BLE peripheral with multiple centrals and peer manager
I am developing application which allows multiple central devices (phones) connect to a single peripheral device (custom board with nRF52840). I took example from /ble_peripheral/experimental/ble_app_multiperipheral as reference for my project. So far I have succeeded in connecting multiple centrals to the board and reading services and characteristics.
Also I need to have one service with public characteristics and another one - with private. I don't use bonding, I use SEC_JUST_WORKS with custom PIN code. Before experimenting with central count, I used module ble_advertising for more simple setup. My app with private, public characteristics was working fine.
Now I use ble setup code from the mentioned example. Using peer manager causes application to crash with code NRF_ERROR_INVALID_STATE on first connection event. How should I setup peer manager to work with multiple centrals?
Here is my current initialization code for peer manager:
static void peer_manager_init(void)
    ret_code_t           err_code;
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 0;
    sec_param.kdist_own.id   = 0;
    sec_param.kdist_peer.enc = 0;
    sec_param.kdist_peer.id  = 0;
  • Update: I get NRF_ERROR_INVALID_STATE on first attempt to read/write characteristic with access SEC_JUST_WORKS. Normally it should trigger pairing process. Meanwhile connecting and reading/writing characteristics with SEC_OPEN works good.
  • Hi
    If you see our examples using this bonding they all use key distribution, but you are not. Could you please try replacing the 0 in the kdist functions with a 1?
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    Simon
  • Hello Simon,
    Thank you for your reply. I don't use key distribution because I don't need device bonding. In my use case scenario I want users to type pin code for each connection when they intend to access protected characteristics. (Pin code changes after each disconnect event)
    Actually it looks like I found the cause of my problem. I took ble event handler code from the ble_app_multiperipheral example. And it had following lines:
        // Pairing not supported
        err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle,
                                               BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                               NULL,
                                               NULL);
    I didn't have handling for BLE_GAP_EVT_SEC_PARAMS_REQUEST previously, and I just missed this part when I moved to ble_app_multiperipheral . So I just removed them and pairing now works fine.
  • Great job! Glad you found a solution.
    Simon
