How to make http post. No libcurl?
Hi, all!
Have nRF9160.
I'm using http sample as template to make http requests get/post. I send it without any lib to build requests.
I can't attach libcurl to nRF9160, and as I understand it is now impossible to using libcurl on nRF9160.
Maybe someone can suggest something to making http requests?
  • Hi Moshe,
    Can you share the code?
    thanks,
    hng
    I'm not sure if it's possible to port libcurl to nRF9160, but you can use the socket API to make HTTP requests. A colleague has made a HTTP example using the Socket API that's available here: https://github.com/Rallare/fw-nrfconnect-nrf/tree/nrf9160_samples/samples/nrf9160/http. This sample demonstrates how you can send a GET request. For POST requests you can use the following template along with snprintf/sprintf.
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    #define HTTP_HOST example.com
    #define HTTP_PATH <post url>
    #define TEST_STRING = "Hello from nrf91"
    #define POST_TEMPLATE "POST %s? HTTP/1.1\r\n"\
    "Host: %s\r\n"\
    "Connection: keep-alive\r\n"\
    "Content-Type: text/plain\r\n"\
    "Content-length: %d\r\n\r\n"\
    "%s"
    /*Prepare POST request*/
    send_data_len = snprintf(send_buf,
    500, /*total length should not exceed MTU size*/
    POST_TEMPLATE, HTTP_PATH,
    HTTP_HOST, strlen(TEST_STRING),
    TEST_STRING);
    /*Send post request*/
    blocking_send(client_fd, send_buf, send_data_len, 0);
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    Edit: defined TEST_STRING
  • Vidar,
    I'm trying you approach that seams very logical to me but somehow my call does not reach the database.
    I will have to cover up some aspects but I know that that side of the story is simply operational: the server is there and accepts POST REST calls of this organisation (SIGFOX is using this port to send my data to me)
    I just want to avoid someone to start jamming my port for fun.
    I did set up the connection parameters, using the right url and port 443.
    Set up a template to generate the POST code:
    #define POST_TEMPLATE "POST %s HTTP/1.1\r\nHost: %s\r\naccept-encoding: gzip, deflate \r\nConnection: keep-alive\r\nAccept: \*/\* \r\nContent-Type: application/json\r\nContent-length: %d\r\ncache-control: no-cache\r\n%s"
    which results in:
    POST /REST/MCS1608 HTTP/1.1
    Host: xxxxx.xxx
    Accept: */*
    Content-length: 79
    {"device": "D2078B","timestamp":"1563365148","data":"a318e451a084f800f9004e0d"}
    Next I created a function:
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    void app_http_post(void){
    struct sockaddr_in local_addr;
    struct addrinfo *res;
    local_addr.sin_family = AF_INET;
    local_addr.sin_port = htons(0);
    local_addr.sin_addr.s_addr = 0;
    printk("HTTP POST example\n\r");
    int err = getaddrinfo(HTTP_HOST, NULL, NULL, &res);
    printk("getaddrinfo err: %d\n\r", err);
    ((struct sockaddr_in *)res->ai_addr)->sin_port = htons(HTTP_PORT);
    char send_buf[500];
    snprintf(send_buf, 500, POST_TEMPLATE, HTTP_PATH, HTTP_HOST, strlen(TEST_STRING), TEST_STRING);
    int send_data_len = strlen(send_buf);
    printk("POST code:\n\r%s\n\n\r", send_buf);
    But I'm not sure whether all is OK as my POSTed information does not go through.
    I get no answer from the server (I know when something is wrong the server still answers with a fault code)
    send err: -1
    I tried with httpbin.org and there the result was the same: no result.
    with port 80 the result is the same, so I assume the problem is deeper than not being able to achieve an HTTPS call.
    Please try the http_post sample attached below and see if you get the same result. I used NCS v.1.0.0 and http://ptsv2.com as a test server.
    Received POST request:
    Project:
    http_post.zip
    I'd suggest that you create a new ticket for HTTPS as I don't have experience with it. Maybe this thread is helpful: https://devzone.nordicsemi.com/f/nordic-q-a/48202/https-sample/
  • HI, does this example work for thingy91 ?
1 2 3
