Hi, I am using nrf52832 with SDK 15.2.0 and nrf 52 dev board. I want change advertising interval in run time so I call a function with the interval as the parameter change_adv_interval (interval ) every time that I will change.
Thanks in Advance.
Thanks in Advance.
Hi Prashant
You need to stop and start the advertising when you do your updates. It should be possible with something similar to this:
sd_ble_gap_adv_stop(); ble_gap_adv_params_t adv_params; memset(&adv_params, 0, sizeof(adv_params)); adv_params.interval = interval; adv_params.timeout = 0; err_code = sd_ble_gap_adv_start(&adv_params); APP_ERROR_CHECK(err_code);
Simon
Thanks It Works
Hi Simon,
I am using SDK16 and NRF52 DK. My goal is to update advertising interval in non-connectable mode dynamically. I don't use advertising module and I am following code from pwr_profiling example to setup advertisement parameters.
In order to update the advertising interval, I wrote a function which stops advertising and then updates the interval and calls the function sd_ble_gap_adv_set_configure. I have thought of another approach too and it's commented down there.
However, the function sd_ble_gap_adv_stop fails without any return code. I tried to set a breakpoint and debug, but in vain. Let me know if it is necessary to stop advertisement for this use-case in SDK16 and how to update update advertising interval dynamically. And as well as a technique to debug and find error code.
void non_conn_adv_interval_update(int8_t m_adv_interval)
ret_code_t err_code;
err_code = sd_ble_gap_adv_stop(m_adv_handle);
// Approach 1 :
NRF_LOG_INFO("Adv interval : %d", m_adv_interval);
m_adv_params.interval = m_adv_interval;
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
// Approach 2:
//non_connectable_adv_init(m_adv_interval);
//advertising_start(true);
Dino
