how to configure connectable beacon in ble_app_beacon
I learning NRF52832 beacon using SDK15.2 i tested code ble_app_beacon code in non connectable beacon mode its working fine. how can i change this code like connectable beacon to check nrf Connect tool please share any tutorial or example code to change connectable beacon example....????
  • Hi
    I suggest you check out the custom ble service tutorial over on our GitHub, which is a great starting point for learning about how our SDK works, and how the nRF devices operate.
    To change the beacon example from non-connectable to connectable, please refer to the ble_app_blinky example for how to set the BLE_GAP_ADV_TYPE to connectable mode. You could also just flash the ble_app_blinky example to your device to have a connectable one.
    Simon
  • Thanks for relay Simonr,
    I trying merge beacon code in blinky SDK15.2. i added adverting beacon data in blinky code below,
        ret_code_t    err_code;
        static ble_gap_adv_params_t m_adv_params;
        ble_advdata_t advdata;
        ble_advdata_t srdata;
    ble_advdata_manuf_data_t manuf_specific_data;
         manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
        #if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
        // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
        // UICR instead of using the default values. The major and minor values obtained from the UICR
        // are encoded into advertising data in big endian order (MSB First).
        // To set the UICR used by this example to a desired value, write to the address 0x10001080
        // using the nrfjprog tool. The command to be used is as follows.
        // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
        // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
        // the following command should be used.
        // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
        uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
        uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
        uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
        m_beacon_info[index++] = MSB_16(major_value);
        m_beacon_info[index++] = LSB_16(major_value);
        m_beacon_info[index++] = MSB_16(minor_value);
        m_beacon_info[index++] = LSB_16(minor_value);
        manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
        manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
        ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = true;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
     advdata.p_manuf_specific_data = &manuf_specific_data;
        memset(&srdata, 0, sizeof(srdata));
        srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        srdata.uuids_complete.p_uuids  = adv_uuids;
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
        ble_gap_adv_params_t adv_params;
        // Set advertising parameters.
        memset(&adv_params, 0, sizeof(adv_params));
        adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
        adv_params.duration        = APP_ADV_DURATION;
        adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
        adv_params.p_peer_addr     = NULL;
        adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        adv_params.interval        = APP_ADV_INTERVAL;
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
     <error> app: Fatal error
    <warning> app: System reset
    continuously reset on my NRF52832  please help me how i solve this problem....????
  • Hi
    Sorry, I didn't realize that you wanted the beacon code explicitly. I suggest you rather start out with the beacon code, and add the advertising parameters from ble_app_blinky, as well as the defines regarding, advertisement and connection. If you'd rather do it this way, you should try debugging and see where exactly your code fails.
    Simon
