I am using SDK 15.2 with Segger Studio 4.10
I am trying to use the same button for sleep mode and wake up. I am doing a long press for sleep and sense wake up.
I am able to put it into sleep mode, but as soon as I let go it wakes up, is there something I can do to delay it, or lacth it for when it goes to sleep?
Here is the snippet for what I am doing.
void button_timerout_handler(void * p_context) { uint32_t err_code; static uint32_t cnt; if(app_button_is_pushed(0)) { cnt++; if(cnt >= LONG_PRESS(LONG_PRESS_WAIT)) { cnt = 0; NRF_LOG_INFO("Long Press"); // prepare wake up button nrf_gpio_cfg_sense_input(BUTTON_PIN_4, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW); // Go to system-off mode (this function will not return; wakeup will cause a reset). err_code = sd_power_system_off(); APP_ERROR_CHECK(err_code); } else { err_code = app_timer_start(m_button_action, APP_TIMER_TICKS(BUTTON_STATE_POLL_INTERVAL_MS), NULL); APP_ERROR_CHECK(err_code); } } else { cnt = 0; NRF_LOG_INFO("Short Press"); } } static void button_event_handler(uint8_t pin_no, uint8_t action) { uint32_t err_code; if((pin_no == BUTTON_PIN_4) && (action == APP_BUTTON_PUSH)) { err_code = app_timer_start(m_button_action, APP_TIMER_TICKS(BUTTON_STATE_POLL_INTERVAL_MS), NULL); APP_ERROR_CHECK(err_code); NRF_LOG_INFO("Button Pressed!"); } } static const app_button_cfg_t buttons[NUM_BUTTONS] = { {BUTTON_PIN_4, APP_BUTTON_ACTIVE_HIGH, NRF_GPIO_PIN_PULLUP, button_event_handler}, }; static void button_init(void){ uint32_t err_code; err_code = app_button_init((app_button_cfg_t *)buttons, NUM_BUTTONS, BUTTON_DELAY); APP_ERROR_CHECK(err_code); err_code = app_button_enable(); APP_ERROR_CHECK(err_code); // Enable timer for long button press detect err_code = app_timer_create(&m_button_action, APP_TIMER_MODE_SINGLE_SHOT, button_timerout_handler); APP_ERROR_CHECK(err_code); }
Thank you for the help.
