Zigbee Find, Bind, Subscribe.
Hello.
I am trying to implement a Zigbee Network were sensors will be posting data periodically to a Coordinator.
I was looking into the examples provided with the SDK and realized that the Zigbee MultiSensor example is similiar to what i want to implement. The End Device set the attributes and the Coordinator susbcribe to it.
I wanted to know if there is some documentation that describes how i can implement in code the configuration required for the Zigbee CLI Coordinator. I want to perform the find, bind and subscribe using the stack functions. I would really appreciate if you can help me with some example code for that.
Thanks!
    You can find the Zigbee functions that are called in the CLI example if you open the project. In components/zigbee/cli/zigbee_cli_cmd_zdo.c you can find the zdo functins, such as "zdo bind on".
    On line 1816-1831 is a list of the different commands, and the last parameter in the NRF_CLI_CMD() call is the function that is called. So the "zdo bind on" calls m_sub_bind (this is not the last entry, but it is used to differentiate between bind on and bind off). Which again calls cmd_zb_bind on line 1811 in the same file.
    The zcl commands are listed in zigbee_cli_cmd_zcl.c. As you can see, the zcl_subscribe on calls m_sub_subscribe() -> cmd_zb_subscribe(), which is found in components/zigbee/cli/zigbee_cli_cmd_attr_report.c.
    Reports are received by a function cli_agent_ep_handler_report , which gets called from cli_agent_ep_handler which is registered in main function of cli_agent_router example with ZB_AF_SET_ENDPOINT_HANDLER macro.
    I hope this can be of help. Let me know how it goes!
    Best Regards,
    Marjeris
  • no no 。。。Nobody does that. It's a bad example. It doesn't help.I have been in contact with zigbee and ble mesh for a month, but there is no help. Many developers of NXP chips have completed the project, and I am still walking in the same place.
  • case ZB_BDB_SIGNAL_DEVICE_REBOOT:
    if (status == RET_OK)
    //ZB_NWK_DEVICE_TYPE_COORDINATOR
    NRF_LOG_INFO("Device started OK. Start network steering. Reason: %d", sig);
    bsp_board_led_on(ZIGBEE_NETWORK_STATE_LED);
    UNUSED_RETURN_VALUE(bdb_start_top_level_commissioning(ZB_BDB_NETWORK_STEERING));
    zb_err_code = ZB_SCHEDULE_ALARM(bdb_restart_top_level_commissioning, 0, ZB_TIME_ONE_SECOND);
    ZB_ERROR_CHECK(zb_err_code);
    if (m_device_ctx.sensor_params.short_addr == 0x0000)
    NRF_LOG_INFO("go to find sensor ");
    zb_err_code = ZB_SCHEDULE_ALARM(find_sensor, param, MATCH_DESC_REQ_START_DELAY);
    zb_err_code = ZB_SCHEDULE_ALARM(find_timeout, 0, MATCH_DESC_REQ_TIMEOUT);
    param=0;
    } //bind_sensor
    static zb_void_t find_sensor(zb_uint8_t param)
    zb_buf_t * p_buf = ZB_BUF_FROM_REF(param); // Resolve buffer number to buffer address
    zb_zdo_match_desc_param_t * p_req;
    /* Initialize pointers inside buffer and reserve space for zb_zdo_match_desc_param_t request */
    UNUSED_RETURN_VALUE(ZB_BUF_INITIAL_ALLOC(p_buf, sizeof(zb_zdo_match_desc_param_t) + (1) * sizeof(zb_uint16_t), p_req));
    p_req->nwk_addr = MATCH_DESC_REQ_ROLE; // Send to devices specified by MATCH_DESC_REQ_ROLE
    p_req->addr_of_interest = MATCH_DESC_REQ_ROLE; // Get responses from devices specified by MATCH_DESC_REQ_ROLE
    p_req->profile_id = ZB_AF_HA_PROFILE_ID; // Look for Home Automation profile clusters
    // 要点
    /* We are searching for 2 clusters: On/Off and Level Control Server */
    p_req->num_in_clusters = 1;
    p_req->num_out_clusters = 0;
    /*lint -save -e415 // Suppress warning 415 "likely access of out-of-bounds pointer" */
    // p_req->cluster_list[0] = ZB_ZCL_CLUSTER_ID_DOOR_LOCK;
    p_req->cluster_list[1] = ZB_ZCL_CLUSTER_ID_PRESSURE_MEASUREMENT;
    /*lint -restore */
    NRF_LOG_INFO(" sensor short addr %04x",m_device_ctx.sensor_params.short_addr);
    //NRF_LOG_INFO(" sensor nwk_addr %s",p_req->nwk_addr);
    // m_device_ctx.sensor_params.short_addr = 0x00; // Reset short address in order to parse only one response.
    UNUSED_RETURN_VALUE(zb_zdo_match_desc_req(param, find_sensor_cb));
    if(m_device_ctx.sensor_params.short_addr != 0x0000)
    NRF_LOG_INFO("bind .........");
    zb_err_code = ZB_SCHEDULE_ALARM(bind_sensor, param, MATCH_DESC_REQ_START_DELAY);
    zb_err_code = ZB_SCHEDULE_ALARM(bint_sensor_timeout, 0, MATCH_DESC_REQ_TIMEOUT);
    It's not easy to do in cli mode. There are many requests and responses. This chip manufacturer really feels bad
  • Hi ,
    If you have any questions regarding Zigbee or BLE mesh protocol please open a new ticket and we will happily help you. To open a new ticket please go to https://devzone.nordicsemi.com/support/add
