I'm looking to test the DPPI peripheral on the dev-kit, and to that end I though a good example would be to setup the DPPI peripheral to trigger an event when a button is pushed, and toggle the output to one of the LEDs.
I'm having trouble getting my example to do anything though, and I can't find anymore settings in the datasheet or the nrfx drivers to show what configuration I am missing.
My attempt at this is below:
#include <zephyr.h>
#include <hal/nrf_gpiote.h>
#include <hal/nrf_dppi.h>
#define PUBLISH_EVENT_INDEX (0)
#define SUBSCRIBE_TASK_INDEX (1)
#define DPPI_CHANNEL (0)
/** @brief Set bit at given position. */
#define DPPI_BIT_SET(pos) (1uL << (pos))
void main(void) {
printk("The sample has started\n");
/* Configure GPIOTE Index 0 to be an Event */
nrf_gpiote_event_configure(PUBLISH_EVENT_INDEX,SW0_GPIO_PIN,NRF_GPIOTE_POLARITY_HITOLO);
/* Configure GPIOTE Index 1 to be a Task*/
nrf_gpiote_task_configure(SUBSCRIBE_TASK_INDEX,LED3_GPIO_PIN,NRF_GPIOTE_POLARITY_TOGGLE,NRF_GPIOTE_INITIAL_VALUE_LOW);
/* Index 0 will Publish on DPPI Channel 0 */
nrf_gpiote_publish_set(NRF_GPIOTE_EVENTS_IN_0,DPPI_CHANNEL);
/* Index 1 will Subscribe on DPPI Channel 0 */
nrf_gpiote_subscribe_set(NRF_GPIOTE_TASKS_OUT_1,DPPI_CHANNEL);
/* Enable Publish and Subscribe */
nrf_gpiote_event_enable(PUBLISH_EVENT_INDEX);
nrf_gpiote_task_enable(SUBSCRIBE_TASK_INDEX);
/* Enable DPPI Channel */
nrf_dppi_channels_enable(NRF_DPPIC, DPPI_BIT_SET(DPPI_CHANNEL));
/* Validate things did get enabled */
printk("[0] is %d\n",nrf_gpiote_te_is_enabled(PUBLISH_EVENT_INDEX));
printk("[1] is %d\n",nrf_gpiote_te_is_enabled(SUBSCRIBE_TASK_INDEX));
printk("[2] is %d\n",nrf_dppi_channel_check(NRF_DPPIC,DPPI_CHANNEL));
I also modified the Secure Bootloader to set the DPPI peripheral to Unsecure, and to also unlock all of the DPPI channels by adding this line to the spm.c file:
NRF_SPU->DPPI[0].PERM = 0; // unsecures all
Before I did that the "nrf_dppi_channel_check" would return false (which is what it is supposed to do).
A full example run (showing the bootloader as well) looks like this:
***** Booting Zephyr OS v1.13.99-ncs1-5781-g1937b41459ca ***** Flash region Domain Permissions 00 0x00000 0x02000 Secure rwxl 01 0x02000 0x04000 Secure rwxl 02 0x04000 0x06000 Secure rwxl 03 0x06000 0x08000 Secure rwxl 04 0x08000 0x0a000 Secure rwxl 05 0x0a000 0x0c000 Secure rwxl 06 0x0c000 0x0e000 Secure rwxl 07 0x0e000 0x10000 Secure rwxl 08 0x10000 0x12000 Non-Secure rwxl 09 0x12000 0x14000 Non-Secure rwxl 10 0x14000 0x16000 Non-Secure rwxl 11 0x16000 0x18000 Non-Secure rwxl 12 0x18000 0x1a000 Non-Secure rwxl 13 0x1a000 0x1c000 Non-Secure rwxl 14 0x1c000 0x1e000 Non-Secure rwxl 15 0x1e000 0x20000 Non-Secure rwxl 16 0x20000 0x22000 Non-Secure rwxl 17 0x22000 0x24000 Non-Secure rwxl 18 0x24000 0x26000 Non-Secure rwxl 19 0x26000 0x28000 Non-Secure rwxl 20 0x28000 0x2a000 Non-Secure rwxl 21 0x2a000 0x2c000 Non-Secure rwxl 22 0x2c000 0x2e000 Non-Secure rwxl 23 0x2e000 0x30000 Non-Secure rwxl 24 0x30000 0x32000 Non-Secure rwxl 25 0x32000 0x34000 Non-Secure rwxl 26 0x34000 0x36000 Non-Secure rwxl 27 0x36000 0x38000 Non-Secure rwxl 28 0x38000 0x3a000 Non-Secure rwxl 29 0x3a000 0x3c000 Non-Secure rwxl 30 0x3c000 0x3e000 Non-Secure rwxl 31 0x3e000 0x40000 Non-Secure rwxl SRAM region Domain Permissions 00 0x00000 0x01000 Secure rwxl 01 0x01000 0x02000 Secure rwxl 02 0x02000 0x03000 Secure rwxl 03 0x03000 0x04000 Secure rwxl 04 0x04000 0x05000 Secure rwxl 05 0x05000 0x06000 Secure rwxl 06 0x06000 0x07000 Secure rwxl 07 0x07000 0x08000 Secure rwxl 08 0x08000 0x09000 Non-Secure rwxl 09 0x09000 0x0a000 Non-Secure rwxl 10 0x0a000 0x0b000 Non-Secure rwxl 11 0x0b000 0x0c000 Non-Secure rwxl 12 0x0c000 0x0d000 Non-Secure rwxl 13 0x0d000 0x0e000 Non-Secure rwxl 14 0x0e000 0x0f000 Non-Secure rwxl 15 0x0f000 0x10000 Non-Secure rwxl 16 0x10000 0x11000 Non-Secure rwxl 17 0x11000 0x12000 Non-Secure rwxl 18 0x12000 0x13000 Non-Secure rwxl 19 0x13000 0x14000 Non-Secure rwxl 20 0x14000 0x15000 Non-Secure rwxl 21 0x15000 0x16000 Non-Secure rwxl 22 0x16000 0x17000 Non-Secure rwxl 23 0x17000 0x18000 Non-Secure rwxl 24 0x18000 0x19000 Non-Secure rwxl 25 0x19000 0x1a000 Non-Secure rwxl 26 0x1a000 0x1b000 Non-Secure rwxl 27 0x1b000 0x1c000 Non-Secure rwxl 28 0x1c000 0x1d000 Non-Secure rwxl 29 0x1d000 0x1e000 Non-Secure rwxl 30 0x1e000 0x1f000 Non-Secure rwxl 31 0x1f000 0x20000 Non-Secure rwxl DPPI NONSECURE Peripheral Domain Status 00 NRF_P0 Non-Secure OK 01 NRF_CLOCK Non-Secure OK 02 NRF_RTC1 Non-Secure OK 03 NRF_NVMC Non-Secure OK 04 NRF_UARTE1 Non-Secure OK 05 NRF_UARTE2 Secure SKIP 06 NRF_IPC Non-Secure OK 07 NRF_VMC Non-Secure OK 08 NRF_FPU Non-Secure ERROR 09 NRF_EGU1 Non-Secure OK 10 NRF_EGU2 Non-Secure OK 11 NRF_TWIM2 Non-Secure OK 12 NRF_SPIM3 Non-Secure OK 13 NRF_TIMER0 Non-Secure OK 14 NRF_TIMER1 Non-Secure OK 15 NRF_TIMER2 Non-Secure OK 16 NRF_SAADC Non-Secure OK 17 NRF_DPPI Non-Secure OK 18 NRF_GPIOTE1 Non-Secure OK SPM: MSP_NS 20021570 SPM: prepare to jump to Non-Secure image ***** Booting Zephyr OS v1.13.99-ncs1-5781-g1937b41459ca ***** The sample has started [0] is 1 [1] is 1 [2] is 1
Any thoughts on what I am missing?
Thank you so much!
