Question about Device Information Service.
Hey,
When I initialize the  device information service as follow ,It seems that  It does not  work ,RTT View show There cause  a  Fatal error 。
But  if  I  initialize one of them only,eg.   ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME); . it  work okay.
  where is wrong with my code?
I am using nRF52832 with SDK 15.0  ,S132 ,SD 6.0
Thanks very much!
ret_code_t err_code;
ble_hrs_init_t hrs_init;
ble_bas_init_t bas_init;
ble_dis_init_t dis_init;
ble_nus_init_t nus_init;
ble_dfu_buttonless_init_t dfus_init = {0};
uint8_t body_sensor_location;
// Initialize Device Information Service.
memset(&dis_init, 0, sizeof(dis_init));
ble_srv_ascii_to_utf8(&dis_init.fw_rev_str, (char *)Firmware_Revision);
ble_srv_ascii_to_utf8(&dis_init.hw_rev_str, (char *)Hardware_Revision);
ble_srv_ascii_to_utf8(&dis_init.sw_rev_str, (char *)Software_Revision);
ble_srv_ascii_to_utf8(&dis_init.serial_num_str,(char *)Serial_Num );
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&dis_init.dis_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&dis_init.dis_attr_md.write_perm);
err_code = ble_dis_init(&dis_init);
// Initialize NUS.
// Initialize Heart Rate Service.
body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_WRIST;
memset(&hrs_init, 0, sizeof(hrs_init));
hrs_init.evt_handler = NULL;
hrs_init.is_sensor_contact_supported = true;
hrs_init.p_body_sensor_location = &body_sensor_location;
// Here the sec level for the Heart Rate Service can be changed/increased.
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_hrm_attr_md.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_bsl_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_bsl_attr_md.write_perm);
err_code = ble_hrs_init(&m_hrs, &hrs_init);
// Initialize Battery Service.
memset(&bas_init, 0, sizeof(bas_init));
// Here the sec level for the Battery Service can be changed/increased.
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&bas_init.battery_level_char_attr_md.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_report_read_perm);
bas_init.evt_handler = NULL;
bas_init.support_notification = true;
bas_init.p_report_ref = NULL;
bas_init.initial_batt_level = 100;
err_code = ble_bas_init(&m_bas, &bas_init);
// Initialize the async SVCI interface to bootloader.
#if 1
err_code = ble_dfu_buttonless_async_svci_init();
dfus_init.evt_handler = ble_dfu_evt_handler;
err_code = ble_dfu_buttonless_init(&dfus_init);
