CRC problem in my customize DFU Controller (nrfutil)
For some reasons, I would like to write my own application for updating the firmware, something like NRFUTIL application.
I wrote it and everything is working fine but in case of CRC failure my target device stuck somewhere and I should restart it manually to continue updating from the last part.
For updating the firmware first I send select command and get the last offset and CRC and if CRC is correct I can continue updating without any problem, but in case of CRC failure, I do not know what should I do to remove the last object that I create. I tried to send Execute command but it is not working.
I think I should send a special command in case of CRC failure to clear the last object which causes the CRC failure but I do not know what is this command!
So could you please let me know what should I do to fix this issue?
Thank you in advance.
    It should be sufficient to issue a new NRF_DFU_OP_OBJECT_CREATE() request. According to the documentation, this will reset the progress since the last Execute command.
    Vidar
  • Thank you for your answer.
    I did this but unfortunately, it is not working.
    when I get CRC error, I execute NRF_DFU_OP_OBJECT_CREATE() function but it is still not working.
    the problem is that after I get CRC error I call NRF_DFU_OBJECT_OP_SELECT and for example it returns this array:
    06, 01, 00, 10, 00, 00, c1, 7f, 00, 00, 75, 1d, c3, e5, c0,
    but it should be:
    06, 01, 00, 10, 00, 00, 00, 70, 00, 00, 47, 91, 6c, b0, c0,
    the CRC of the 0x00007fC1 is not correct but for 0x00007000 is correct.
    when I reset the target manually it is working and I get the second array which is the correct answer.
    This was not the result I expected. When you get the CRC error, do you send NRF_DFU_OP_OBJECT_CREATE() followed by NRF_DFU_OBJECT_OP_SELECT()? Another option may be to simply resend the init packet command, this should let you restart DFU the upload.
  • I think finally I found the problem!, the problem was when I got the CRC error, I started sending from the beginning of the firmware again!, but I should send data from the last correct offset.
    now it is working in all situations.
    Thank you for helping me.
