Adding custom service UUID in pc_ble_driver_py
Hi
I made a custom service for sending radar data from a NRF52 DK and I'm trying to access it with my computer using the pc_ble_driver_py.
I tried to modify the heart_rate_collector.py example to fit my application, but I am not able to add my custom service UUID.  I followed a similar thread regarding the same issue(How to write to a custom 128 UUID service using pc-ble-driver-py), but it does not work.
I get the error:
  File "C:\Users\akkvj\Anaconda2\lib\site-packages\pc_ble_driver_py\ble_adapter.py", line 254, in enable_notification
raise NordicSemiException('CCCD not found')
pc_ble_driver_py.exceptions.NordicSemiException: CCCD not found
Can you explain how I can modify the heart rate example to enable my custom service? The data I'm transferring are very similar to heart-rate data.
I'm using Anaconda python distribution package and a nRF52840 DK.
Thank you very much
Aksel
  • Hi Aksel
    Have a look at this GitHub "fork" made by one of my colleagues. Also this example where the heart_rate_collector is modified to read battery level might be helpful:
    # Copyright (c) 2016 Nordic Semiconductor ASA
    # All rights reserved.
    # Redistribution and use in source and binary forms, with or without modification,
    # are permitted provided that the following conditions are met:
    #   1. Redistributions of source code must retain the above copyright notice, this
    #   list of conditions and the following disclaimer.
    #   2. Redistributions in binary form must reproduce the above copyright notice, this
    #   list of conditions and the following disclaimer in the documentation and/or
    #   other materials provided with the distribution.
    #   3. Neither the name of Nordic Semiconductor ASA nor the names of other
    #   contributors to this software may be used to endorse or promote products
    #   derived from this software without specific prior written permission.
    #   4. This software must only be used in or with a processor manufactured by Nordic
    #   Semiconductor ASA, or in or with a processor manufactured by a third party that
    #   is used in combination with a processor manufactured by Nordic Semiconductor.
    #   5. Any software provided in binary or object form under this license must not be
    #   reverse engineered, decompiled, modified and/or disassembled.
    # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
    # ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
    # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
    # DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
    # ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
    # (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
    # LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
    # ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    # (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
    # SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    # Example shows how to a read request to get value of the battery_level characteristic
    import sys
    import time
    import Queue
    import logging
    from pc_ble_driver_py.observers     import *
    TARGET_DEV_NAME = "Nordic_HRM"
    CONNECTIONS     = 1
    def init(conn_ic_id):
        global BLEDriver, BLEAdvData, BLEEvtID, BLEAdapter, BLEEnableParams, BLEGapTimeoutSrc, BLEUUID
        from pc_ble_driver_py import config
        config.__conn_ic_id__ = conn_ic_id
        from pc_ble_driver_py.ble_driver    import BLEDriver, BLEAdvData, BLEEvtID, BLEEnableParams, BLEGapTimeoutSrc, BLEUUID
        from pc_ble_driver_py.ble_adapter   import BLEAdapter
        global nrf_sd_ble_api_ver
        nrf_sd_ble_api_ver = config.sd_api_ver_get()
    class HRCollector(BLEDriverObserver, BLEAdapterObserver):
        def __init__(self, adapter):
            super(HRCollector, self).__init__()
            self.adapter    = adapter
            self.conn_q     = Queue.Queue()
            self.adapter.observer_register(self)
            self.adapter.driver.observer_register(self)
        def open(self):
            self.adapter.driver.open()
            ble_enable_params = BLEEnableParams(vs_uuid_count      = 1,
                                                service_changed    = False,
                                                periph_conn_count  = 0,
                                                central_conn_count = CONNECTIONS,
                                                central_sec_count  = CONNECTIONS)
            if nrf_sd_ble_api_ver >= 3:
                print("Enabling larger ATT MTUs")
                ble_enable_params.att_mtu = 50
            self.adapter.driver.ble_enable(ble_enable_params)
        def close(self):
            self.adapter.driver.close()
        def connect_and_discover(self):
            self.adapter.driver.ble_gap_scan_start()
            new_conn = self.conn_q.get(timeout = 60)
                att_mtu = self.adapter.att_mtu_exchange(new_conn)
            self.adapter.service_discovery(new_conn)
            self.adapter.enable_notification(new_conn, BLEUUID(BLEUUID.Standard.battery_level))
            self.adapter.enable_notification(new_conn, BLEUUID(BLEUUID.Standard.heart_rate))
            status, data = self.adapter.read_req(new_conn,BLEUUID(BLEUUID.Standard.battery_level))
            print('Battery level read value = {} status = {}'.format(data,status))
            return new_conn
        def on_gap_evt_connected(self, ble_driver, conn_handle, peer_addr, role, conn_params):
            print('New connection: {}'.format(conn_handle))
            self.conn_q.put(conn_handle)
        def on_gap_evt_disconnected(self, ble_driver, conn_handle, reason):
            print('Disconnected: {} {}'.format(conn_handle, reason))
        def on_gap_evt_timeout(self, ble_driver, conn_handle, src):
            if src == BLEGapTimeoutSrc.scan:
                ble_driver.ble_gap_scan_start()
        def on_gap_evt_adv_report(self, ble_driver, conn_handle, peer_addr, rssi, adv_type, adv_data):
            dev_name_list = None
            if BLEAdvData.Types.complete_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.complete_local_name]
            elif BLEAdvData.Types.short_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.short_local_name]
            else:
                return
            dev_name        = "".join(chr(e) for e in dev_name_list)
            address_string  = "".join("{0:02X}".format(b) for b in peer_addr.addr)
            print('Received advertisment report, address: 0x{}, device_name: {}'.format(address_string,
        dev_name))
            if (dev_name == TARGET_DEV_NAME):
                self.adapter.connect(peer_addr)
        def on_notification(self, ble_adapter, conn_handle, uuid, data):
            print('Connection: {}, {} = {}'.format(conn_handle, uuid, data))
        #It is optional to catch this event:
        def on_gattc_evt_read_rsp(self, ble_driver, conn_handle, status, error_handle, attr_handle, offset,data):
            print('Read Response event - Connection: {}, {} = {}'.format(conn_handle, attr_handle, data))
        def on_att_mtu_exchanged(self, ble_driver, conn_handle, att_mtu):
            print('ATT MTU exchanged: conn_handle={} att_mtu={}'.format(conn_handle, att_mtu))
        def on_gattc_evt_exchange_mtu_rsp(self, ble_driver, conn_handle, **kwargs):
            print('ATT MTU exchange response: conn_handle={}'.format(conn_handle))
    def main(serial_port):
        print('Serial port used: {}'.format(serial_port))
        driver    = BLEDriver(serial_port=serial_port, auto_flash=True)
        adapter   = BLEAdapter(driver)
        collector = HRCollector(adapter)
        collector.open()
        for i in xrange(CONNECTIONS):
            conn_handle = collector.connect_and_discover()
        time.sleep(30)
        print('Closing')
        collector.close()
    def item_choose(item_list):
        for i, it in enumerate(item_list):
            print('\t{} : {}'.format(i, it))
        print(' ')
        while True:
            try:
                choice = int(raw_input('Enter your choice: '))
                if ((choice >= 0) and (choice < len(item_list))):
                    break
            except Exception:
                pass
            print ('\tTry again...')
        return choice
    if __name__ == "__main__":
        serial_port = None
        if len(sys.argv) < 2:
            print("Please specify connectivity IC identifier (NRF51, NRF52)")
            exit(1)
        init(sys.argv[1])
        if len(sys.argv) == 3:
            serial_port = sys.argv[2]
        else:
            descs       = BLEDriver.enum_serial_ports()
            choices     = ['{}: {}'.format(d.port, d.serial_number) for d in descs]
            choice      = item_choose(choices)
            serial_port = descs[choice].port
        main(serial_port)
        quit()
    Simon
  • Hi Simon,
    Thanks for the prompt reply and information. I looked through the repo and example you sendt me, but I didn't really get any wiser. Am I missing something? The battery-level output already has a predefined UUID which is easily accessed.
    For simplicity and easy referencing I can rephrase the question:
    How do I modify the pc-ble-driver-py/heart-rate-collector to be able to take in data from a DK running this example?
    Have a great day Slight smile
    Aksel
  • Hi Aksel
    Back to your original issue. "CCCD not found" for a second. Can you check if your service has a CCCD? The nRFConnect for desktop app will be helpful here.
    Roughly, what you have to do is to replace the the heart rate service with the custom_ble_service. To do this, you should try to understand how the heart rate collector is implemented, and create an equivalent implementation for the service you want.
    Simon
  • This is what nRFConnect looks like when I connect the boards:
    When I hit the play button the Client Characteristic Configuration changes to 01 00 and it seems to be streaming data just fine.
    Could you be a bit more specific please? Like, I see that when enabling notifications for battery-level or heart-rate the example uses predefined UUIDs from the BLEUUID class. What UUID should I use instead of self.adapter.enable_notification(new_conn, BLEUUID(BLEUUID.Standard.heart_rate))?
    As you've probably gathered I'm not an experienced programmer. This is part of my master project where I'm supposed to set up a WSN using the nRF52 DK and radar sensors.
    Thanks for the support
    Aksel
  • I also tried connecting with nRFConnect for Mobile. I get the exact same screenshot(including the CCCD UUID) as in the custom service example.
