Dear ,
I want to use LTE_M of nRF9160 DK to POST to my webserver
Do you have any suggestions?
Regards
hng
Dear ,
Regards
hng
Dear Vidar Berg
Sorry for snippers, it missed the LTEfound
#include <zephyr.h>
#include <net/socket.h>
#include <misc/printk.h>
#include <zephyr/types.h>
#include <math.h>
#include <soc.h>
#include <gpio.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h> /* atof */
#include <autoconf.h>
#define AT_MAX_CMD_LEN 4096
#define INVALID_DESCRIPTOR -1
#define UART_RX_BUF_SIZE 4096
#define CMD_STATE 0
#define RESPOND_STATE 1
#define UART_BUF_SIZE 1024
#define RECV_BUF_SIZE 1024
char recv_buf[RECV_BUF_SIZE + 1];
const char *at_commands[] = {
"AT+CGMM", "AT+CGDCONT?", "AT%XCBAND=?", "AT+CGSN=1",
"AT+CESQ",
// Add more here if needed
*name:
*to do: SPLIT the String with pattern()
*return:
void stringsplit(char *str)
//char str[] = "strtok needs to be called several times to split a string";
int init_size = strlen(str);
char delim[] = " ";
char *ptr = strtok(str, delim);
while(ptr != NULL)
printf("'%s'\n", ptr);
ptr = strtok(NULL, delim);
/* This loop will show that there are zeroes in the str after tokenizing */
for (int i = 0; i < init_size; i++)
printf("%d ", str[i]); /* Convert the character to integer, in this case
the character's ASCII equivalent */
printf("\n");
return 0;
*name:
*return:
void split_string_ltepos(char *str, char splitStrings[10][10])
// char str[100];
//can store 10 words of 10 characters
int i,j,cnt;
j=0; cnt=0;
for(i=0;i<=(strlen(str));i++)
// if space or NULL found, assign NULL into splitStrings[cnt]
if(str[i]=='"'||str[i]=='\0')
splitStrings[cnt][j]='\0';
cnt++; //for next word
j=0; //for next word, init index to 0
splitStrings[cnt][j]=str[i];
j++;
printk("\nOriginal String is: %s",str);
printk("\nStrings (words) after split by space:\n");
for(i=0;i < cnt;i++)
printk("%s\n",splitStrings[i]);
// return splitStrings;
*name: blocking_recv()
*to do: receive data
*return:
int blocking_recv(int fd, u8_t *buf, u32_t size, u32_t flags)
int err;
do {
err = recv(fd, buf, size, flags);
} while (err < 0 && errno == EAGAIN);
return err;
*name: blocking_send
*todo: send data
*return:
int blocking_send(int fd, u8_t *buf, u32_t size, u32_t flags)
int err;
do {
err = send(fd, buf, size, flags);
return err;
*name: blocking_connect
*todo: connect block()
*return:
int blocking_connect(int fd, struct sockaddr *local_addr, socklen_t len)
int err;
do {
err = connect(fd, local_addr, len);
return err;
*name: nRF_LTE_check
*todo: check nRF LTE connect
*return: return at_commands[]
int nRF_LTE_check(void)
int err;
const char *ATREG="AT+CEREG?";
int at_socket_fd = socket(AF_LTE, 0, NPROTO_AT);
//printk("LTE socket is: %d \n",at_socket_fd);
printk("Checking LTE_M signal.............\n\r");
if (at_socket_fd < 0) {
err = 1;
else {
err = 0;
int bytes_written2 = send(at_socket_fd, ATREG, strlen(ATREG), 0);
k_sleep(5000);
if (bytes_written2 > 0) {
int r_bytes2 = blocking_recv(at_socket_fd, recv_buf,sizeof(recv_buf), MSG_DONTWAIT);
if (r_bytes2 > 0) {
printk("%s", recv_buf);
char splitStringstac[10][10];
split_string_ltepos(recv_buf,splitStringstac);
if (splitStringstac[0] == 0)
err = 1;
printk("Cant find LTE_M signal \n");
else {
printk("Found the LTE_M signal \n");
err =0;
printk("Closing socket\n\r");
//(void)close(at_socket_fd);
return err;
*name: app_socket_start
*todo: send the const char *at_commands[]
void app_socket_start(void)
printk("Starting simple AT socket application\n\r");
printk("Socket err: %d, errno: %d\r\n", at_socket_fd, errno);
for (int i = 0; i < ARRAY_SIZE(at_commands); i++) {
int bytes_written = send(at_socket_fd, at_commands[i],
strlen(at_commands[i]), 0);
if (bytes_written > 0) {
int r_bytes =
if (r_bytes > 0) {
*name: LTE_socket_com
*todo: send AT command
* use: LTE_socket_com("AT");
LTE_socket_com("AT+CPIN?");
*return:
void LTE_socket_com(const char *lte_at_cmd )
//printk("Starting simple AT socket application\n\r");
printk("AT cmd: %s \n\r",lte_at_cmd);
//for (int i = 0; i < ARRAY_SIZE(lte_at_cmd); i++) {
int bytes_written = send(at_socket_fd, lte_at_cmd, strlen(lte_at_cmd), 0);
int r_bytes =
if (r_bytes > 0) {
//printk("Closing socket\n\r");
*name: LTE_AT_position
*todo: find GMS position
*return: MCCMNC / LAC / CID
* MCC � a Mobile Country Code
* MNC - a Mobile Network Code
* LAC - Location Area Code
* CID : CellID
void LTE_AT_position(char *mccmnc,char *lac, char *cid )
const char *ATCOPS="AT+COPS?";
const char *ATREG2="AT+CEREG=2";
// printk("LTE socket is: %d \n",at_socket_fd);
* find MNC and MCC
int bytes_written0 = send(at_socket_fd, ATCOPS, strlen(ATCOPS), 0);
if (bytes_written0 > 0) {
int r_bytes =
if (r_bytes > 0) {
//printk("%s", recv_buf);
char splitStringsmcc[10][10];
split_string_ltepos(recv_buf,splitStringsmcc);
memcpy(mccmnc,splitStringsmcc[1],sizeof(splitStringsmcc[1]));
// printk("MCC&MNC: %s\n",mccmnc);
int bytes_written1 = send(at_socket_fd, ATREG2, strlen(ATREG2), 0);
if (bytes_written1 > 0) {
* find LAC and CID
if (r_bytes2 > 0) {
memcpy(lac,splitStringstac[1],sizeof(splitStringstac[1]));
memcpy(cid,splitStringstac[3],sizeof(splitStringstac[3]));
#define MAXLINE 4096
#define HTTP_HOST "142.93.37.192"
#define HTTP_PORT 7000
#define HTTP_PATH "/"
#define TEST_STRING "Hello from nRF9160 DK"
#define POST_TEMPLATE "POST %s? HTTP/1.1\r\n"\
"Host: %s\r\n"\
"Connection: keep-alive\r\n"\
"Content-type: application/x-www-form-urlencoded\r\n"\
"Content-length: %d\r\n\r\n"\
"%s"
*name: app_http_get:
*todo: HTTP GET from webserver: http://142.93.37.192
*return: return from HTTP GET
*use: app_http_get();
void app_http_get(void)
struct sockaddr_in local_addr;
struct addrinfo *res;
local_addr.sin_family = AF_INET;
local_addr.sin_port = htons(0);
local_addr.sin_addr.s_addr = 0;
printk("HTTP GET http://142.93.37.192 example\n\r");
int err = getaddrinfo(HTTP_HOST, NULL, NULL, &res);
printk("getaddrinfo err: %d\n\r", err);
((struct sockaddr_in *)res->ai_addr)->sin_port = htons(HTTP_PORT);
char send_buf[] =
"GET / HTTP/1.1\r\nHost: http://142.93.37.192:80\r\nConnection: close\r\n\r\n";
int send_data_len = strlen(send_buf);
int client_fd = socket(AF_INET, SOCK_STREAM, 0);
printk("client_fd: %d\n\r", client_fd);
err = bind(client_fd, (struct sockaddr *)&local_addr,
sizeof(local_addr));
printk("bind err: %d\n\r", err);
err = blocking_connect(client_fd, (struct sockaddr *)res->ai_addr,
sizeof(struct sockaddr_in));
printk("connect err: %d\n\r", err);
int num_bytes = send(client_fd, send_buf, send_data_len, 0);
printk("send err: %d\n\r", num_bytes);
num_bytes = blocking_recv(client_fd, recv_buf, RECV_BUF_SIZE, 0);
//printk("\n\rFinished. Closing socket");
//err = close(client_fd);
*name: app_http_post_bk
*todo: HTTP POST PostString[] to webserver http://142.93.37.192
*return:
* use:
void app_http_post(char *PostString)
//int err;
char send_buf[MAXLINE + 1];
int send_data_len_post = snprintf(send_buf,
500, /*total length should not exceed MTU size*/
POST_TEMPLATE, HTTP_PATH,
HTTP_HOST, strlen(PostString),
PostString);
printk("send err: %d\n\r", send_data_len_post);
// connect
//send
blocking_send(client_fd, send_buf, send_data_len_post, 0);
k_sleep(1000);
printk("\n\r HTTP POST Finished. \n\r");
close(client_fd);
int nRF_LTE_CLOSE(void)
int err;
err = close(at_socket_fd);
printk("Close the socket LTE_M \n");
return err;
#include <zephyr.h>
#include <math.h>
#include <uart.h>
#include <soc.h>
#include <gpio.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "lte_post_get.c"
void main (void)
printk("Test is starting \n");
while(1){
//CyCo_Hot_GSM_Handle();
int lte_err= nRF_LTE_check();
if(lte_err==0){ printk(" find LTE_M signal........... \n"); }
else{ printk(" Couldnt find LTE_M signal........... \n");}
k_sleep(2000);
The function returns "Not enough space" after a while. Increasing the delay did not help. Maybe you can try to keep the socket open rather than open and close it for every command.
void main (void)
while(1){
else{ printk(" Couldnt find LTE_M signal........... %s \n", strerror(errno));}
k_sleep(8000);
}Dear Vidar Berg
Ja, increasing the delay didn't help. Currently, the solution is: control the socket
Hng
Hi Vidar and Hoang,
Actually I want to do same simple HTTP post message to server, with this I am able to successfully run and flash merge.hex file into nRF91 DK. But unable to get signal strength I want to see all logs that we have printed in printk(); function.
To flash build into nRF91 DK is only sufficient to flash merge.hex or I need to flash also .elf file as well.
Thanks and looking forward your response..!!!
