Chain tool speed
Hello I'v just ordered a NRF51-DK kit.
I'm looking at the different tool chain. In my application speed is critical 16Mhz is actually bearly enough, so my question is:
-Is there a difference in the execution speed of the same code written : Keil , eclipse GCC, or Mbed?
-I see that the NRF51-DK is actually running at 32Mhz, is this ok to put a 32 Mhz Cristal to a nRF51822??
Thanks
  • I don't think it is a definitive answer for that, except that i believe Mbed would be slower because it is higher level. Both in Keil and GCC you have optimization options:
    gcc.gnu.org/.../Optimize-Options.html
    www.keil.com/.../uv4_dg_adscc.htm
    In Keil you have the -Otime optimization, which will optimize for execution time. But, in the end I believe you just have to test, because it depends on your code.
    You can use a 32MHz crystal, but the chip only runs on 16MHz anyway. It just divides the clock.
  • It's all about how you write your code. Knowing how the compiler generate code and write optimize code would be the latest. One compiler with same setting you can have 2 sets of code with one running faster the the other.
    A simple example
    a = b / 2;  // Takes many cpu cycles
    a = b >> 1; // only 1 cycle
    Compiler will not optimize that for you.
    There is a good book on writing optimized code.
    "C++ Footprint and Performance Optimization" by Rene Alexander & Grahm Bensley. Published by SAMS. ISBN 0-672-31904-7
    PS. mBed not recommended for speed.
  • This is also an interesting read regarding optimization. The modulo operator is something embedded engineers fear like the plague, but it's actually efficient on the ARM platform: embeddedgurus.com/.../
    When it comes to speed, it's as Nguyen says, it's the code that the developer writes that has the most impact.
    Doing shift-operations are always efficient compared to doing division/multiplication. I've seen many funky macro functions for effective divisions, which are purely made with regards to speed, and to be accurate enough for the scope it's used in.
    Here's a fantastic snippet from Quake 3 src sqrt calculation: en.wikipedia.org/.../Fast_inverse_square_root
    Cheers, Håkon
