I am trying to perform the steps from infocenter.nordicsemi.com/.../iot_rpi_kernel.html in order to build a 6LoWPAN boarder router.
I followed the steps from Option 1: Cross-compilation on x86/x64. Unfortunately at point 6 (Generate .deb packages) the generation of the packets never comes to end. Attached is the output of the console. Can you eventually provide pre-built .dep packets for raspberry pi 3?
lei@lei02390:~/raspbian/linux$ CONCURRENCY_LEVEL=5 DEB_HOST_ARCH=armhf fakeroot make-kpkg --append-to-version rpi-ble --revision `date +%Y%m%d%H%M%S` --ARCH=arm --cross-compile ${CCPREFIX} kernel_image kernel_headers
exec make kpkg_version=13.018+nmu1 -f /usr/share/kernel-package/ruleset/minimal.mk debian DEBIAN_REVISION=20190424145742 APPEND_TO_VERSION=rpi-ble KPKG_ARCH=arm CROSS_COMPILE=/home/lei/raspbian/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf-
dpkg-architecture: warning: specified GNU system type arm-linux-gnu does not match CC system type x86_64-linux-gnu, try setting a correct CC environment variable
====== making target debian/stamp/conf/minimal_debian [new prereqs: ]======
This is kernel package version 13.018+nmu1.
test -d debian || mkdir debian
test ! -e stamp-building || rm -f stamp-building
install -p -m 755 /usr/share/kernel-package/rules debian/rules
for file in ChangeLog Control Control.bin86 config templates.in rules; do \
cp -f /usr/share/kernel-package/$file ./debian/; \
done
cp: cannot stat '/usr/share/kernel-package/ChangeLog': No such file or directory
for dir in Config docs examples ruleset scripts pkg po; do \
cp -af /usr/share/kernel-package/$dir ./debian/; \
done
test -f debian/control || sed -e 's/=V/4.19.36rpi-ble/g' \
-e 's/=D/20190424145742/g' -e 's/=A/armhf/g' \
-e 's/=SA//g' \
-e 's/=I//g' \
-e 's/=CV/4.19/g' \
-e 's/=M/Unknown Kernel Package Maintainer <[email protected]>/g' \
-e 's/=ST/linux/g' -e 's/=B/arm/g' \
-e 's/=R//g' /usr/share/kernel-package/Control > debian/control
test -f debian/changelog || sed -e 's/=V/4.19.36rpi-ble/g' \
/usr/share/kernel-package/changelog > debian/changelog
chmod 0644 debian/control debian/changelog
test -d ./debian/stamp || mkdir debian/stamp
make -f debian/rules debian/stamp/conf/kernel-conf
make[1]: Entering directory '/home/lei/raspbian/linux'
====== making target debian/stamp/conf/kernel-conf [new prereqs: ]======
make EXTRAVERSION=rpi-ble CROSS_COMPILE=/home/lei/raspbian/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf- ARCH=arm \
oldconfig;
make[2]: Entering directory '/home/lei/raspbian/linux'
scripts/kconfig/conf --oldconfig Kconfig
# configuration written to .config
make[2]: Leaving directory '/home/lei/raspbian/linux'
make EXTRAVERSION=rpi-ble CROSS_COMPILE=/home/lei/raspbian/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf- ARCH=arm prepare
scripts/kconfig/conf --syncconfig Kconfig
UPD include/config/kernel.release
UPD include/generated/utsrelease.h
CALL scripts/checksyscalls.sh
echo done > debian/stamp/conf/kernel-conf
make[1]: Leaving directory '/home/lei/raspbian/linux'
make -f debian/rules debian/stamp/conf/full-changelog
====== making target debian/stamp/conf/full-changelog [new prereqs: ]======
done
done
sed -e 's/=V/4.19.36rpi-ble-v7+/g' \
-e 's/=SA//g' \
-e 's/=I//g' \
-e 's/=CV/4.19/g' \
sed -e 's/=V/4.19.36rpi-ble-v7+/g' -e 's/=D/20190424145742/g' \
-e 's/=A/armhf/g' -e 's/=M/Unknown Kernel Package Maintainer <[email protected]>/g' \
make[2]: 'debian/stamp/conf/kernel-conf' is up to date.
echo done > debian/stamp/conf/minimal_debian
exec debian/rules DEBIAN_REVISION=20190424145742 APPEND_TO_VERSION=rpi-ble KPKG_ARCH=arm CROSS_COMPILE=/home/lei/raspbian/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf- kernel_image kernel_headers
