I have a custom board SDK 15.2 API 6.1
I have a simple PWM going but it seems to just turn the low and set it high when i turn it on. It does not however seem to pulse according to my scope. Nor does it stop. This is in a ble application that has softdevices enabled and LFCLK source. I am tyring to use app_pwm.h instead of the nrf_drv_pwm. I am curious why a simple application doe snot seem to operate though.
static nrf_drv_pwm_t m_pwm0 = NRF_DRV_PWM_INSTANCE(0); nrf_pwm_values_individual_t seq_values[] = {DUTY_CYCLE, 0, 0, 0}; nrf_pwm_sequence_t const seq = { .values.p_individual = seq_values, .length = NRF_PWM_VALUES_LENGTH(seq_values), .repeats = 0, .end_delay = 0 }; void pwm_start(void) { nrf_drv_pwm_simple_playback(&m_pwm0, &seq, 1, NRF_DRV_PWM_FLAG_LOOP); } void pwm_stop(void) { nrf_drv_pwm_stop(&m_pwm0, false); } static void pwm_init(void) { nrf_drv_pwm_config_t const config0 = { .output_pins = { OUTPUT_PIN, // channel 0 NRF_DRV_PWM_PIN_NOT_USED, // channel 1 NRF_DRV_PWM_PIN_NOT_USED, // channel 2 NRF_DRV_PWM_PIN_NOT_USED, // channel 3 }, .irq_priority = APP_IRQ_PRIORITY_LOWEST, .base_clock = NRF_PWM_CLK_1MHz, .count_mode = NRF_PWM_MODE_UP, .top_value = 100, .load_mode = NRF_PWM_LOAD_INDIVIDUAL, .step_mode = NRF_PWM_STEP_AUTO }; // Init PWM without error handler APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config0, NULL)); } void int main(void){ pwm_init(); pwm_start(); nrf_delay_ms(2000); pwm_stop(); }
