pc-ble-driver bonding with LESC succeeded (BLE_GAP_SEC_STATUS_SUCCESS) but get invalid encryption information
I am trying to implement LESC Security Mode 1 Level 4 with a peripheral ble_app_hrs on PCA10040 and a central via pc-ble-driver example heart_rate_collector_v6 with PCA10040.
I am using pc-ble-driver latest version. I compiled the connectivity firmware from source and load connectivity_<version>_1m_with_s132_6.1.1.hex onto serialization PCA10040.
The peripheral device is implemented as mentioned here.
I am following Central LESC for hear rate collector example:
  Bonding: Passkey Entry: User Inputs on Central
The heart_rate_collector example modification is here:
(Updated on 2019-04-16 with fix to passkey entry):
/cfs-file/__key/support-attachments/beef5d1b77644c448dabff31668f3a47-226eb83e350846778d6a5ac3302b24ec/HRSC_2D00_Third_2D00_party_2D00_light_2D00_LESC_2D00_impl_2D00_master.patch
Strangely, every time after I get BLE_GAP_SEC_STATUS_SUCCESS, I found kdist_own value is changing all the time. The value can be anything, e.g. 0x00, 0x30, 0x40, 0x60, 0x70, 0x80, 0xc0, 0xc0, 0xf0, etc.
Update on 2019-05-13 with fix to unstable BLE_GAP_EVT_AUTH_STATUS returning values:
HRSC-Third-party-light-LESC-impl-master.patch
And I only get ble_gap_enc_key_t (LTK and so on) information with only zero values.
An example log:
$ ./heart_rate_collector_sd_api_v6 /dev/ttyACM0
Serial port used: /dev/ttyACM0
Baud rate used: 1000000
Info: Successfully opened /dev/ttyACM0. Baud rate: 1000000. Flow control: none. Parity: none.
SDH: Status: 6, message: Target Reset performed
SDH: Status: 7, message: Connection active
Scan started
Received BLE_GAP_EVT_ADV_REPORT with device address: 0xCB76125C099D
Connection established
Received BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST. Reply with 247
Received BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST. Peer data length is:
	max_rx_octets = 251
	max_tx_octets = 251
	max_rx_time = 2120
	max_tx_time = 2120
Received BLE_GAP_EVT_DATA_LENGTH_UPDATE (157, max_rx_time 1370).
sd_ble_gap_authenticate succeeded
Received BLE_GAP_EVT_SEC_PARAMS_REQUEST
uECC PK own "m_lesc_pk_own(keyset_pointer)":
53(53)	176(176)	227(227)	134(134)	192(192)	182(182)	152(152)	104(104)	144(144)	59(59)	164(164)	248(248)	45(45)	54(54)	216(216)	245(245)	243(243)	114(114)	5(5)	137(137)	175(175)	5(5)	93(93)	215(215)	150(150)	62(62)	160(160)	110(110)	148(148)	142(142)	74(74)	107(107)	72(72)	119(119)	84(84)	253(253)	247(247)	243(243)	57(57)	115(115)	73(73)	142(142)	125(125)	82(82)	18(18)	22(22)	35(35)	229(229)	174(174)	198(198)	184(184)	152(152)	45(45)	137(137)	61(61)	123(123)	109(109)	41(41)	120(120)	169(169)	52(52)	188(188)	75(75)	139(139)
SK own:
111	201	75	248	121	184	84	213	111	54	63	45	152	34	229	82	32	134	100	229	6	37	25144	69	41	246	107	41	121	162	47
Security parameters replied.
BLE_GAP_EVT_AUTH_KEY_REQUEST received.
Enter passkey:
890975
Enter passkey again:
Got passkey: 890975
Authentication passkey replied.
Received BLE_GAP_EVT_LESC_DHKEY_REQUEST
PK Peer:
108	41	67	129	227	11	160	54	97	160	221	138	21	166	181	217	14	25	45	189	208	97	52	225	91	25	221	46	61	5	235	85	16	95	229	176	172	89	154	168	199	220	91	22	138	122173	188	57	73	5	148	183	178	107	96	139	237	164	115	250	158	22	152
DHKey:
148	232	74	125	19	144	198	34	192	2	236	188	113	11	151	28	95	216	40	45	162	124	21422	140	176	248	124	217	157	68	249
LESC DHkey replied.
BLE_GAP_EVT_CONN_SEC_UPDATE: Security mode: 1. Security level: 4
Security level high enough to enable BAS notifications.
BLE_GAP_EVT_AUTH_STATUS: status=0x0 bond=0x1 lv4: 1 kdist_own:0x0 kdist_peer:0x0
Authorization succeeded!
Own	LTK:
	0	0	0	0	0	0	0	0	0	0	0	0	0	0	0	0
	EDIV:
	0
	RAND:
	0	0	0	0	0	0	0	0
Peer	LTK:
	EDIV:
	0
	RAND:
	0	0	0	0	0	0	0	0
Discovering primary services
Received BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP
Discovered heart rate service. UUID: 0x180D, start handle: 0x000E, end handle: 0x0013
Discovering characteristics
Received BLE_GATTC_EVT_CHAR_DISC_RSP, characteristics count: 2
Characteristic handle: 0x000F, UUID: 0x2A37
Characteristic handle: 0x0012, UUID: 0x2A38
Discovering characteristic's descriptors
Received BLE_GATTC_EVT_DESC_DISC_RSP, descriptor count: 5
Descriptor handle: 0x000F, UUID: 0x2803
Descriptor handle: 0x0010, UUID: 0x2A37
Descriptor handle: 0x0011, UUID: 0x2902
Press 't' to toggle notifications on the HRM characteristic
Descriptor handle: 0x0012, UUID: 0x2803
Descriptor handle: 0x0013, UUID: 0x2A38
Can anyone kindly help me how to properly fetch ble_gap_enc_key_t (LTK) information after the bonding procedure seems successful so that I can store it in the file system?
Thanks & best regards,
Chencheng
