Adding Custom Service to Buttonless DFU example results in fatal error
I am working on NRF52840 preview DK using SDK version 15.3
I have compiled and loaded the Secure DFU bootloader onto the device, and also successfully got the BLE_BUTTONLESS_DFU template to work by uploading it through the DfuTarg.
but, once I try to write my own service in the template the app crashes with a 'fatal error' and the device keeps resetting.
Here is my service_init function
    uint32_t                  err_code;
    nrf_ble_qwr_init_t        qwr_init  = {0};
    ble_dfu_buttonless_init_t dfus_init = {0};
    dfus_init.evt_handler = ble_dfu_evt_handler;
    err_code = ble_dfu_buttonless_init(&dfus_init);
    err_code = ble_dfu_buttonless_async_svci_init();
    ble_uuid_t        service_uuid;
    ble_uuid128_t     base_uuid = BLE_UUID_OUR_BASE_UUID;
    service_uuid.uuid = BLE_UUID_OUR_SERVICE_UUID;
    err_code = sd_ble_uuid_vs_add(&base_uuid, &service_uuid.type);
    // Add our service
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
                            &service_uuid,
                            &p_our_service.service_handle);
some of the settings related to service is as follows
// Defining 16-bit service and 128-bit base UUIDs
#define BLE_UUID_OUR_BASE_UUID              {{0x23, 0xD1, 0x13, 0xEF, 0x5F, 0x78, 0x23, 0x15, 0xDE, 0xEF, 0x12, 0x12, 0x00, 0x00, 0x00, 0x00}} // 128-bit base UUID
#define BLE_UUID_OUR_SERVICE_UUID                0xF00D // Just a random, but recognizable value
typedef struct
    uint16_t service_handle;                /**< Handle of Our Service (as provided by the BLE stack). */
}ble_os_t;
ble_os_t p_our_service;
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                            /**< Handle of the current connection. */
static void advertising_start(bool erase_bonds);                                    /**< Forward declaration of advertising start function */
// YOUR_JOB: Use UUIDs for service(s) used in your application.
static ble_uuid_t m_adv_uuids[] = {{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}, {BLE_UUID_OUR_SERVICE_UUID, BLE_UUID_TYPE_VENDOR_BEGIN}};
I also changed
NRF_SDH_BLE_VS_UUID_COUNT to 2
and
NRF_SDH_BLE_SERVICE_CHANGED = 1
in sdk_config.h
  • sure, but I have fatal error if I start advertising before add a UUID.
  • : "Fatal Error" is printed by the app_error_fault_handler in app_error_weak.c. Please define DEBUG in your Preprocessor Definitions so that the fault id, line number etc is printed in the log output.
    __WEAK void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
        __disable_irq();
        NRF_LOG_FINAL_FLUSH();
    #ifndef DEBUG
        NRF_LOG_ERROR("Fatal error");
    #else
        switch (id)
    #if defined(SOFTDEVICE_PRESENT) && SOFTDEVICE_PRESENT
            case NRF_FAULT_ID_SD_ASSERT:
                NRF_LOG_ERROR("SOFTDEVICE: ASSERTION FAILED");
            case NRF_FAULT_ID_APP_MEMACC:
                NRF_LOG_ERROR("SOFTDEVICE: INVALID MEMORY ACCESS");
            case NRF_FAULT_ID_SDK_ASSERT:
                assert_info_t * p_info = (assert_info_t *)info;
                NRF_LOG_ERROR("ASSERTION FAILED at %s:%u",
                              p_info->p_file_name,
                              p_info->line_num);
            case NRF_FAULT_ID_SDK_ERROR:
                error_info_t * p_info = (error_info_t *)info;
                NRF_LOG_ERROR("ERROR %u [%s] at %s:%u\r\nPC at: 0x%08x",
                              p_info->err_code,
                              nrf_strerror_get(p_info->err_code),
                              p_info->line_num,
                              pc);
                 NRF_LOG_ERROR("End of error report");
                NRF_LOG_ERROR("UNKNOWN FAULT at 0x%08X", pc);
        NRF_BREAKPOINT_COND;
        // On assert, the system can only recover with a reset.
    #ifndef DEBUG
        NRF_LOG_WARNING("System reset");
        NVIC_SystemReset();
    #else
        app_error_save_and_stop(id, pc, info);
    #endif // DEBUG
