Migration from SDK 14.2.0 to 15.3.0, nrf_drv_uart.h:127:13: error: unknown type name 'nrf_uarte_baudrate_t'
I'm migrating a project from SDK 14.2.0 to SDK 15.3.0 and using the UART (not the UARTE). I want to use the legacy UART driver. I'm hitting these errors when compiling
app_uart_fifo.c, which includes nrf_drv_uart.h:
Compiling file: app_uart_fifo.c
In file included from /usr/local/nRF5_SDK_15.3.0_59ac345/components/libraries/uart/app_uart_fifo.c:44:0:
/usr/local/nRF5_SDK_15.3.0_59ac345/integration/nrfx/legacy/nrf_drv_uart.h:127:13: error: unknown type name 'nrf_uarte_baudrate_t'
     typedef nrf_uarte_baudrate_t        nrf_uart_baudrate_t;
/usr/local/nRF5_SDK_15.3.0_59ac345/integration/nrfx/legacy/nrf_drv_uart.h:132:13: error: unknown type name 'nrf_uarte_error_mask_t'
     typedef nrf_uarte_error_mask_t      nrf_uart_error_mask_t;
/usr/local/nRF5_SDK_15.3.0_59ac345/integration/nrfx/legacy/nrf_drv_uart.h:135:13: error: unknown type name 'nrf_uarte_hwfc_t'
     typedef nrf_uarte_hwfc_t            nrf_uart_hwfc_t;
/usr/local/nRF5_SDK_15.3.0_59ac345/integration/nrfx/legacy/nrf_drv_uart.h:138:13: error: unknown type name 'nrf_uarte_parity_t'
     typedef nrf_uarte_parity_t          nrf_uart_parity_t;
/usr/local/nRF5_SDK_15.3.0_59ac345/integration/nrfx/legacy/nrf_drv_uart.h:139:13: error: unknown type name 'nrf_uarte_task_t'
     typedef nrf_uarte_task_t            nrf_uart_task_t;
/usr/local/nRF5_SDK_15.3.0_59ac345/integration/nrfx/legacy/nrf_drv_uart.h:140:13: error: unknown type name 'nrf_uarte_event_t'
     typedef nrf_uarte_event_t           nrf_uart_event_t;
/usr/local/nRF5_SDK_15.3.0_59ac345/components/libraries/uart/app_uart_fifo.c: In function 'app_uart_init':
/usr/local/nRF5_SDK_15.3.0_59ac345/integration/nrfx/legacy/nrf_drv_uart.h:141:41: error: 'NRF_UARTE_PSEL_DISCONNECTED' undeclared (first use in this function); did you mean 'NRF_UART_PSEL_DISCONNECTED'?
     #define NRF_UART_PSEL_DISCONNECTED  NRF_UARTE_PSEL_DISCONNECTED
/usr/local/nRF5_SDK_15.3.0_59ac345/integration/nrfx/legacy/nrf_drv_uart.h:217:27: note: in expansion of macro 'NRF_UART_PSEL_DISCONNECTED'
     .pseltxd            = NRF_UART_PSEL_DISCONNECTED,                        \
/usr/local/nRF5_SDK_15.3.0_59ac345/components/libraries/uart/app_uart_fifo.c:151:36: note: in expansion of macro 'NRF_DRV_UART_DEFAULT_CONFIG'
     nrf_drv_uart_config_t config = NRF_DRV_UART_DEFAULT_CONFIG;
/usr/local/nRF5_SDK_15.3.0_59ac345/integration/nrfx/legacy/nrf_drv_uart.h:141:41: note: each undeclared identifier is reported only once for each function it appears in
/usr/local/nRF5_SDK_15.3.0_59ac345/integration/nrfx/legacy/nrf_drv_uart.h:133:41: error: 'NRF_UARTE_HWFC_DISABLED' undeclared (first use in this function); did you mean 'NRF_UART_HWFC_DISABLED'?
     #define NRF_UART_HWFC_DISABLED      NRF_UARTE_HWFC_DISABLED
/usr/local/nRF5_SDK_15.3.0_59ac345/components/libraries/uart/app_uart_fifo.c:154:13: note: in expansion of macro 'NRF_UART_HWFC_DISABLED'
             NRF_UART_HWFC_DISABLED : NRF_UART_HWFC_ENABLED;
/usr/local/nRF5_SDK_15.3.0_59ac345/integration/nrfx/legacy/nrf_drv_uart.h:134:41: error: 'NRF_UARTE_HWFC_ENABLED' undeclared (first use in this function); did you mean 'NRF_UART_HWFC_ENABLED'?
     #define NRF_UART_HWFC_ENABLED       NRF_UARTE_HWFC_ENABLED
/usr/local/nRF5_SDK_15.3.0_59ac345/components/libraries/uart/app_uart_fifo.c:154:38: note: in expansion of macro 'NRF_UART_HWFC_ENABLED'
/usr/local/nRF5_SDK_15.3.0_59ac345/integration/nrfx/legacy/nrf_drv_uart.h:137:41: error: 'NRF_UARTE_PARITY_INCLUDED' undeclared (first use in this function); did you mean 'NRF_UART_PARITY_INCLUDED'?
     #define NRF_UART_PARITY_INCLUDED    NRF_UARTE_PARITY_INCLUDED
/usr/local/nRF5_SDK_15.3.0_59ac345/components/libraries/uart/app_uart_fifo.c:156:49: note: in expansion of macro 'NRF_UART_PARITY_INCLUDED'
     config.parity = p_comm_params->use_parity ? NRF_UART_PARITY_INCLUDED : NRF_UART_PARITY_EXCLUDED;
/usr/local/nRF5_SDK_15.3.0_59ac345/integration/nrfx/legacy/nrf_drv_uart.h:136:41: error: 'NRF_UARTE_PARITY_EXCLUDED' undeclared (first use in this function); did you mean 'NRF_UART_PARITY_EXCLUDED'?
     #define NRF_UART_PARITY_EXCLUDED    NRF_UARTE_PARITY_EXCLUDED
/usr/local/nRF5_SDK_15.3.0_59ac345/components/libraries/uart/app_uart_fifo.c:156:76: note: in expansion of macro 'NRF_UART_PARITY_EXCLUDED'
make: *** [_build/app/app_uart_fifo.c.o] Error 1
This seems to be because NRFX_CHECK(NRFX_UART_ENABLED) evaluates to false. So I added a pragma like this:
#define STR_HELPER(x) #x
#define STR(x) STR_HELPER(x)
#pragma message "NRFX_UART_ENABLED: " STR(NRFX_UART_ENABLED)
Which gives me:
/usr/local/nRF5_SDK_15.3.0_59ac345/integration/nrfx/legacy/nrf_drv_uart.h:49:9: note: #pragma message: NRFX_UART_ENABLED: (1 && (0 && 1))
I have no idea where that 0 is coming from. apply_old_confog.h has only this to say about it:
#if defined(UART_ENABLED)
#undef NRFX_UART_ENABLED
#define NRFX_UART_ENABLED (UART_ENABLED && NRFX_UART0_ENABLED)
My sdk_config.h is simply <SDK>/config/nrf52832/config/sdk_config.h - I don't have one in my own project. Instead I have an app_config.h in my own project and that looks like this:
#define UART_ENABLED 1
#define NRFX_UART_ENABLED 1
#define NRFX_UART0_ENABLED 1
#define NRFX_UARTE_ENABLED 0
#define NRFX_UARTE0_ENABLED 0
#define UART0_USE_EASY_DMA false
#define UART_EASY_DMA_SUPPORT 0
#define UART_LEGACY_SUPPORT 1
I know app_config.h is being seen by the preprocessor, because an #error added to it will be hit.
