEM_POOL_SIZE=8192 # LTE link control #CONFIG_LTE_LINK_CONTROL=y CONFIG_UART_2_NRF_TX_BUFFER_SIZE=1024
Can you upload your entire project directory here so I can try to debug it? Some of the variable definitions are missing from the code snippets above.
