How decode RSSI message
I use the NRF 24AP2E in my communications, and I need detect if the communication is good. I active the RSSI message, but in scanning mode I don't receive byte 0x20 in Measurement Type (in ANT protocol information indicates that the RSSI value field shield not be interpreted), horever I see the values change because the proximity of devices.
The procedure that I do is the following:
0001 -TX- A40342004000A5 - Assign Channel
0002 -RX- A40340004200A5
0003 -TX- A405510000000503F6 - Channel ID
0004 -RX- A40340005100B6
0005 -TX- A4026E00C008 - ListLib
0006 -RX- A40340006E0089
0007 -TX- A402450003E0 - Channel RF Frequency
0008 -RX- A40340004500A2
0009 -TX- A4015B00FE - Open Rx Scan Mode
000A -RX- A40340005B00BC
000B -RX- A4124E000000000000000000C00046050310016C0005
000C -RX- A4124E000000000000000000C00043050310016D0001
000D -RX- A4124E000000000000000000C00045050310016D0007
000E -RX- A4124E000000000000000000C0004405031000690003
000F -RX- A4124E000000000000000000C00046050310016C0005
0010 -RX- A4124E000000000000000000C00043050310016D0001
0011 -RX- A4124E000000000000000000C00045050310016D0007
0012 -RX- A4124E000000000000000000C0004405031000690003
0013 -RX- A4124E000000000000000000C00046050310016C0005
0014 -RX- A4124E000000000000000000C00043050310016D0001
0015 -RX- A4124E000000000000000000C00045050310016D0007
0016 -RX- A4124E000000000000000000C0004405031000690003
0017 -RX- A4124E000000000000000000C00046050310016C0005
0018 -RX- A4124E000000000000000000C00043050310016D0001
0019 -RX- A4124E000000000000000000C00045050310016D0007
001A -RX- A4124E000000000000000000C0004405031000680002
I receive value 10-01-6C-00, 10 represent measurement type, 01 is RSSI value and 6C is Threshold Configuration, and 00 I don't know, can explain the values?
I see the values of RSSI is beetween 0(closest device) and 1(farthest device), and Threshold Configuration beetween 68(closest device) and 6D(farthest device).
What is the correct procedure to obtain the values ​​of RSSI?
