execution profiling
     we are developing on the nrf52840 using SES and SDK 15.0. This is a custom board. Softdevice is s140_nrf52_6.0.0_softdevice.hex
We are sampling distance with vl53l0x chips. The chips are sampled in a loop and the results smoothed and then written to a service characteristic. The aim is to achieve the cycle within 20ms/50hz. We have an implementation working on another chipset but are having trouble porting to the nrf52.
for(;;) {
//int32_t tick_st = rtc_get_tick();
       startTime = RTC_TICKS_TO_MS(rtc_get_tick(), RTC_FREQ_TICK);
       if (sched_get_state() != SCHED_TOP_ST_SAMPLING) {
           NRF_LOG_INFO("NOT IN SAMPLING STATE");
       // enter loop every 20ms
       if (lastTime_ == 0)
          lastTime_ = startTime;
       if (startTime >= lastTime_ + 20 ) {
flex_DebugData(2, startTime - lastTime_);
          ** get the range data from the chip
The real time counter - rtc functions above - is set to milliseconds.
#define RTC_FREQ_TICK 1000
/** @brief Function initialization and configuration of RTC driver instance for ticks.
void rtc_config_tick(void)
    uint32_t err_code;
    if (!is_uninit) {
       nrfx_rtc_disable(&rtc);
       nrfx_rtc_uninit(&rtc);
    // get the crystal buzzing
    /// The clock is also used by the softdevice. Depending on what else is started we may or may not have to start it
    if (!nrfx_clock_lfclk_is_running())
       lfclk_config();
    //Initialize RTC instance
    nrfx_rtc_config_t config = NRFX_RTC_DEFAULT_CONFIG;
    config.prescaler = RTC_FREQ_TO_PRESCALER(RTC_FREQ_TICK);
    err_code = nrfx_rtc_init(&rtc, &config, rtc_handler);
    is_uninit = false;
    //Enable tick event & interrupt
    nrfx_rtc_tick_enable(&rtc,true);
    // enable over flow event
    nrfx_rtc_overflow_enable(&rtc, true);
    //set the counter to 0
    nrfx_rtc_counter_clear(&rtc);
    //Power on RTC instance
    nrfx_rtc_enable(&rtc);
The measurement point at flex_DebugData(2, startTime - lastTime_) shows a time of 37 to 38ms. It is unclear where the extra 17 - 18ms is used. It should be noted that on a test run, this value starts at 20ms and then slowly creeps up until it sits fairly steady at the 37 to 38ms.
While in the loop there are a steady stream of writes to a service characteristic. This characteristic is set with notify enabled. You also have a bunch of writes to another characteristic with notify enabled for debug writes.
I am not sure how to track down where the extra 17-18ms is coming from - I would guess the softdevice servicing the characteristic writes but am not sure.
Any pointers would be greatly appreciated.
Cheers Paul
  • Hello Paul,
    It is a bit difficult to say without knowing what you do inside your flex_DebugData(), and what other tasks your application is doing. Is there any more relevant information you can share?
    Where are you sending data over BLE?
    Without knowing anything about your application, from a power consumption point of view, it doesn't look like you ever let your chip go to sleep. I don't know whether this is a concern for you.
    Edvin
  • hi Edvin,
                    In trying to resolve this I simplified the code down. The for loop is not timer/interrupt driven - just normal flow of execution. It should enter the third if statement every 20ms unless something that is timer/interrupt driven is taking a long time. The flex_debugdata call simply writes that value - lastTime_ - startTime to a characteristic for debug purposes. It should be 20. However at steady state it is 37 - 38 hence the 17 to 18 ms lost.
    I finally found where this extra time was going. Seems I had a couple of SDH logs enabled. With these switched off, the measurement timing comes back to 51.2hz or ~20ms
    Thanks for your help
    Paul
