Adding custom service UUID in pc_ble_driver_py
Hi
I made a custom service for sending radar data from a NRF52 DK and I'm trying to access it with my computer using the pc_ble_driver_py.
I tried to modify the heart_rate_collector.py example to fit my application, but I am not able to add my custom service UUID.  I followed a similar thread regarding the same issue(How to write to a custom 128 UUID service using pc-ble-driver-py), but it does not work.
I get the error:
  File "C:\Users\akkvj\Anaconda2\lib\site-packages\pc_ble_driver_py\ble_adapter.py", line 254, in enable_notification
raise NordicSemiException('CCCD not found')
pc_ble_driver_py.exceptions.NordicSemiException: CCCD not found
Can you explain how I can modify the heart rate example to enable my custom service? The data I'm transferring are very similar to heart-rate data.
I'm using Anaconda python distribution package and a nRF52840 DK.
Thank you very much
Aksel
  • I figured out what was wrong:
    Decleared BASE_UUID in the init
    BASE_UUID = BLEUUIDBase([0xAD, 0x4A, 0x00, 0x41, 0x55, 0x62, 0x41, 0x12, 0x9A, 0xA8, 0x0A, 0xA2, 0x3D, 0x0C, 0xE5, 0x7A])
    This needs to be the big-endian version of what is written on the client.
    Then the UUID that is going to be notifying
    X4_UUID = BLEUUID(0x0041, BASE_UUID)
    Add it by writing:
    self.adapter.driver.ble_vs_uuid_add(BASE_UUID)
    under the line
    self.adapter.driver.ble_enable(ble_enable_params)
    Then enable notification on X4_UUID
    self.adapter.enable_notification(new_conn, X4_UUID)
    I know this is basically the same as written in other threads, but I just wanted to explain what i did before closing the thread.
  • Hi Aksel
    Sorry for the late reply but I have been out of office travelling this week. I'm glad you were able to figure it out on your own!
    Simon
  • Hi, I'm having the same problem, and I'm having other problems with this method.
    import sys
    import time
    import logging
    from queue import Queue, Empty
    from pc_ble_driver_py.observers import *
    from serial import Serial
    import serial.tools.list_ports
    TARGET_DEV_NAME = "GACYF000006037ECB2E4"
    CONNECTIONS = 1
    CFG_TAG = 1
    def init(conn_ic_id):
        # noinspection PyGlobalUndefined
        global config, BLEDriver, BLEAdvData, BLEEvtID, BLEAdapter, BLEEnableParams, BLEGapTimeoutSrc, BLEUUID, BLEUUIDBase, BLEConfigCommon, BLEConfig, BLEConfigConnGatt, BLEGapScanParams
        from pc_ble_driver_py import config
        config.__conn_ic_id__ = conn_ic_id
        # noinspection PyUnresolvedReferences
        from pc_ble_driver_py.ble_driver import (
            BLEDriver,
            BLEAdvData,
            BLEEvtID,
            BLEEnableParams,
            BLEGapTimeoutSrc,
            BLEUUID,
            BLEGapScanParams,
            BLEConfigCommon,
            BLEConfig,
            BLEConfigConnGatt,
            BLEUUIDBase
        from pc_ble_driver_py.ble_adapter import BLEAdapter
        global nrf_sd_ble_api_ver
        nrf_sd_ble_api_ver = config.sd_api_ver_get()
        # logging.debug("api version" + nrf_sd_ble_api_ver)
    class HRCollector(BLEDriverObserver, BLEAdapterObserver):
        def __init__(self, adapter):
            super(HRCollector, self).__init__()
            self.adapter = adapter
            self.conn_q = Queue()
            self.adapter.observer_register(self)
            self.adapter.driver.observer_register(self)
            self.adapter.default_mtu = 250
            self.localName = ""
            self.address_Str = TARGET_DEV_NAME
            self.advData = ""
            [0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x80, 0x00, 0x00, 0x80, 0x5F, 0x9B, 0x34, 0xFB])
        kVCKServiceStatusCharacteristicUUID = BLEUUID(0xFFE1, BASE_UUID)
        kVCKServiceNotifyCharacteristicUUID = BLEUUID(0xFFF2, BASE_UUID)
        #pyth
        def open(self):
            self.adapter.driver.open()
            if config.__conn_ic_id__ == "NRF51":
                    BLEEnableParams(
                        vs_uuid_count=1,
                        service_changed=0,
                        periph_conn_count=0,
                        central_conn_count=1,
                        central_sec_count=0,
            elif config.__conn_ic_id__ == "NRF52":
                gatt_cfg = BLEConfigConnGatt()
                gatt_cfg.att_mtu = self.adapter.default_mtu
                gatt_cfg.tag = CFG_TAG
                self.adapter.driver.ble_cfg_set(BLEConfig.conn_gatt, gatt_cfg)
                # self.adapter.driver.ble_vs_uuid_add(BASE_UUID)
                self.adapter.driver.ble_enable()
        def close(self):
            self.adapter.driver.close()
        def connect_and_discover(self):
            scan_duration = 2
            params = BLEGapScanParams(interval_ms=200, window_ms=150, timeout_s=scan_duration)
            self.adapter.driver.ble_gap_scan_start(scan_params=params)
            print("sssssssssssssssss")
            # print(self.adapter.driver.ble_gap_scan_start(scan_params=params))
            try:
                new_conn = self.conn_q.get(timeout=scan_duration)
                self.adapter.service_discovery(new_conn)
                    new_conn, BLEUUID(BLEUUID.Standard.battery_level)
                self.adapter.enable_notification(new_conn, BLEUUID(BLEUUID.Standard.heart_rate))
                return new_conn
            except Empty:
                print(f"No heart rate collector advertising with name {TARGET_DEV_NAME} found.")
                return None
        def on_gap_evt_connected(
            self, ble_driver, conn_handle, peer_addr, role, conn_params
            print("New connection: {}".format(conn_handle))
            self.conn_q.put(conn_handle)
        def on_gap_evt_disconnected(self, ble_driver, conn_handle, reason):
            print("Disconnected: {} {}".format(conn_handle, reason))
        def on_gap_evt_adv_report(
            self, ble_driver, conn_handle, peer_addr, rssi, adv_type, adv_data
            dev_name_list = ""
            dev_adv_data = ""
            dev_name = ""
            if BLEAdvData.Types.complete_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.complete_local_name]
                dev_name = "".join(chr(e) for e in dev_name_list)
            if BLEAdvData.Types.manufacturer_specific_data in adv_data.records:
                if adv_data.records.get(BLEAdvData.Types.manufacturer_specific_data) == None:
                    pass
                else:
                    dev_adv_data = adv_data.records[BLEAdvData.Types.manufacturer_specific_data]
                    dev_adv_data = "".join("{0:02X}".format(b) for b in dev_adv_data)
            address_string = "".join("{0:02X}".format(b) for b in peer_addr.addr)
            # ":".join("{:02X}".format(a) for a in addr.addr)
            if address_string == TARGET_DEV_NAME:
                if len(dev_name) > 0:
                    self.localName = dev_name
                if len(dev_adv_data) > 0:
                    if len(self.advData) > 0:
                        if self.advData == dev_adv_data:
                            self.adapter.driver.ble_gap_scan_stop()
                            print("stop scan")
                            print("localName ========{}".format(self.localName))
                            print("address ========{}".format(self.address_Str))
                            print("advData ========{}".format(self.advData))
                            self.adapter.connect(peer_addr, tag=CFG_TAG)
                        else:
                            self.advData = "{}{}".format(self.advData,dev_adv_data)
                    else:
                        self.advData = dev_adv_data
            # if address_string == TARGET_DEV_NAME:
            #     print("find device")
        def on_notification(self, ble_adapter, conn_handle, uuid, data):
            if len(data) > 32:
                data = "({}...)".format(data[0:10])
            print("Connection: {}, {} = {}".format(conn_handle, uuid, data))
    def main(selected_serial_port):
        print("Serial port used: {}".format(selected_serial_port))
        driver = BLEDriver(
            serial_port=selected_serial_port, auto_flash=False, baud_rate=1000000, log_severity_level="info"
        adapter = BLEAdapter(driver)
        collector = HRCollector(adapter)
        collector.open()
        conn = collector.connect_and_discover()
        if conn is not None:
            time.sleep(10)
        collector.close()
    def item_choose(item_list):
        for i, it in enumerate(item_list):
            print("\t{} : {}".format(i, it))
        print(" ")
        while True:
            try:
                choice = int(input("Enter your choice: "))
                if (choice >= 0) and (choice < len(item_list)):
                    break
            except Exception:
                pass
            print("\tTry again...")
        return choice
    #查找端口函数
    def findPort():
        ports = serial.tools.list_ports.comports()
        print(ports)
        if len(ports) <= 0:
            print ("The Serial port can't find!")
            exit(1)
        else:
            if len(ports) == 1:
                port0 = list(ports[0])
                port_serial = port0[0]
            else:
                port0 = list(ports[1])
            return port_serial
            print(f"-----{ports}")
            print(f"-----{port_serial}")
    if __name__ == "__main__":
        logging.basicConfig(
            level="DEBUG",
            format="%(asctime)s Ingeek [%(thread)d/%(threadName)s] %(message)s",
        TARGET_DEV_NAME = str(input("输入要连接的设备名称:"))
        print(TARGET_DEV_NAME)
        serial_port = None
        port = findPort()
        sys.argv = ["","NRF52",port]
        print(sys.argv)
        if len(sys.argv) < 2:
            print("Please specify connectivity IC identifier (NRF51, NRF52)")
            exit(1)
        init(sys.argv[1])
        if len(sys.argv) == 3:
            print(sys.argv)
            serial_port = sys.argv[2]
        else:
            descs = BLEDriver.enum_serial_ports()
            print(descs)
            choices = ["{}: {}".format(d.port, d.serial_number) for d in descs]
            choice = item_choose(choices)
            serial_port = descs[choice].port
        main(serial_port)
        quit()
    He told me of the mistake
      File "/Users/syj/Downloads/pc-ble-driver-py/pc_ble_driver_py/examples/heart_rate_collector.py", line 50, in <module>
    NameError: name 'BLEUUIDBase' is not defined
    If I put the method that created the UUID in my code inside def open(self):, I get the following error
    Serial port used: /dev/cu.usbmodemC20FBBC0D20F2
    2020-05-19 18:54:58,209 Ingeek [123145309003776/LogThread] Successfully opened /dev/cu.usbmodemC20FBBC0D20F2. Baud rate: 1000000. Flow control: none. Parity: none.
    2020-05-19 18:54:58,209 Ingeek [123145309003776/LogThread] evt> severity(20) message(Successfully opened /dev/cu.usbmodemC20FBBC0D20F2. Baud rate: 1000000. Flow control: none. Parity: none.)
    2020-05-19 18:54:58,210 Ingeek [123145314258944/StatusThread] RpcAppStatus.resetPerformed: Target Reset performed
    2020-05-19 18:54:58,210 Ingeek [123145314258944/StatusThread] evt> status code(RpcAppStatus.resetPerformed) message(Target Reset performed)
    2020-05-19 18:54:59,428 Ingeek [123145314258944/StatusThread] RpcAppStatus.connectionActive: Connection active
    2020-05-19 18:54:59,428 Ingeek [123145314258944/StatusThread] evt> status code(RpcAppStatus.connectionActive) message(Connection active)
      File "/Users/syj/Downloads/pc-ble-driver-py/pc_ble_driver_py/examples/heart_rate_collector.py", line 286, in <module>
        main(serial_port)
      File "/Users/syj/Downloads/pc-ble-driver-py/pc_ble_driver_py/examples/heart_rate_collector.py", line 215, in main
        collector.open()
      File "/Users/syj/Downloads/pc-ble-driver-py/pc_ble_driver_py/examples/heart_rate_collector.py", line 117, in open
      File "/usr/local/lib/python3.7/site-packages/pc_ble_driver_py/ble_driver.py", line 107, in wrapper
        error_code=err_code,
    pc_ble_driver_py.exceptions.NordicSemiException: Failed to ble_vs_uuid_add. Error code: 12289
    self.adapter.driver.ble_vs_uuid_add(BASE_UUID) This sentence should be wrong, but I don't know why this is wrong.
