nrf24l01+ crc problem
I have been using nRF24 in many projects with Arduino. So far quite good experience.
Now I transfer to STM32 and have a strange problem, I cannot send with STM32 as MCU as soon as CRC is active (receive works fine). When I disable CRC (and of course Auto_ack off) everything works fine, stable and fast. As soon as I enable CRC only very view packages come through. I checked CRC length, payload length and all relevant registers on TX / RX device several times, have tried different modules from different sources, with power supply and tested different SPI configurations (although it looks fine, I can write and read registers reliably). Result always the same. I do not use any library on STM and the RF24  library by TMRh20 on Arduino. I have compared all possible register settings on both systems.
Currently I`m running on a STM32F407ZGT, use CubeMX (several versions tested) with HAL (several libraries tested).
I understand that the question for help is a bit abstract in that case, but what can go wrong when calculating CRC and how can I check / fix?
Thanks!
