I am using NRF51422 Development kit in my project.Here can you tell me which version of Segger embedded studio want to download for this controller. And also plz let me know which version of SDK do i need to use for this controller.
You can use this guide to set up SES. You will have to download SES for ARM compatible with your Operating System.
As for the SDK the most recent that supports a SoftDevice compatible with the nRF51422 is SDK 12.3.0 while using SD S130. I don't know if this is best suited for your needs.
I found you've already tried to get started some days ago. If you're having trouble getting started with your development kit you can use this getting started guide to find your way around and get a feel for using it.
However, I have found that SDK 12.3.0 does not support SES. To try to get it to work you could check out this blog, maybe this and this post can also help you.
Hi
Kevin is correct here I'm afraid. The older SDKs doesn't support SES. I suggest you use another IDE like Keil instead, or think about using an nRF52 series product instead, as they are compatible with the newer SDKs which supports SES.
Simon
I have tried with the keil IDE but i have problem in Keil package installer so i am trying to install SES. can i use SDK 14.1 or later for SES IDE?
Thank you
Thank you .Can i use SDK 14.1 or later for NRF51822 DK?
