SDK V12.2.0 sleep mode issue
We have written an application based on SDK V12.2.0 using S132_V3.1.0 for the nRF52832 and have been dealing with an issue where the module constantly enters a hardfault. Unfortunately debugging is not an option as the problem seems to be resolved when using a debugger. I've stripped down our application to simply start scanning for peripherals and go to sleep in the main loop using sd_app_evt_wait, yet the issue persists.
The issue appears to be related to the scan interval as the module resets at exactly the scan interval time. Furthermore increasing/decreasing the scan interval changes the time after which the module goes through reset.
I've noticed that removing sd_app_evt_wait from code or replacing the call with __WFE resolves the issue. As far as my understanding goes sd_app_evt_wait and __WFE should have the exact same behavior. What is the difference between the 2 calls?
  • Hi
    Due to the Easter holiday you will have to expect a delay in replies, sorry for the inconvenience!
    Could you try adding an app_error_check, to see what values the interval timer function and sd_app_evt_wait returns? Only reason I see to why sd_app_evt_wait should cause a hard fault would be that the SoftDevice isn't initialized properly. How do you initialize the SoftDevice?
    Sidenote: SDK12.2 and S132_v3.1 are old, and you should consider updating both to a more recent update.
    Best regards and happy Easter,
    Simon
  • Hello Simon,
    Thank you for the reply. Let me clarify that it is not an interval timer we're using, but it is the interval on which the softdevice repeats a scan as defined by the scan parameters handed to the softdevice when starting scanning for peripherals.
    See the following segment where we initialize the softdevice:
        uint32_t err_code = NRF_SUCCESS;
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
    	/*Disable softdevice to delete any registered services,
        only a limited amount of services can be registered*/
        err_code = sd_softdevice_disable();
    	//Initialize the SoftDevice handler module.
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
    													PERIPHERAL_LINK_COUNT,
    													&ble_enable_params);
    	// Use the max config: 8 central, 0 periph, 10 VS UUID
        ble_enable_params.common_enable_params.vs_uuid_count = 10;
    	//Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
    	//Enable BLE stack.
    #if (NRF_SD_BLE_API_VERSION == 3)
        ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
        err_code = softdevice_enable(&ble_enable_params);
    	//Register with the SoftDevice handler module for BLE events.
        err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    	// Register with the SoftDevice handler module for BLE events.
        err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
    As for the app_error_check, we do include that with our call to sd_app_evt_wait. The problem however occurs before sd_app_evt_wait returns, either in interrupt context or within the softdevice itself.
    With kind regards,
    Pim
  • Hi
    I talked to my colleagues on the matter, and there has been an issue in very old SDKs where MWU violations won't be handled while an application is in a critical section, and causes this hard fault.
    The fix should be to replace __NRF_NVIC_SD_IRQS_1 with the following in nrf_nvic.h, and recompile the application:
    #define __NRF_NVIC_SD_IRQS_1 ((uint32_t)(1U << (MWU_IRQn - 32)))
    This will cause the MWU handler to not be masked by the critical section, and thus be run at the correct time.
    Simon
